GDAL
November 18, 2010, 11:13am
1
#1218: make htmldocs generates Python and not C documentation
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: Docs | Version: svn-develbranch6
Keywords: | Platform: Unspecified
Cpu: Unspecified |
After opening programmers manual generated by "make htmldocs", all C
functions having Python alternatives are replaced by Python ones
description.
Example: GRASS 6 Vector Architecture -> Vector build functions ->
Vect_build() -> goes to "list grass::lib::vector::Vect_build =
_libs['grass_vect']" comming from "dist.x86_64-unknown-linux-
gnu/etc/python/grass/lib/vector.py" and not original lib/... C version.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1218> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
November 18, 2010, 5:42pm
2
Cpu: Unspecified |
Comment(by neteler):
The command should be "make htmldocs-single".
When using the indicated link, I get the same problem indeed!
For the GRASS 7 progman it works ok.
It must be a recent doxygen bug, perhaps a namespace overlap of the page
labels?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1218#comment:1> ;
GDAL
November 20, 2010, 10:24pm
3
Reporter: marisn | Owner: martinl
Type: defect | Status: assigned
Cpu: Unspecified |
Changes (by martinl):
* cc: grass-dev@… (added)
* owner: grass-dev@… => martinl
* status: new => assigned
Comment:
Related to r44040. I will take a look as soon as posible.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1218#comment:2> ;
GDAL
December 4, 2010, 9:59pm
4
Cpu: Unspecified |
Comment(by martinl):
Hopefully fixed in r44538.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1218#comment:3> ;
GDAL
December 15, 2010, 10:58pm
5
Type: defect | Status: closed
Resolution: fixed | Keywords:
Platform: Unspecified | Cpu: Unspecified
* status: assigned => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1218#comment:4> ;
GDAL
January 4, 2011, 3:44pm
6
Type: defect | Status: reopened
Resolution: | Keywords:
Changes (by marisn):
* status: closed => reopened
* resolution: fixed =>
Comment:
Not fixed at all. Confirmed by http://grass.osgeo.org/programming6/
Ticket URL: <http://trac.osgeo.org/grass/ticket/1218#comment:5> ;
GDAL
January 4, 2011, 4:01pm
7
Replying to [comment:5 marisn]:
When building api docs on my machine, everything is OK. Can you build api
docs on your own and confirm it?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1218#comment:6> ;
GDAL
January 4, 2011, 5:35pm
8
* status: reopened => closed
Comment:
Replying to [comment:6 martinl]:
api docs on your own and confirm it?
Ah. "make distclean" issue. Somebody needs to run it also on documentation
generation server (Markus?).
Sorry for noise.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1218#comment:7> ;
