[GRASS-dev] [GRASS GIS] #1262: r.proj failing in GRASS 7
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Raster | Version: unspecified
Keywords: reprojection | Platform: MacOSX
      Cpu: OSX/Intel |
I just tried to reproject a raster from a UTM location into a latlon
location. After a silent failure in the GUI, I made a vector area in the
UTM location that matched the raster extents and reprojected it (v.proj)
into the latlon location. This worked. Then I set the region to match the
vector extents and tried to reproject the raster. I set the resolution to
match the source raster that I was trying to reproject. r.proj fails
immediately with the following seg fault error:
GRASS 7.0.svn (polengrass13):~ > r.proj input=h92_N-33-131-D
location=PolenUTM mapset=PERMANENT output=h92 resolution=0.000039682539683
Input Projection Parameters: +proj=tmerc +lat_0=0 +lon_0=19 +k=0.9993
+x_0=500000 +y_0=-5300000 +no_defs +a=6378137 +rf=298.257222101
+towgs84=0.000,0.000,0.000
Input Unit Factor: 1
Output Projection Parameters: +proj=longlat +a=6378137 +rf=298.257223563
+no_defs
Output Unit Factor: 1
Segmentation fault
I have not yet tried this in other dev versions, but I guess I'd better do
so.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262&gt;
      Cpu: OSX/Intel |
Comment(by cmbarton):
Same thing happens in GRASS 6.4.1. It also doesn't matter if I set the
resolution or not.
source location projection information (not a UTM, but a mercator):
zone: 0
datum: etrs89
ellipsoid: grs80
north: 516344.80163701
south: 497432.30163701
west: 380800.49568881
east: 398208.49568881
nsres: 4.25
ewres: 4.25
rows: 4450
cols: 4096
cells: 1822720
target location projection information:
projection: 3 (Latitude-Longitude)
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: wgs84
north: 52:30:12N
south: 52:19:48N
west: 17:14:36E
east: 17:30:21E
nsres: 0:00:03
ewres: 0:00:03
rows: 208
cols: 315
cells: 65520
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:1&gt;
#1262: r.proj broken in all dev versions
Priority: blocker | Milestone: 6.4.1
      Cpu: OSX/Intel |
Changes (by cmbarton):
  * priority: major => blocker
  * milestone: 7.0.0 => 6.4.1
Comment:
I've tested this and on the Mac at least r.proj is broken in all
development versions: 7.0, 6.5, and 6.4.1. Here is the result from testing
it on the North Carolina demo data set, trying to reproject from State
Plane into Latlon (same thing happens going the other way).
There is a segmentation fault and no map is reprojected.
r.proj input=aspect location=nc_spm_07 mapset=PERMANENT
Input Projection Parameters: +proj=lcc +lat_1=36.16666666666666
+lat_2=34.33333333333334 +lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0
+no_defs +a=6378137 +rf=298.257222101 +towgs84=0.000,0.000,0.000
+no_defs
Segmentation fault
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:2&gt;
      Cpu: OSX/Intel |
Comment(by mlennert):
Replying to [comment:2 cmbarton]:
+rf=298.257223563 +no_defs
> Segmentation fault
I've just tried to reproduce on Debian GNU/Linux using fairly recent
grass7 and grass65, but I don't get any segmentation fault and
reprojection works well.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:3&gt;
Keywords: r.proj, reprojection | Platform: MacOSX
      Cpu: OSX/Intel |
Changes (by martinl):
  * keywords: reprojection => r.proj, reprojection
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:4&gt;
      Cpu: OSX/Intel |
Comment(by neteler):
> Segmentation fault
Michael, please use a debugger and add the backtrace to the ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:5&gt;
      Cpu: OSX/Intel |
Comment(by martinl):
Replying to [comment:5 neteler]:
I can confirm that it's working on Linux. Some debug info is needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:6&gt;
      Cpu: OSX/Intel |
Here is the gdb results for r.proj
GRASS 6.4.1svn (nc_ll):~ > gdb `which r.proj`
GNU gdb 6.3.50-20050815 (Apple version gdb-1510) (Wed Sep 22 02:45:02 UTC
2010)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for
details.
This GDB was configured as "x86_64-apple-darwin"...Reading symbols for
shared libraries ......
warning: Could not find object file
"/Users/Shared/src/gdal/gdal-1.7.1/frmts/o/.libs/wktrasterdataset.o" - no
debug information available for "wktrasterdataset.cpp".
"/Users/Shared/src/gdal/gdal-1.7.1/frmts/o/.libs/wktrasterrasterband.o" -
no debug information available for "wktrasterrasterband.cpp".
"/Users/Shared/src/gdal/gdal-1.7.1/frmts/o/.libs/wktrasterwrapper.o" - no
debug information available for "wktrasterwrapper.cpp".
