#1259: g.remove deletes raster maps by default: could delete the wrong map
Reporter: benducke | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: g.remove, raster, deletion | Platform: Unspecified
Cpu: Unspecified |
If I run g.remove with only the name of a non-existing
map, I get this:
g.remove tmp
Removing raster <tmp>
WARNING: Raster map <tmp> not found
WARNING: <tmp> nothing removed
This indicates that g.remove tries to remove a raster of
name "tmp" by default. I am not sure this is good behaviour.
What if the user meant a vector map and forgot to explicitely
type "vect=tmp". In such a case, the wrong map might get
deleted, instead of just an error message being issued.
Also, the synopsis for g.remove does not indicate that there
is a default removal type.
Cpu: Unspecified |
Comment(by martinl):
From ML
It's "default" behaviour. If the first argument doesn't contain an "="
character, it's assumed to be the value of the first registered
option.
This behaviour applies to all modules. Currently, there isn't any way
for individual commands to disable it without resorting to "hacks",
e.g. making the first option a dummy option (which would then show up
in the help output and manual page).
Cpu: Unspecified |
Comment(by wenzeslaus):
See and comment on #2414 (Replace g.list/g.remove with g.mlist/g.mremove)
which might solve this issue. This has to be solved before 7.0 because it
requires interface change.
