[GRASS-dev] [GRASS GIS] #1270: Error in Attribute Table Manager
Reporter: antonioall | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Database | Version: 6.4.1 RCs
Keywords: | Platform: MSWindows Vista
      Cpu: x86-64 |
If I add columns to the database of a coverage in "Attribute Table
Manager" and I modify a value in these columns, Grass shows a message of
error (you see attached image) and it doesn't memorize the value.
Thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270&gt;
      Cpu: x86-32 |
Changes (by antonioall):
  * cpu: x86-64 => x86-32
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:1&gt;
Keywords: wingrass | Platform: MSWindows Vista
      Cpu: x86-32 |
Changes (by hellik):
  * keywords: => wingrass
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:2&gt;
Priority: critical | Milestone: 6.4.2
Component: wxGUI | Version: svn-develbranch6
Keywords: wingrass, attribute table manager | Platform: MSWindows Vista
      Cpu: x86-32 |
Changes (by hamish):
  * keywords: wingrass => wingrass, attribute table manager
  * priority: normal => critical
  * version: 6.4.1 RCs => svn-develbranch6
  * component: Database => wxGUI
  * milestone: 6.4.1 => 6.4.2
Comment:
I can reproduce this in 6.5svn nightly build on Windows XP.
steps as described in the orig report, add a new vector column, edit a
row, hit submit.
error is now:
Error:
c:\docume~1\hamish\locals~1\temp\tmpuelgf4: Permission denied
exiting & restarting grass doesn't help, nor does rebooting. (there's not
zombie dbf.exe afterwards either)
same error if I try to add a new row or delete and old one.
... so it is generally impossible to edit using the attribute table
manager in wingrass?! (bumping priority)
suspect the attribute manager is holding the temp file open..
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:3&gt;
#1270: wingrass: Error in Attribute Table Manager
      Cpu: x86-32 |
Comment(by hamish):
maybe this program helps: (lsof for Windows)
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs
/en-us/openfiles.mspx
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:4&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:3 hamish]:
> Hi,
confirmed
but map display -> query raster/vector layer -> click on an activated
vector layer feature -> a little windows for updating attributes pops up
there you can edit successfully the attribute for the selected feature.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:5&gt;
      Cpu: x86-32 |
Comment(by hamish):
suggest to apply this patch to 6.4svn until a solution is found:
Index: gui/wxpython/gui_modules/dbm.py
--- gui/wxpython/gui_modules/dbm.py (revision 50681)
+++ gui/wxpython/gui_modules/dbm.py (working copy)
@@ -546,7 +546,11 @@
              self.editable = True
          else:
              self.editable = False
+ # FIXME: editing is currently broken on wingrass (bug #1270)
+ if sys.platform == 'win32':
+ self.editable = False
          self.cmdLog = log # self.parent.goutput
          wx.Frame.__init__(self, parent, id, style=style)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:6&gt;
      Cpu: x86-32 |
Comment(by hamish):
patch applied in relbr64 in r50701. please test!
sys.platform for Cygwin = cygwin not win32, so it should still work from
there.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:7&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:7 hamish]:
tested with
osgeo4w-wingrass6.4.3svn r52715
osgeo4w-wingrass6.5svn r52495
error pop up still there.
without any problem.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:8&gt;
      Cpu: x86-32 |
Comment(by mlennert):
> Hi,
row, hit submit.
> error is now:
> Error:
Working with a student yesterday, I saw a similar error trying to add a
new column.
We were trying to digitize, so I thought it was because the table was open
for the digitization, but even when we ended that, no way to add a new
column.
Even calling v.db.addcol ended in an error. This all happened in a hurry,
so I don't have the exact errors and cannot reproduce right now. Anyone
can confirm that this also happens when you try to add a column ? This was
with a grass6.4.3svn install (don't have the revision number).
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:9&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:9 mlennert]:
> > Hi,
row, hit submit.
> > error is now:
> > Error:
new column.
still there by editing within the table manager, but not by querying the
vector in the map display and changing a table value there.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:10&gt;
Priority: critical | Milestone: 6.4.4
      Cpu: x86-32 |
  * milestone: 6.4.2 => 6.4.4
Comment:
editing the table on WinGrass was greyed-out in the release branch by
r50701, but that was lost in a bulk backport. The patch from comment:6 is
now reapplied with r55016. It doesn't do anything to fix the problem, but
makes it not-release critical since the user won't encounter breakage.
