#1242: vector fills and line widths not displaying in latlon regions
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
GRASS trunk svn updated today (16 Dec. 2010). Symbol fills do not display
and changing line width has no effect. This all works fine in a non-latlon
region.
D_line_width() is not working in trunk for any projection type.
tested: d.vect, d.grid, d.northarrow
symbol fill color is not working with lat/lon locations in trunk + d.vect,
but it works ok in projected (spearfish) locations, and also from
d.northarrow both in lat/lon and projected loc'ns.
In lat/lon locations d.northarrow is showing horizontal duplication of
polyline-strings but not duplication of fill-areas for symbols. (I though
we fixed that bug a year or two ago?)
test region for this was not global or near the dateline.
Priority: critical | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: vector, display, d.vect | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
I would test that but I don't understand what to try and what should I
look for. Line width for vectors works for me (`d.vect`'s `width` option).
Running from GUI (with cairo driver I think).
Cpu: Unspecified |
Comment(by lucadelu):
Replying to [comment:5 cmbarton]:
> I just tested with GRASS 7.1 and it works fine on a set of points in a
latlon region.
> There is still a problem with north arrows, but I don't know if that is
related or not. The arrow now looks OK, but it is still double.
Tested with r62902 everything is working, could we close this ticket?
Cpu: Unspecified |
Replying to [comment:7 cmbarton]:
> Are the north arrows working? Last time I checked, they are still
rendering as multiples. I have not tested this update from yesterday
however.
> Michael
Yes, everything is working for me. Please see the attachment