.. done
(gdb) run input=aspect location=nc_spm_07 mapset=PERMANENT
Starting program:
/Users/Shared/grass_dev/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/bin/r.proj
Reading symbols for shared libraries
done
+no_defs
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_INVALID_ADDRESS at address: 0x0000000000000000
0x00007fff80f94f2f in __vfprintf ()
(gdb) bt full
#0 0x00007fff80f94f2f in __vfprintf ()
No symbol table info available.
#1 0x00007fff80fc9b17 in vsnprintf ()
#2 0x00007fff8100a4da in __vsprintf_chk ()
#3 0x0000000100020f7d in print_error [inlined] () at
/Users/Shared/grass_dev/grass64_rb/lib/gis/error.c:61
         buffer = "\020\035?\001\001\000\000\000@?
p?\000\000?¿_?\000\000&\022???\000\000\000\000\000\000l??\000\000\000\000\000\000\000?¿_?\000\000@u???\000\000\000Ŀ_?\000\000\000Ŀ_?\000\000\000Ŀ_?\000\000\000Ŀ_?\000\000?Ŀ_?\000\000@?
p?\000\000?Ŀ_?\000\000?U\037p?\000\000?Ŀ_?\000\000h?\003\000\001\000\000\000?$?HZ\f???=\032??ā???\000\000\000\000\000\000\000\000??\bN???,??0j\037p?\000\000??\036O??P?"...
#4 0x0000000100020f7d in vfprint_error (type=0, template=<value
temporarily unavailable, due to optimizations>, ap=<value temporarily
unavailable, due to optimizations>) at error.c:64
         format = 1606392479
         type = Cannot access memory at address 0x0
(gdb) l
67 {p_nearest, "nearest", "nearest neighbor"},
68 {p_bilinear, "bilinear", "bilinear"},
69 {p_cubic, "cubic", "cubic convolution"},
70 {NULL, NULL, NULL}
71 };
72
73 static char *make_ipol_list(void);
74
75 int main(int argc, char **argv)
76 {
(gdb) frame 2
(gdb) l
77 char *mapname, /* ptr to name of output layer */
78 *setname, /* ptr to name of input mapset */
79 *ipolname; /* name of interpolation method */
80
81 int fdi, /* input map file descriptor */
82 fdo, /* output map file descriptor */
83 method, /* position of method in table */
84 permissions, /* mapset permissions */
85 cell_type, /* output celltype */
86 cell_size, /* size of a cell in bytes */
(gdb)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:7&gt;
      Cpu: OSX/Intel |
Note that I am running this on the same system where I compiled it with no
errors, using William Kyngesburye's Mac frameworks.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:8&gt;
      Cpu: OSX/Intel |
Replying to [comment:7 cmbarton]:
> (gdb) bt full
> format = 1606392479
Any idea? This bug is marked as a blocker for 6.4.1...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:9&gt;
      Cpu: OSX/Intel |
All I know is that this is relatively new, affects all dev versions, and
shows up on other computers beyond mine. It may not affect Linux versions.
I don't know about Windows. r.proj is a key, core module. I don't think we
should release a new version of GRASS where this is non-functional. I'm
afraid that I don't know what the problem is. I'd hoped that the debug
code would help someone with with knowledge of C. I'm happy to test
potential fixes.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:10&gt;
      Cpu: OSX/Intel |
Comment(by marisn):
If backtraces involve suspicious memory addresses (0x0 etc.), it's
necessary to run program under valrgind to look for possible memory
corruption or pointer abuse.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:11&gt;
      Cpu: OSX/Intel |
Comment(by mmetz):
Replying to [comment:11 marisn]:
Good hint. The segfault happened when printing a message, also on Windows,
not on Linux.
Should be fixed in r45195, r45196, r45197 (6.4, 6.5, 7.0).
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:12&gt;
      Cpu: OSX/Intel |
Replying to [comment:12 mmetz]:
Windows, not on Linux.
> Markus M
Thanks much. I'll test in the next day or so.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:13&gt;
      Cpu: OSX/Intel |
I just did an updated from the svn trunk (after a make distclean). This
has changed the results and error, but has not corrected the problem. Just
to be sure that there is nothing weird with the map, here is what I did. I
opened the NC_spm_07 dataset and set the region to match the
elev_state_500m dem. Then I tried to reproject into the state plane region
the 1 arc second dem from the nc_ll location. I set debug=5 and here is
the result.
