[GRASS-dev] [GRASS GIS] #1251: tweaking new feature in file selection drop-down of layer manager
Reporter: cmbarton | Owner: grass-dev@…
Component: Default | Version: svn-trunk
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
I originally thought this was a weird bug but it seems to be a new feature
that needs to be tweaked somewhat. Apparently, a new filtering function
has been added to the file selection drop down to make it easier to find
files in long lists within a mapset. This is a good thing in general. But
the filter is on all the time with no visual indication that it is active,
leading a user to think that his/her files have disappeared when editing
layer properties.
What happens is this:
When a layer is added, all files are displayed in the drop down list of
maps, but typing a few letters of a file name will make the drop down only
display files that begin with those letters.
But when editing a layer, the current file name is already in the
selection box and the drop down only displays that file. All other files
are invisible.
For filtering the display list in this way, it would be better to filter
by letters followed by an asterisk rather than just the letters (abc*
rather than abc). Then all files would display by default, but a filtered
list could be seen using a very standard designation.
Alternatively, typing letters would automatically scroll the list to the
first file with those letters (e.g., typing "abc" would automatically
scroll the list to "abcfile").
I'm setting this ticket to "enhancement", but many users may initially
think it is a bug.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251&gt;
     Type: defect | Status: new
      Cpu: Unspecified |
Changes (by cmbarton):
  * type: enhancement => defect
Comment:
Changing this to a bug. I found out that once a layer is displayed, you
can no longer change the map that is displayed in that layer. That is,
even if you delete the name of the map and pick a new one from the now
visible list, the new map selected is not displayed. The new filter
prevents any other map from being displayed.
This feature needs to be disabled until it is working correctly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:1&gt;
Priority: critical | Milestone: 7.0.0
      Cpu: Unspecified |
  * priority: normal => critical
Comment:
Bumping this up to critical. It affects all map selection, not just the
layer manager. You can no longer choose a file, run a module, choose a
different file and run the same module. You must close the module dialog
now to choose a different file.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:2&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
This filtering feature needs to be fixed in 6.5 too.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:3&gt;
Reporter: cmbarton | Owner: martinl
     Type: defect | Status: assigned
Priority: critical | Milestone: 6.4.1
Component: wxGUI | Version: svn-trunk
Keywords: map selection | Platform: Unspecified
      Cpu: Unspecified |
Changes (by martinl):
  * status: new => assigned
* cc: grass-dev@… (added)
  * component: Default => wxGUI
  * owner: grass-dev@… => martinl
  * milestone: 7.0.0 => 6.4.1
  * keywords: => map selection
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:4&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [ticket:1251 cmbarton]:
feature that needs to be tweaked somewhat. Apparently, a new filtering
function has been added to the file selection drop
Filtering map names has been implemented in r44638, besides
collapsing/expending mapset by left/right arrow. It was designed as the
first step to make selection widget usable for long list of maps.
> down to make it easier to find files in long lists within a mapset. This
is a good thing in general. But the filter is on all the time with no
visual indication that it is active, leading a user to think that his/her
files have disappeared when editing layer properties.
In r44715 is filtering disabled when item is found (on full match). The
widget should indicate that it offers only selection of items.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:5&gt;
      Cpu: Unspecified |
* cc: annakrat (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:6&gt;
      Cpu: Unspecified |
done by Anna, committed as r44725. Testing welcomed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: map selection
  Platform: Unspecified | Cpu: Unspecified
  * status: assigned => closed
  * resolution: => fixed
Comment:
Closing ticket, please reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:8&gt;
The bug I reported has indeed been fixed. Thanks much. I'm not sure
whether we want to keep this open as an enhancement request or not.
Testing on GRASS 7 (svn trunk updated 2 January 2011), the drop down
search feature works as follows on my Mac.
Click to display map list -> all maps are displayed and user can select
any map
Type something while map list is displayed -> nothing happens
Type something while map list is closed, then click to display map list ->
all maps are displayed and the selection indicator is located on a map
that begins with the same characters as those typed (if such a map
exists).
So AFAICT, there is no filtering, but there is an easy (if not obvious)
way to quickly move the selection cursor to a desired map in a long list.
Is this behaving the way it is supposed to behave?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:9&gt;
Comment(by annakrat):
Replying to [comment:9 cmbarton]:
Sorry, I tried to change this behaviour but unsuccessfully, there are some
problems with events. So it's necessary to close the popup to type
anything.
There are some other features you haven't described, you can display popup
with down arrow. Then it's possible to change selection with arrows, tab
changes selection to map (starting with typed letters) in the next mapset,
enter confirms the selection and closes the popup. Don't be surprised that
the action is performed after releasing the key (and not pressing down),
it's the same problem I mentioned before.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:10&gt;
  Priority: normal | Milestone: 6.4.1
  * priority: critical => normal
Comment:
I took the liberty to reopen the ticket and to downgrade the priority.
Thanks Anna.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:11&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: map selection
  * status: closed => reopened
  * resolution: fixed =>
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:12&gt;
Replying to [comment:10 annakrat]:
some problems with events. So it's necessary to close the popup to type
anything.
popup with down arrow. Then it's possible to change selection with arrows,
tab changes selection to map (starting with typed letters) in the next
mapset, enter confirms the selection and closes the popup. Don't be
surprised that the action is performed after releasing the key (and not
pressing down), it's the same problem I mentioned before.
> Anna
The features you mention do not work on my Mac.
The down arrow does open the popup, but arrows do not work after that. I
assume that the binding for opening the popup has trapped all arrow
function. Most people would probably like to have the arrows available to
move up and down the map list.
The tab key just switches back and forth between the entry box and the
page tabs at the top of the dialog.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:13&gt;
Replying to [comment:13 cmbarton]:
what's the current status of this bugreport?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:14&gt;
Replying to [comment:14 martinl]:
I've just fixed (at least I hope) the problem with not working arrows.
Still there are several problems: move up and down with the arrows is
working only for EVT_KEY_UP event and not EVT_KEY_DOWN (no idea why) and
you can't type when the popup window is shown. I am not able to fix these
issues now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:15&gt;
I just updated last night to r52468 for GRASS 7. I don't see any change in
the map selection control. Is this fixed in a later revision?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:16&gt;
Replying to [comment:16 cmbarton]:
in the map selection control. Is this fixed in a later revision?
Really r52468? Try e.g. svnversion to get the revision number. The changes
are done in r53320 (GRASS 7) and related backports in r53321, r53322.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:17&gt;
Actually I have r53317. Confusion with g.version. So I'll need to update
to test.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:18&gt;
* cc: grass-dev@… (removed)
* cc: martinl (added)
  * owner: martinl => grass-dev@…
  * status: reopened => new
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:19&gt;
