The 3D visualizer is disabled in the stable GRASS 6.4.0 version.
GRASS 6.5 is an active development version. Because of this, somethings
may not work or cause crashes. This is the nature of a dev version,
although GRASS dev versions are pretty solid.
I'm using GRASS 6.5 and 7 actively on Mac OSX and have not experienced a
crash in the viewer. Can you detail what caused it so that we can work on
improving it?
There is a bug in which quitting the 3D viewer BEFORE switching the GIS
manager window back to the layer-manager pane will cause the 3D controls
to overlay the layer manager and lock them up. I don't know whether this
is what you are experiencing, but I've submitted a fix to this for GRASS 7
and am waiting on testing results before backporting to 6.5
Replying to [comment:2 cmbarton]:
tested with the latest nightly-build of WinGrass7. switching back to 2d-
view is possible without an overlay of the 3d controls.
but if I exit the wxgui, python is crashing. this doesn't occur if the
wxgui is always only in 2d-view mode.
When I exit the GUI after being in 3D mode, I get error messages sent to
the terminal. This is not a crash. And I don't know if the error messages
are bogus or not, since they seem to have no effect on the operation of
the program otherwise. Is this what you are talking about?
Replying to [comment:6 cmbarton]:
no, the wxgui-grass-layer-manager-window and python itself are crashing
(see screenshot).
i download your binary version for grass65 and i have the same behavioure
gui window start at the top of the screen (i'm not able to move them)
and if i select "3d view" in the map-display combo-box
i have a gui crash (quit).
tomorrow at work i've access to ftp to upload a screen-record
Yes, i'm using the latest frameworks,
seems to me that's a problem more related to python + wx + osx
(i don't think the framewroks are affecting this problem)
I see several errors popping up when you start. 1) you are missing NumPy
(in terminal), 2) some text shows up in the command window in the GUI, but
it went by so fast that I could not see it.
Have you installed any other Python on your computer at any time, or in
any other application?
in the wx output window i have the "digitizer worning" :
Vector digitizer not available
Reason: No module named grass6_wxvdigit
Note that the wxGUI's vector digitizer is currently disabled
(hopefully this will be fixed soon). Please keep an eye out
for updated versions of GRASS. In the meantime you can use
"v.digit" from the Develop Vector menu.
while on the shell i've a numpy "not found" error :
GRASS 6.5.svn (spearfish60):~ > profile.py: This module requires the NumPy
module, which could not be imported. It probably is not installed (it's
not part of the standard Python distribution). See the Numeric Python site
(http://numpy.scipy.org) for information on downloading source or
binaries.
^ this is beacouse i'm using python 2.7 64bit and numpy, scipy and all my
"python source build" are for 64bit arch.
this is is a problem of WX on OSX , the lack of a 64 bit version for wx
... make all the things more difficult.
actually i really don't like the state of WX .. we're waiting a 64bit
cocoa version from more than 2 years.
i tried the 2.9 cocoa version and it is buggy as well.
I'm pretty sure that this is a version mismatch problem. This is likely to
be more of an issue with 6.5, in which both the digitizer and 3D
visualizer are built with swig than in 7, where we switched to ctypes.
The GUI is built with Python 2.5 and will run on 2.6. There are reports
that it will not run on 2.7 without errors.
If you have installed a 3rd party Python (e.g., Macpython), it is likely
that you will run into trouble. Just removing the frameworks directory is
not enough, as the actual files are in /usr or /usr/local (I don't
remember which version ends up where) and there are path statements to
remove in several places. Also, wxPython can end up in or the other
versions for a variety of reasons. We package wxPython with the Mac GRASS
app, but that won't help the version mismatches if other Python versions
are installed.
