[GRASS-dev] [GRASS GIS] #1201: wingrass
#1201: wingrass
Reporter: hellik | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.1
Component: Packaging | Version: svn-releasebranch64
Keywords: wingrass, gdal, proj4 | Platform: MSWindows Vista
      Cpu: All |
from the osgeo4w-ml:
http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001093.html
I have updated the gdal-dev, libtiff, and libgeotiff packages from the
respective trunks' and CVS heads.
The gdal-dev package is now built with VC9 (Visual Studio 2008 Express).
This greatest challenge with this proved to be mixups with alloc/free
between the GDAL GeoTIFF driver's heap, and the libgeotiff heap since GDAL
is built against the VC9 runtime/heap and libgeotiff is built against the
VC7.1 runtime/heap. The fixes are back in GDAL trunk. This took *way*
too much time for me to track down, isolate and fix but hopefully we are
good till next time folks fiddle with the gt_wkt_srs.cpp code without
realizing this issue.
There seems to be no problem with building GDAL and it's python bindings
with VC9 against the same Python we using VC7.1 with before. Somehow I
thought there was an issue - but apparently not. I did have to take care
to embed manifests.
Once GDAL 1.8 is released I plan to build a gdal18 package using VC9
as a step towards reducing my dependence VC7.1 which is now antique,
and not easily available to others. At that point I'm also hoping
we can migrate most packages using GDAL to GDAL 1.8, to try and get out of
the situation now where the default is ancient (1.5) and some packages
(MapServer, QGIS) have moved to somewhat newer GDALs. This puts us in the
ugly situation where people may end up having to install plugins for
several versions of GDAL instead of install-once, use everywhere applying
as I would like.
I tried to package, and utilize the openjpeg jpeg2000 library but got
caught up in some details and put it off. But this is likely our best
hope for jpeg2000 read/write support that works well for large images
without depending on proprietary libraries.
http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001101.html
hi,
I've read in the ML "gdal-dev, libtiff and libgeotiff upgraded"
(http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001093.html)
from time to time I'm building the "official" wingrass-installer.
after updating according to "gdal-dev, libtiff and libgeotiff upgraded",
I can find following updated files/folders in the osgeo4w-stack:
C:\OSGeo4W\share\proj
C:\OSGeo4W\share\epsg_csv
C:\OSGeo4W\share\gdal
AFAICT the actual wingrass-installers are built against osgeo4w-gdal-15.
gdal and proj4 are dependencies for grass.
which of the above mentioned (actualized) files/folders should be
included in the wingrass-installers and for which above mentioned folders
should be set GDAL_DATA and PROJ_LIB in order to get proj4 and gdal
working properly?
best regards
Helmut (a little be confused and ...)
p.s.
"At that point I'm also hoping we can migrate most packages using GDAL to
GDAL 1.8, to try and get out of the situation now where the default is
ancient (1.5) and some packages (MapServer, QGIS) have moved to somewhat
newer GDALs." ... very appreciated :o)
http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001102.html
Helmut,
They should all be include with wingrass.
GDAL_DATA=C:\OSGeo4W\share\gdal
PROJ_LIB=C:\OSGeo4W\share\proj
GEOTIFF_CSV=C:\OSGeo4W\share\epsg_csv
AFAIK \share\gdal and \share\epsg_csv isn't included at the moment in the
wingrass-installer: see GRASS-packager.bat
(http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows
/GRASS-Packager.bat)
and GEOTIFF_CSV isn't set by the nsis-installer
/GRASS-Installer.nsi)
so wingrass-packaging and installing should be adapted acordingly?
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1201&gt;
#1201: wingrass, gdal, proj4
      Cpu: All |
Ticket URL: <http://trac.osgeo.org/grass/ticket/1201#comment:1&gt;
      Cpu: All |
Comment(by hellik):
patches for wingrass64svn, wingrass6devel and wingrass70svn added.
should they be applied?
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1201#comment:2&gt;
      Cpu: All |
Comment(by hellik):
Replying to [comment:2 hellik]:
> Helmut
slightly modified patches (deinstall new files added by the wingrass-
deinstaller) comitted:
r44053 (wingrass64)
r44054 (wingrass65)
r44055 (wingrass70)
locally tested, leave the ticket open until some testing (also by the
nightly builds)
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1201#comment:3&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: wingrass, gdal, proj4
  Platform: MSWindows Vista | Cpu: All
Changes (by hellik):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:3 hellik]:
> > Helmut
> r44053 (wingrass64)
> r44054 (wingrass65)
> r44055 (wingrass70)
nightly builds)
> Helmut
tested with the nightly build WinGRASS-6.4.SVN-r44123-1-Setup.exe
all examples for r.in.wms from the manpage (US NED Elevation from OnEarth
server download (metric units), LANDSAT from OnEarth server download,
DRG from Terraserver server download; which all requires the correctly set
GDAL_DATA-, PROJ_LIB-, GEOTIFF_CSV-variables) for the nc-sample-dataset
seems to work.
so I'm closing the ticket, please reopen if there are any problems with
the wingrass-installers and the GDAL_DATA-, PROJ_LIB-, GEOTIFF_CSV-
variables.
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1201#comment:4&gt;