Leaving broken in the release branches in hope of a real fix one day;
severity of ticket can be lowered after some testing.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:11&gt;
Priority: blocker | Milestone: 6.4.3
      Cpu: x86-32 |
Changes (by neteler):
  * priority: critical => blocker
  * milestone: 6.4.4 => 6.4.3
Comment:
I guess that http://trac.osgeo.org/grass/changeset/55106 will now
block any testing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:12&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:12 neteler]:
> block any testing.
yes.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:13&gt;
      Cpu: x86-32 |
Comment(by hellik):
v.db.addcol works here (latest osgeo4w-nightly build)
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:14&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:8 hellik]:
still working this way...
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:15&gt;
      Cpu: x86-32 |
Comment(by hamish):
> block any testing.
not really, just use devbr6 for testing, or open up dbmgr/manager.py in
notepad++ or TextPad or whatever favourite text editor under Windows and
comment-out the comment-out. The idea of r55106 is to have relbr64 ready
for release now, and to continue the debugging in the dev branches. aka
this doesn't look like it is being resolved in a hurry, and if we leave it
blocking 6.4.3 then the release may take a long time.
is there a wxPy way to grey-out entire tabs? the manage tables and manage
layers tabs don't give much feedback that they're disabled beyond "(read-
only)" in the window title super-tab. the connection info may still be
interesting to see, so fully blocking access to reading what's there
wouldn't be the ideal way to do that.. ?
with the r55185-512 6.4.3svn nightly build on Windows7 64bit running the
desktop icon wxGUI, I still get an error. Actually it froze with an
endless spinning circle hourglass thing when I tried to add a column in
the "show attribute data" manage tables tab, with the cursor over any of
the open grass windows. I had to kill it by clicking on the "X" in the
window, which took out all of grass except a zombie dbf.exe in the task
manager + the empty cmd.exe dosbox.
moreover, using v.db.addcol from the main db -> vect db conns menu to add
a column had this error:
v.db.addcol --verbose map=copyofbugs2@user1 columns=someint2 integer
DBMI-DBF driver error:
ERROR: Unable to open database <C:/Program Files (x86)/GRASS GIS
6.4.3svn/msys/Users/Hamish/Documents/GIS DataBase/spearfish60/user1/dbf/>
ERROR: Cannot continue (problem adding column).
Somehow ProgramFiles....msys (GISBASE) is sneaking into the GISDBASE. ??
and again there's a dbf.exe zombie in the task manager, so when you try to
quit the empty dos box lurking in the background won't exit without a `^C`
in it or to kill the dbf.exe in the task manager. No lockup this way
though.
running v.db.connect from the same menu has everything looking as it
should be:
v.db.connect -p map=copyofbugs2@user1
layer <1> table <copyofbugs2> in database </Users/Hamish/Documents/GIS
DataBase\spearfish60\user1\dbf\> through driver <dbf> with key <cat>
Vector map <copyofbugs2@user1> is connected by:
well, everything except the order of stderr and stdout, but I can forgive
that.
On a hunch I tried dragging a file into the dbf/ folder directly, but it
complied and didn't request that I do that as admin.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:16&gt;
      Cpu: x86-32 |
Comment(by neteler):
Replying to [comment:16 hamish]:
> > block any testing.
... as per previous discussions (see ML archive) I doubt that devbr6
receives reasonable testing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:17&gt;
      Cpu: x86-32 |
Comment(by hellik):
tested with
System Info
GRASS version: 6.5.svn
GRASS SVN Revision: 55167
GIS Library Revision: 50936 (2012-02-25)
GDAL/OGR: 1.9.2
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
yes, it seems so.
the temp file is in C:\Users\xxxxxxx\AppData\Local\Temp, the file's
content is the sql update command, e.g.
UPDATE myhosp SET testc=2 WHERE cat=1;
any idea how to close the temp file?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:18&gt;
      Cpu: x86-32 |
Comment(by hellik):
add a column had this error:
tested with
GRASS version: 6.4.3svn
GRASS SVN Revision: 55185
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.9.2
Python: 2.7.2
wxPython: 2.8.12.1
v.db.addcol map=myfires@user1 columns=someint2 integer
(Mon Feb 25 21:05:23 2013) Command finished (2 sec)
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:19&gt;
