#1207: wingrass - installation incomplete/messed
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass, compiling | Platform: MSWindows Vista
Cpu: x86-32 |
fresh svn-checkout of releasebranch64
compiled and installed in the osgeo4w-tree (source is in
C:\OSGeo4W\usr\src\grass64svn) by package.sh in the source
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows/osgeo4w/package.sh
#!/c/OSGeo4W/apps/msys/bin/sh
set -e
if ! [ -d mswindows ]; then
echo Start from GRASS toplevel dir
exit 1
fi
export OSGEO4W_ROOT_MSYS=/c/OSGeo4W
export
PATH=.:/c/mingw/bin:/usr/local/bin:/bin:$OSGEO4W_ROOT_MSYS/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem
version() {
read MAJOR
read MINOR
read PATCH
echo $MAJOR.$MINOR.$PATCH
) <include/VERSION
export VERSION=$(version)
export PACKAGE=3
echo
echo
echo
if ! [ -f mswindows/osgeo4w/configure-stamp ]; then
if [ -e include/Make/Grass.make ] ; then
echo $(date): STARTING make distclean
make distclean
fi
echo $(date): STARTING configure
./configure \
--with-libs="$OSGEO4W_ROOT_MSYS/apps/gdal-16/lib
$OSGEO4W_ROOT_MSYS/lib" \
--with-includes="$OSGEO4W_ROOT_MSYS/apps/gdal-16/include
$OSGEO4W_ROOT_MSYS/include" \
--exec-prefix=$OSGEO4W_ROOT_MSYS/bin \
--libexecdir=$OSGEO4W_ROOT_MSYS/bin \
--prefix=$OSGEO4W_ROOT_MSYS/apps/grass \
--includedir=$OSGEO4W_ROOT_MSYS/include \
--disable-x --without-x \
--with-cxx \
--enable-shared \
--enable-largefile \
--with-opengl=windows \
--with-fftw \
--with-freetype \
--with-proj-share=$OSGEO4W_ROOT_MSYS/share/proj \
--with-gdal=$OSGEO4W_ROOT_MSYS/bin/gdal-config \
--with-tcltk \
--with-sqlite \
--with-postgres \
--with-curses \
--with-regex \
--with-nls \
--with-freetype-
includes=$OSGEO4W_ROOT_MSYS/include/freetype2 \
--with-odbc
touch mswindows/osgeo4w/configure-stamp
fi
make || make
echo $(date): STARTING make install
make install
echo $(date): STARTING cleanup
mv $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/lib/*.$VERSION.dll
rm $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/lib/*.dll
mv $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h
$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h.mingw
cp mswindows/osgeo4w/config.h.switch
cp mswindows/osgeo4w/config.h.vc
cp mswindows/osgeo4w/grass64.bat.tmpl
$OSGEO4W_ROOT_MSYS/bin/grass64.bat.tmpl
cp mswindows/osgeo4w/ini.bat.tmpl
$OSGEO4W_ROOT_MSYS/etc/ini/grass.bat.tmpl
cp mswindows/osgeo4w/postinstall.bat
$OSGEO4W_ROOT_MSYS/etc/postinstall/grass.bat
cp mswindows/osgeo4w/preremove.bat
$OSGEO4W_ROOT_MSYS/etc/preremove/grass.bat
#cp /c/mingw/bin/libgnurx-0.dll $OSGEO_ROOT_MSYS/bin
#cp /c/mingw/bin/libiconv-2.dll $OSGEO_ROOT_MSYS/bin
#cp /c/mingw/bin/libintl-8.dll $OSGEO_ROOT_MSYS/bin
P=$(pwd -W)
P=${P//\//\\\\}\\\\dist.i686-pc-mingw32
sed -e "s#$P#@osgeo4w@#"
$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/fontcap
>$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/fontcap.tmpl
sed -e "s#$P#@osgeo4w_msys@#" $OSGEO4W_ROOT_MSYS/apps/grass/bin/grass64
>$OSGEO4W_ROOT_MSYS/apps/grass/bin/grass64.tmpl
rm $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/fontcap
echo $(date): END
) | tee -a mswindows/osgeo4w/package.log
(1)after compiling, in C:\OSGeo4W\usr\src\grass64svn\dist.i686-pc-mingw32
there are following files/folders:
AUTHORS
bin
bwidget
CHANGES
COPYING
demolocation
docs
driver
etc
fonts
GPL.TXT
grass64.tmp
include
lib
locale
log.txt
REQUIREMENTS.html
scripts
tools
so contributors.csv and translators.csv seems to be missed and therefore
also not in C:\OSGeo4W\apps\grass\grass-6.4.1svn after installing
(2)
in C:\OSGeo4W\usr\src\grass64svn\bin.i686-pc-mingw32 there are following
files:
grass64
grass64.bat
a few weeks ago the files, adapted for the path etc., were installed in
C:\OSGeo4W\apps\grass\bin.
now there is only an empty grass64.tmpl in C:\OSGeo4W\apps\grass\bin
and in C:\OSGeo4W\bin there is grass64.bat.tmpl and in C:\OSGeo4W\bin\bin
there are the two files grass64 and grass64.bat (but not adapted for the
path)
and in the installation-log there is following message:
Following modules are missing the 'description.html' file in src code:
GRASS GIS compilation log
Started compilation: Sat Oct 30 17:35:17 GMT 2010
Errors in:
No errors detected.
