GDAL
February 7, 2011, 8:18pm
1
#1275: HGT Import
Reporter: MartinOver | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: 6.4.0
Keywords: HGT Import | Platform: MSWindows XP
Cpu: x86-32 |
The import of srtm .hgt raster data is not working.
unzip: unknown command
ERROR: The "unzip" program is required, please install it first
Ticket URL: <http://trac.osgeo.org/grass/ticket/1275> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
February 7, 2011, 8:27pm
2
#1275: HGT Import
Component: Packaging | Version: 6.4.0
Keywords: unzip missing on Win (r.in.srtm req) | Platform: MSWindows XP
Cpu: All |
Changes (by msieczka):
* keywords: HGT Import => unzip missing on Win (r.in.srtm req)
* component: Default => Packaging
* cpu: x86-32 => All
Ticket URL: <http://trac.osgeo.org/grass/ticket/1275#comment:1> ;
GDAL
February 8, 2011, 1:01am
3
#1275: HGT Import
Keywords: r.in.srtm, wingrass | Platform: MSWindows XP
Cpu: All |
Changes (by hamish):
* keywords: unzip missing on Win (r.in.srtm req) => r.in.srtm, wingrass
Comment:
is this the standalone installer or installed by osgeo4w?
easy work around: unzip it yourself before running the program.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:2> ;
GDAL
March 4, 2011, 1:25pm
4
#1275: HGT Import
Cpu: All |
Comment(by martinover):
Replying to [comment:2 hamish]:
> Hamish
Hi Hamish,
It is in both the standalone and osgeo4w installation.
The workaround does not work but I converted the hgt files via
gdal_translate to GTiffs.
The Problem is that I can import the Data in the standalone installation
but can not export the dataset (empty image) or work with the dataset (for
example wirth the raster calculator). In the osgeo4w installation I can´t
even import the dataset.
Is it possible for you to import and export the hgt files:
http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/Eurasia/
I tried both linux and windows systems.
Best regards,
Martin Over
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:3> ;
GDAL
March 5, 2011, 6:27am
5
#1275: HGT Import
Cpu: All |
Comment(by hamish):
Replying to [comment:3 martinover]:
I am a bit surprised by that, it should.
> installation but can not export the dataset (empty image) or
> work with the dataset (for example wirth the raster calculator).
after import you need to change the working ("computational") region to
match the bounds of the map. Run "g.region rast=your_map".
> In the osgeo4w installation I can´t even import the dataset.
exact error messages are needed. (assuming it's not the same unzip one,
which should only be shown if you feed it a .zip file)
> hgt files: http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/Eurasia/
(todo)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:4> ;
GDAL
April 17, 2011, 6:08pm
6
#1275: HGT Import
Cpu: All |
Comment(by neteler):
I imported such files yesterday with 6.4.1 on Linux, no problems occured.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1275#comment:5> ;
GDAL
July 29, 2011, 11:19am
7
#1275: HGT Import
Cpu: All |
Replying to [ticket:1275 MartinOver]:
I have found it here:
http://sourceforge.net/projects/mingw/files/MSYS/unzip/
Probably it would be an idea to copy it from the MSYS builder and add it
to the winGRASS package?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:6> ;
GDAL
January 17, 2012, 9:48am
8
#1275: zipped HGT Import fails on wingrass as "unzip" isn't in the package
Priority: normal | Milestone: 6.4.3
Cpu: All |
* milestone: 6.4.1 => 6.4.3
Comment:
6.4.2rc3 native wingrass installer still does not ship "unzip".
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:7> ;
GDAL
August 20, 2012, 10:09pm
9
Cpu: All |
Strangely no "unzip" in http://download.osgeo.org/osgeo4w/versions.html -
could
http://sourceforge.net/projects/mingw/files/MSYS/Extension/zip/ be
packaged?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1275#comment:8> ;
GDAL
March 31, 2013, 7:14pm
10
Component: Packaging | Version: svn-releasebranch64
Cpu: All |
Changes (by neteler):
* version: 6.4.0 => svn-releasebranch64
Comment:
An "easy" solution would be to add the "zip" package
http://sourceforge.net/projects/gnuwin32/files/zip/
to the MSYS package:
http://trac.osgeo.org/osgeo4w/wiki/pkg-msys
Ticket URL: <http://trac.osgeo.org/grass/ticket/1275#comment:9> ;
GDAL
April 13, 2013, 11:35am
11
Cpu: All |
Comment(by martinl):
Replying to [comment:9 neteler]:
done for `msys-1.0.11-11` (1)
(1) http://trac.osgeo.org/osgeo4w/wiki/pkg-msys#Extrapackages
Ticket URL: <http://trac.osgeo.org/grass/ticket/1275#comment:10> ;
GDAL
April 13, 2013, 11:40am
12
Cpu: All |
Replying to [comment:10 martinl]:
such tools like zip and others should go probably to the new package
(`msys-tools` or `msys-extra`)
http://trac.osgeo.org/osgeo4w/wiki/pkg-msys#TODO
Ticket URL: <http://trac.osgeo.org/grass/ticket/1275#comment:11> ;
GDAL
May 2, 2013, 9:16am
13
Keywords: r.in.srtm, wingrass, unzip | Platform: MSWindows XP
Cpu: All |
* keywords: r.in.srtm, wingrass => r.in.srtm, wingrass, unzip
Comment:
latest nightly wingrass installers still not shipping `unzip.exe` in
extrabin or msys/bin.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:12> ;
GDAL
May 25, 2013, 10:28am
14
Cpu: All |
See also ticket #1952
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:13> ;
GDAL
June 6, 2013, 12:31pm
15
Cpu: All |
Comment(by hamish):
* http://trac.osgeo.org/osgeo4w/wiki/pkg-msys
* http://lists.osgeo.org/pipermail/grass-dev/2013-June/064214.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:14> ;
GDAL
July 23, 2013, 9:31am
16
Cpu: All |
Comment(by hellik):
unzip [1] seems to be needed to close this ticket.
[1] http://gnuwin32.sourceforge.net/packages/unzip.htm
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:15> ;
GDAL
July 28, 2013, 8:34am
17
Cpu: All |
Replying to [comment:15 hellik]:
I have added `unzip` into `msys` package in `1.0.18-4` (1)
(1) http://trac.osgeo.org/osgeo4w/wiki/pkg-msys#Majorchanges
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:16> ;
GDAL
January 10, 2014, 7:14pm
18
Cpu: All |
Can the ticket be closed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:17> ;
GDAL
January 11, 2014, 6:48pm
19
Type: defect | Status: closed
Resolution: fixed | Keywords: r.in.srtm, wingrass, unzip
Platform: MSWindows XP | Cpu: All
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:17 neteler]:
unzip available. closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:18> ;
