[GRASS-dev] [GRASS GIS] #1223: g.mapsets access from menu broken
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: MacOSX
      Cpu: OSX/Intel |
Trying to access g.mapsets from the menu raises the following error:
   File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc
/gui/wxpython/wxgui.py", line 304, in OnMapsets
dlg = preferences.MapsetAccess(parent = self, id =
wx.ID_ANY)
   File "/Users/cmbarton/grass_dev/grass70_dev/dist.i386
-apple-
darwin10.5.0/etc/gui/wxpython/gui_modules/preferences.py",
line 2183, in __init__
wx.Dialog.__init__(self, parent, id, title, pos, size,
style)
NameError
global name 'pos' is not defined
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223&gt;
Component: Installation | Version: svn-trunk
      Cpu: OSX/Intel |
Changes (by cmbarton):
  * component: wxGUI => Installation
Comment:
Turns out that g.mapsets cannot be launched from the command line or
terminal either. No way to set mapset access in GRASS 7 currently.
Changing component from wxGUI to ... hmmm there is no component for
general, configuration, or settings. I'm picking "installation" because
this is slightly less erroneous than the other choices.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:1&gt;
      Cpu: OSX/Intel |
Changes (by martinl):
* cc: grass-dev@… (added)
  * component: Installation => wxGUI
Comment:
Replying to [comment:1 cmbarton]:
g.mapsets doesn't start from the cli because all parameters are optional.
Probably we could change this behaviour in GRASS7. You can force launching
GUI dialog by
g.mapsets --ui
> set mapset access in GRASS 7 currently. Changing component from wxGUI to
... hmmm there is no component for general, configuration, or settings.
I'm picking "installation" because this is slightly less erroneous than
the other choices.
fixed in r44412.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:2&gt;
Reporter: cmbarton | Owner: martinl
     Type: defect | Status: assigned
      Cpu: OSX/Intel |
  * owner: grass-dev@… => martinl
  * status: new => assigned
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:3&gt;
      Cpu: OSX/Intel |
Comment(by glynn):
Replying to [comment:2 martinl]:
optional. Probably we could change this behaviour in GRASS7.
Note that GRASS 7 intentionally doesn't launch a GUI when all required
parameters are provided. In 6.x, modules which want to be able to run
without parameters must skip the call to G_parser() if no parameters are
given. The problem here is that G_parser() performs some necessary tasks
even when no options are provided, so it should always be called.
The real problem is that "required" options have to be marked as optional
if there are any special cases which eliminate the requirement, e.g. the
"-l" flag in the case of g.mapsets. Ideally, we should add a mechanism to
allow such flags to suppress the checking of required options, so that the
->required field can be set based upon normal usage rather than a worst-
case scenario.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:4&gt;
      Cpu: OSX/Intel |
Comment(by glynn):
Replying to [comment:4 glynn]:
optional if there are any special cases which eliminate the requirement,
e.g. the "-l" flag in the case of g.mapsets.
My mistake; g.mapsets really doesn't have any required options. If it does
nothing when no options are given, it should probably at least generate an
error along the lines of "at least one of ... must be given".
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:5&gt;
      Cpu: OSX/Intel |
Comment(by martinl):
Replying to [comment:5 glynn]:
does nothing when no options are given, it should probably at least
generate an error along the lines of "at least one of ... must be given".
in the case that {{{GRASS_GUI}}} is not 'text' better to launch GUI
dialog.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:6&gt;
      Cpu: OSX/Intel |
Comment(by cmbarton):
So the menu entry in the GUI should be "g.mapsets --ui" rather than
g.mapsets?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:7&gt;
      Cpu: OSX/Intel |
Replying to [comment:7 cmbarton]:
g.mapsets?
No, from wxGUI it will run without {{{-ui}}}. I was speaking about CLI.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:8&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: MacOSX | Cpu: OSX/Intel
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:9&gt;
