[GRASS-dev] [GRASS GIS] #122: g.region should not duplicate the code of G3d_regionToCellHead ()
Reporter: 1gray | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: trivial | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: |
Currently, {{{g.region/main.c}}} includes almost the same code that's
already available as the {{{G3d_regionToCellHead ()}}} function.
Hence, I suggest the following change:
general/g.region/main.c (main): Use `G3d_regionToCellHead' instead of
copying the fields directly.
An (untested) patch is attached.
Ticket URL: <http://trac.osgeo.org/grass/ticket/122&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords:
Comment (by neteler):
If it works, consider to submit. Folks often just test once present in
SVN.
Ticket URL: <http://trac.osgeo.org/grass/ticket/122#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Applied to trunk.
Ticket URL: <http://trac.osgeo.org/grass/ticket/122#comment:2&gt;
