#1266: d.vect has problems
Reporter: akbgf | Owner: grass-dev@…
Type: defect | Status: new
Component: Display | Version: svn-trunk
Keywords: d.vect | Platform: Linux
Cpu: x86-32 |
Hi!
If using any selection option of d.vect (the list of category values or
the where condition) GRASS-7.0 does not display the vector. The problem
was in r45123 and is still there in r45168.
If I start with no selection option except feature type selection, vectors
are displayed. If I turn on a selection option of a vector - either the
category list or the where condition, the vector is not displayed, other
vectors are visible. After turning off the selection option, the vector is
still non-visible. I tried to turn the vector on and off in the Layer
Manager window and re-render map display - no effect. The vector is still
there - I see the info of vector elements using v.what, however the vector
is non-visible. I tested this problem on three different vectors having
only areas, only lines, and only points.
An early version of GRASS-7 (of Dec 15 or 16, I guess) does not have this
problem.
Andres Kuusk, Tartu Observatory, Estonia
Ticket URL: <http://trac.osgeo.org/grass/ticket/1266>
