GDAL
December 3, 2010, 11:29am
1
#1229: Error in db.droptable
Reporter: akbgf | Owner: grass-dev@…
Type: defect | Status: new
Component: Database | Version: svn-trunk
Keywords: db.droptable | Platform: Linux
Cpu: x86-32 |
GRASS-7.0 r44530, the db.droptable complains about -f flag, and does not
remove the table:
(Fri Dec 3 13:13:41 2010)
db.droptable -f table=refl :
Sorry, <f> is not a valid flag
The table 'refl' is present, driver=pg.
GRASS-6.4 drops the table.
Andres Kuusk,
Tartu Observatory,
Estonia,
andres@aai.ee
Ticket URL: <http://trac.osgeo.org/grass/ticket/1229> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
September 17, 2011, 8:02pm
2
Cpu: x86-32 |
Comment(by lucadelu):
I try with r48337 and NC datasete I got this error
db.droptable hospitals
dbmi: db_drop_table() not implemented
I grep db_drop_table and I found
lib/python/ctypes/dbmi.py
# /home/luca/compilati/grass70_new/dist.i686-pc-linux-
gnu/include/grass/dbmidefs.h: 123
if hasattr(_libs['grass_dbmiclient.7.0.svn'], 'db_drop_table'):
db_drop_table = _libs['grass_dbmiclient.7.0.svn'].db_drop_table
db_drop_table.restype = c_int
db_drop_table.argtypes = [POINTER(dbDriver), POINTER(dbString)]
cheers
Luca
Ticket URL: <https://trac.osgeo.org/grass/ticket/1229#comment:1> ;
GDAL
September 17, 2011, 9:11pm
3
Cpu: x86-32 |
Comment(by mmetz):
Replying to [comment:1 lucadelu]:
[snip]
Worksforme with both dbf and sqlite driver. Try make disclean, svn up,
configure, make.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1229#comment:2> ;
GDAL
September 22, 2011, 4:20pm
4
Type: defect | Status: closed
Resolution: fixed | Keywords: db.droptable
Platform: Linux | Cpu: x86-32
Changes (by lucadelu):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:2 mmetz]:
configure, make.
I confirm that it works. I close the ticket as fixed
> Markus M
Luca
Ticket URL: <https://trac.osgeo.org/grass/ticket/1229#comment:3> ;
