[GRASS-dev] [GRASS GIS] #1220: Error when creating vector(areas) from raster
Reporter: toyzerocha1980 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.1
Component: Vector | Version:
Keywords: | Platform: MSWindows XP
      Cpu: x86-32 |
I'm trying to create a vector (areas) from a big LandUSe/LandCover map
with a lot of small patterns so, I believe that I have a lot of polygons
I'm using this expression:
r.to.vect -v input=map output=test02 feature=area
And I get this error:
Extracting areas...
Building topology for vector map <test02>...
Registering primitives...
  820000ERROR: G_realloc: unable to allocate 9900000 bytes at cindex.c:108
A few days ago, with other image I have obtained almost tghe same error
but a bit different:
ERROR: G_realloc: unable to allocate 33760000 bytes at areas.c:678
My Region is defined as:
projection: 99 (Transverse Mercator)
zone: 0
datum: etrs89
ellipsoid: grs80
north: -4772.159565
south: -300404.804
west: -28364.80083451
east: 105242.8746
nsres: 30.00128318
ewres: 29.99723292
rows: 9854
cols: 4454
cells: 43889716
I'm going to try in Linux and I wil reply on this right next.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220&gt;
      Cpu: x86-32 |
Comment(by toyzerocha1980):
Hi
Still in Windows: It has created a vector file and it seems ok (in extent)
But If I use v.what I get:
v.what --q -a map=test03@National east_north=66367.029426,-51132.981541
distance=220.079183
Coor files of vector map <test03@National> is larger than it should be
(99266507 bytes excess)
ERROR: You must build topology on vector map <teste03@National>
(Mon Nov 22 12:21:03 2010) Command finished (0 sec)
And I'm not able to add any column v.db.addcol and Vector does not have
any topology...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220#comment:1&gt;
      Cpu: x86-32 |
Ok I have decided to create/build topology
v.build map=test10@National error=error10
Coor files of vector map <teste10@National> is larger than it should be
Building topology for vector map <teste10>...
1874449 primitives registered
5317522 vertices registered
Building areas...
601738 areas built
117075 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 1389786
Number of primitives: 1874449
Number of points: 0
Number of lines: 0
Number of boundaries: 1272712
Number of centroids: 601737
Number of areas: 601738
Number of isles: 117075
Number of areas without centroid: 1
Building topology for vector map <error10>...
1 primitives registered
5 vertices registered
Building areas...
1 areas built
1 isles built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of centroids: 0
Number of areas: 1
Number of isles: 1
(Mon Nov 22 13:54:01 2010) Command finished (1421 sec)
And when I try v.what I get:
Building spatial index...
East: 70680.40267
North: -70979.942188
Map: teste10
Mapset: National
Type: Area
Sq Meters: 1083351106.914
Hectares: 108335.111
Acres: 267701.889
Sq Miles: 418.2842
Layer: 1
Category: 11
Driver: dbf
Database: C:\DWEISdata/Portugal/National/dbf/
Table: teste10
Key column: cat
Cannot open select cursor:<BR>'select * from teste10 where cat = 11'<BR>on
database 'C:\\DWEISdata/Portugal/National/dbf/' by driver 'dbf'<BR>
DBMI-DBF driver error:
Table 'teste10' doesn't exist.
Error in db_open_select_cursor()
(Mon Nov 22 14:45:19 2010) Command finished (131 sec)
and the following in DOS commandline window
Table "test10" doesn't exist
GRASS_INFO_ERROR(5452,1): Unable to describe table <test10>
GRASS_INFO_END(5452,1)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220#comment:2&gt;
      Cpu: x86-32 |
Comment(by neteler):
Replying to [comment:2 toyzerocha1980]:
> Building areas...
> 601738 areas built
> 117075 isles built
perhaps you exceed the 2Gb limit here? GRASS 7 supports large file support
(LFS).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220#comment:3&gt;
      Cpu: x86-32 |
Comment(by mmetz):
Replying to [comment:3 neteler]:
be (99266507 bytes excess)
> > Building areas...
> > 601738 areas built
> > 117075 isles built
support (LFS).
I don't think so. The coor file size warning is issued because the vector
was not properly closed when creating it with r.to.vect and the coor file
size was not written to the coor header. So far this warning can be
ignored. Also, there is no LFS (yet) in wingrass, also not in 7.
601738 areas is a lot and you are likely to run out of memory with such a
large vector on a 32 bit operating system, or a 64 bit operating system
with insufficient system memory. I am planning to substantially reduce
memory requirements for vector processing in grass 7 such that you could
easily process 601738 areas with 32 bit wingrass, but that will still take
some time.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220#comment:4&gt;
      Cpu: x86-32 |
Hi
In this case, and since I'm converting a raster-to-Vector how can I know
that I'm over 2Gb limit?
Ok, after some minor changes in r.to.vect (in areas_io.c), I was able to
produce a vector file for my raster after almost 3 hours processing (in
Win 7).
When I try to display it, GRASS freezed and then collpsed.
But this is no way to do this...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220#comment:5&gt;
Priority: major | Milestone: 6.4.1
      Cpu: x86-32 |
Changes (by martinl):
  * priority: blocker => major
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220#comment:6&gt;
Keywords: wingrass | Platform: MSWindows XP
      Cpu: x86-32 |
Changes (by hellik):
  * keywords: => wingrass
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220#comment:7&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: wingrass, memory, r.to.vect
  Platform: MSWindows XP | Cpu: x86-32
Changes (by hamish):
  * keywords: wingrass => wingrass, memory, r.to.vect
  * status: new => closed
  * resolution: => wontfix
Comment:
closing the ticket as "wontfix" (aka can't fix), if you want to work with
huge datasets the solutions seem to be installing more RAM and/or a more
capable 64bit OS.
building topology in GRASS 6.4 is going to get memory hungry and with
32bit WinXP there's a hard RAM limit that we can't do much about.
you can try to use the `r.to.vect -b` flag to skip building topology, but
that's mostly useful for point data, not areas.
you can also try running the module on a smaller raster region, then
`v.patch` the results back together and dissolve out any seam boundary
lines.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1220#comment:8&gt;