Finished compilation: Sat Oct 30 18:45:00 GMT 2010
Sat Oct 30 18:45:00 GMT 2010: STARTING make install
include/Make/Doxygen.make:13: warning: overriding commands for target
`htmldocs
-single'
include/Make/Docs.make:11: warning: ignoring old commands for target
`htmldocs-
single'
include/Make/Doxygen.make:19: warning: overriding commands for target
`htmldocs
include/Make/Docs.make:38: warning: ignoring old commands for target
`htmldocs'
include/Make/Doxygen.make:39: warning: overriding commands for target
`pdfdocs'
include/Make/Docs.make:49: warning: ignoring old commands for target
`pdfdocs'
include/Make/Doxygen.make:51: warning: overriding commands for target
`cleandoc
s'
include/Make/Docs.make:55: warning: ignoring old commands for target
`cleandocs
echo /c/osgeo4w/usr/src/grass64svn/bin.i686-pc-mingw32/grass64
`htmldocs
-single'
include/Make/Docs.make:11: make[1]: Entering directory
`/c/osgeo4w/usr/src/gras
s64svn'
warning: ignoring old commands for target `htmldocs-single'
`htmldocs
`htmldocs'
`pdfdocs'
`pdfdocs'
`cleandoc
s'
`cleandocs
test -d /c/OSGeo4W/apps/grass/grass-6.4.1svn || mkdir -p -m 755
/c/OSGeo4W/apps
test -d /c/OSGeo4W/bin/bin || mkdir -p -m 755 /c/OSGeo4W/bin/bin
sed -e "s#^GISBASE.*#GISBASE=/c/OSGeo4W/apps/grass/grass-6.4.1svn#"
/c/osgeo4w/
usr/src/grass64svn/bin.i686-pc-mingw32/grass64 >
/c/OSGeo4W/bin/bin/grass64
chmod a+x /c/OSGeo4W/bin/bin/grass64
sed -e "s#WINGISBASE=.*#WINGISBASE=/c/OSGeo4W/apps/grass/grass-6.4.1svn#"
/c/os
geo4w/usr/src/grass64svn/bin.i686-pc-mingw32/grass64.bat >
rass64.bat
chmod a+x /c/OSGeo4W/bin/bin/grass64.bat
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - AUTHORS
COPYI
NG CHANGES REQUIREMENTS.html GPL.TXT | (cd
; tar xBf - ) 2>/dev/null
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - bin |
(cd /c/
OSGeo4W/apps/grass/grass-6.4.1svn ; tar xBf - ) 2>/dev/null
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - bwidget
| (cd
/c/OSGeo4W/apps/grass/grass-6.4.1svn ; tar xBf - ) 2>/dev/null
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - docs |
(cd /c
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - driver |
(cd
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - etc |
(cd /c/
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - fonts |
(cd /
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - man |
(cd /c/
tar: man: Cannot stat: No such file or directory
tar: Error exit delayed from previous errors
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - scripts
| (cd
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - tools |
(cd /
if [ 1 -eq 1 ] ; then cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-
mingw32 ; t
ar cBf - locale | (cd /c/OSGeo4W/apps/grass/grass-6.4.1svn ; tar xBf - )
2>/dev
/null ; fi
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - include
| (cd
cd /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32 ; tar cBf - lib |
(cd /c/
sed 's#'/c/osgeo4w/usr/src/grass64svn/dist.i686-pc-
mingw32'#'/c/OSGeo4W/apps/gr
ass/grass-6.4.1svn'#g' /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-
mingw32/etc/m
onitorcap > /c/OSGeo4W/apps/grass/grass-6.4.1svn/etc/monitorcap
mingw32/etc/f
ontcap > /c/OSGeo4W/apps/grass/grass-6.4.1svn/etc/fontcap
chmod -R a+rX /c/OSGeo4W/apps/grass/grass-6.4.1svn 2>/dev/null
tar cBf - gem/skeleton | (cd /c/OSGeo4W/apps/grass/grass-6.4.1svn/etc ;
tar xBf
- ) 2>/dev/null
tar: gem/skeleton/.svn/text-base: file changed as we read it
/bin/install -c gem/gem64 /c/OSGeo4W/bin/bin 2>/dev/null
make[1]: [real-install] Error 1 (ignored)
make[1]: Leaving directory `/c/osgeo4w/usr/src/grass64svn'
Sat Oct 30 18:46:41 GMT 2010: STARTING cleanup
sed: can't read /c/OSGeo4W/apps/grass/bin/grass64: No such file or
directory
so the sed-command can't find the file in C:\OSGeo4W\apps\grass\bin,
because it's partly in C:\OSGeo4W\bin and in C:\OSGeo4W\bin\bin
directory
AFAICT a few weeks ago this issues weren't there.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1207>
