[GRASS-dev] [GRASS GIS] #126: v.outlier & sqlite
Reporter: dadudeman | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.2.3
Keywords: v.outlier sqlite |
When running v.outlier with sqlite.db, I encounter the following error.
DBMI-SQLite driver error:
Error in sqlite3_prepare():
no such table: Auxiliar_outlier_table
ERROR: Impossible to write in the database
Google revealed a page that identified the same problem with a solution.
http://lists.osgeo.org/pipermail/grass-user/2006-November/037304.html
When I increased the spline step parameter, it worked (or at least it ran
a while, I am unable to verify my results yet). I was unable to change my
region resolution, so I kept increasing the spline step until it would
run.
Ticket URL: <http://trac.osgeo.org/grass/ticket/126&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords: v.outlier sqlite
Comment (by dadudeman):
(I also tried this with GRASS 6.3RC6 and got the same error.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/126#comment:1&gt;
Comment (by neteler):
Can you please post an example? Eg based on the North Carolina dataset or
any other public data set?
Ticket URL: <http://trac.osgeo.org/grass/ticket/126#comment:2&gt;
      Type: defect | Status: closed
Component: Vector | Version: 6.2.3
Resolution: fixed | Keywords: v.outlier sqlite
  Platform: Unspecified | Cpu: Unspecified
Changes (by mmetz):
  * status: new => closed
  * platform: => Unspecified
  * resolution: => fixed
  * component: default => Vector
  * cpu: => Unspecified
Comment:
fixed in relbr6, devbr6 and trunk
Ticket URL: <https://trac.osgeo.org/grass/ticket/126#comment:3&gt;