GRASS 7.0.svn (nc_spm_07):~ > g.gisenv set="DEBUG=5"
GRASS 7.0.svn (nc_spm_07):~ > r.proj input=elev_ned_1arcsec location=nc_ll
mapset=PERMANENT output=elev_ned_1arcsec
D1/5: G_find_raster(): name=elev_ned_1arcsec mapset=user1
D2/5: G__read_Cell_head
D2/5: G__read_Cell_head_array
D3/5: region item: proj: 99
D3/5: region item: zone: 0
D3/5: region item: north: 318500
D3/5: region item: south: -16000
D3/5: region item: east: 963000
D3/5: region item: west: 124000
D3/5: region item: cols: 1678
D3/5: region item: rows: 669
D3/5: region item: e-w resol: 500
D3/5: region item: n-s resol: 500
D3/5: region item: top: 1
D3/5: region item: bottom: 0
D3/5: region item: cols3: 1678
D3/5: region item: rows3: 669
D3/5: region item: depths: 1
D3/5: region item: e-w resol3: 500
D3/5: region item: n-s resol3: 500
D3/5: region item: t-b resol: 1
D1/5: G_find_raster(): name=elev_ned_1arcsec mapset=PERMANENT
D1/5: G_find_raster2(): name=elev_ned_1arcsec mapset=PERMANENT
D5/5: color buf = [0% yellow]
D5/5: color buf = [20% green]
D5/5: color buf = [40% cyan]
D5/5: color buf = [60% blue]
D5/5: color buf = [80% magenta]
D5/5: color buf = [100% red]
Input Projection Parameters: +proj=longlat +a=6378137 +rf=298.257223563
+no_defs
Output Projection Parameters: +proj=lcc +lat_1=36.16666666666666
D3/5: region item: proj: 3
D3/5: region item: north: 35:54:41.000547N
D3/5: region item: south: 35:35:17.001098N
D3/5: region item: east: 78:27:08.000616W
D3/5: region item: west: 78:49:17.999987W
D3/5: region item: cols: 1330
D3/5: region item: rows: 1164
D3/5: region item: e-w resol: 0:00:01
D3/5: region item: n-s resol: 0:00:01
D3/5: region item: format: -1
D3/5: region item: compressed: 1
D3/5: G_adjust_Cell_head: epsilon_ns: 8.59107e-07, epsilon_ew: 1e-06
D1/5: G_find_raster(): name=MASK mapset=user1
D3/5: Top: xmin: -78.452221; xmax: -78.821668; ymin: 35.911390; ymax:
35.588055
D3/5: Right: xmin: -78.452221; xmax: -78.821668; ymin: 35.911390; ymax:
35.588055
D3/5: Bottom: xmin: -78.452221; xmax: -78.821668; ymin: 35.911390; ymax:
35.588055
D3/5: Left: xmin: -78.452221; xmax: -78.821668; ymin: 35.911390; ymax:
35.588055
D3/5: Extra check: xmin: -78.821528; xmax: -78.452361; ymin: 35.588195;
ymax: 35.911250
D3/5: Final check: xmin: -78.821667; xmax: -78.452222; ymin: 35.588056;
ymax: 35.911389
D3/5: Top: xmin: 625709.948811; xmax: 659030.331786; ymin: 239768.184363;
ymax: 239890.045778
D3/5: Right: xmin: 625709.948811; xmax: 659228.054367; ymin:
204049.351740; ymax: 239890.045778
D3/5: Bottom: xmin: 625709.948811; xmax: 659228.054367; ymin:
203927.002865; ymax: 239890.045778
D3/5: Left: xmin: 625709.948811; xmax: 659228.054367; ymin: 203927.002865;
ymax: 239890.045778
D3/5: Extra check: xmin: 625709.948811; xmax: 659228.054367; ymin:
D3/5: Final check: xmin: 625500.000000; xmax: 659500.000000; ymin:
203500.000000; ymax: 240000.000000
Segmentation fault
I can run a shell debugger on this again if needed.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:14&gt;
      Cpu: OSX/Intel |
Comment(by marisn):
Replying to [comment:14 cmbarton]:
tl;dr
valgrind!
Works just fine on my AMD64 Linux.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:15&gt;
      Cpu: OSX/Intel |
For valgrind usage, see
http://grass.osgeo.org/wiki/GRASS_Debugging#Using_Valgrind
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:16&gt;
      Cpu: OSX/Intel |
Replying to [comment:15 marisn]:
> tl;dr
> valgrind!
Are these shell commands? The don't work as typed in my terminal.
We know that it works on Linux. It is broken for Mac and Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:17&gt;
      Cpu: OSX/Intel |
Looks like valgrind does not come on my Mac by default. I'll have to find
instructions and time to compile this. If anyone using a Mac already has
it, it might be faster if they tried to run this. I can post a GRASS
binary to try.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:18&gt;
      Cpu: OSX/Intel |
Here are instructions to compile it which may be helpful:
http://stackoverflow.com/questions/2285964/how-can-i-compile-valgrind-on-
snow-leopard
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:19&gt;
