[GRASS-dev] [GRASS GIS] #1231: v.parallel cycles
Reporter: akbgf | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: v.parallel | Platform: Linux
      Cpu: x86-32 |
GRASS-7.0 r44543
There are occasions that v.parallel can not create parallel lines to a
line, v.parallel cycles forever.
Attached please find a small raster r35.txt and vector v35.txt which has a
line and a centroid. The following sequence of commands will create an
infinite loop:
r.in.ascii -i --overwrite input=r35.txt output=r35[[BR]]
v.in.ascii --overwrite input=v35.txt output=v35 format=standard
fs='space'[[BR]]
v.parallel -b input=v35 layer=-1 output=v35b distance=10 side=both
--overwrite
Andres Kuusk, Tartu Observatory, Estonia, andres@aai.ee
Ticket URL: <http://trac.osgeo.org/grass/ticket/1231&gt;
Keywords: v.parallel, patch | Platform: Linux
      Cpu: x86-32 |
Changes (by yawl):
  * keywords: v.parallel => v.parallel, patch
Comment:
The function
void link__set_next(VOID_T * a, VOID_T * b)
in lib/linkm/next.c corrupted the
struct Slink
     double x;
     struct Slink *next;
defined in lib/vector/Vlib/poly.c
by modifying x instead of *next.
The patch is attached as grass.diff
Ticket URL: <http://trac.osgeo.org/grass/ticket/1231#comment:1&gt;
#1231: v.parallel2 cycles
Keywords: v.parallel2, patch | Platform: Linux
      Cpu: x86-32 |
Changes (by mmetz):
  * keywords: v.parallel, patch => v.parallel2, patch
Comment:
Applies to v.parallel2, not to v.parallel.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1231#comment:2&gt;
Priority: normal | Milestone: 6.4.5
      Cpu: x86-32 |
Changes (by neteler):
  * milestone: 7.0.0 => 6.4.5
Comment:
v.parallel2 only exists in GRASS 6, downgrading milestone.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1231#comment:3&gt;
      Cpu: x86-32 |
Changes (by mmetz):
  * milestone: 6.4.5 => 7.0.0
Comment:
Replying to [comment:3 neteler]:
v.parallel2 has been renamed to v.parallel in GRASS 7, restoring
milestone.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1231#comment:4&gt;
