[GRASS-dev] [GRASS GIS] #1276: r.null in winGRASS does not work properly
Reporter: helena | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Raster | Version: 6.4.1 RCs
Keywords: null | Platform: MSWindows 7
      Cpu: Unspecified |
in the following example, when run in WinGRASS in command console
g.region swwake_30m -p
v.to.rast streets_wake out=streets_speed use=attr col=SPEED
r.null streets_speed null=5
the null values get replaced by 0 instead of 5. The example works OK on
Mac and linux.
This was tried independently on several Windows 7 machines, always
producing wrong result.
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/1276&gt;
Keywords: r.null, wingrass | Platform: MSWindows 7
      Cpu: Unspecified |
Changes (by hamish):
  * keywords: null => r.null, wingrass
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:1&gt;
Priority: normal | Milestone: 6.4.2
      Cpu: Unspecified |
  * milestone: 6.4.1 => 6.4.2
Comment:
bug still present in wingrass 6.4.svn r48373 (Sept 2011), tested on
Windows XP.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:2&gt;
      Cpu: Unspecified |
Comment(by hamish):
bug still present in wingrass 6.4.2rc3, tested on Windows XP.
very weird.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:3&gt;
Priority: critical | Milestone: 6.4.2
      Cpu: Unspecified |
Changes (by martinl):
  * priority: normal => critical
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:4&gt;
      Cpu: Unspecified |
Comment(by hamish):
a debug message I threw into devbr6 shows that the "5" was making it into
the variable ok.
if you convert streets_speed to a DCELL map from a CELL map:
   r.mapcalc "streets_speed.DCELL = double(streets_speed)"
then r.null works as expected.
I strongly suspect the trouble is on this line of r.null/mask.c:
   if (change_null && G_is_null_value(rast, data_type))
         G_set_raster_value_d(rast, new_null, data_type);
new_null is always sent as DCELL, but data_type changes.
(n.b. for CELL maps the command line value for new_null is laundered into
something CELL compatible by main.c when it is first read in, but only if
you enter a non-integer for null=)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:5&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:5 hamish]:
That isn't a problem; as the _d suffix indicates, the source value is
always DCELL; data_type indicates the type of the destination. The whole
point of G_{get,set}_raster_value_{c,f,d} is to convert values between a
type which is fixed at compile time and a type which is only known at run
time.
My suspicion is that the null bitmap is being updated but the cell/fcell
file isn't. Null values always have a zero stored in the cell/fcell file,
so clearing the null bitmap without updating the cell/fcell file will
replace nulls with zeros. If this is the case, it should be
straightforward to confirm it by checking the timestamps on the files.
That this only happens on Windows suggests that it may be related to
Windows' different filesystem semantics (e.g. not being able to
rename/remove open files). Also, r.null is unusual in that it opens the
same map for both reading and writing. It does close the input map before
the output map.
If it only happens on Windows 7 and Vista (but not XP): is GISDBASE in a
directory which is !VirtualStore'd (e.g. Program Files)? That could
potentially cause these exact symptoms. The null bitmap is modified in-
place, but the cell/fcell files are generated in the temporary directory
then rename()d over the original file when closed. This might result in
the new cell/fcell file being silently redirected to the !VirtualStore
directory (%LOCALAPPDATA%\!VirtualStore); although I don't know why it
wouldn't then be read instead of the original file.
Also, I notice that close_new() (in lib/gis/closecell.c) doesn't examine
the return codes from either close() or remove(); it may be worth checking
those.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:6&gt;
      Cpu: Unspecified |
Comment(by hamish):
when testing this (in XP, where it fails too), to reset the map-to-
be-r.null'd I had been rerunning with the overwrite flag:
v.to.rast streets_wake out=streets_speed use=attr col=SPEED --o
it happened that I got an error that it could not move the created map
from .tmp/ into the main mapset dir, presumably because some part of it
was still an open file. I though to save that for another bug report as it
seemed to only happen the 4th or 5th time overwriting it, but maybe it is
relevant or a sign some more general problem.
Hamish
(offline/in the field until next week or so)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:7&gt;
      Cpu: Unspecified |
Comment(by hamish):
> presumably because some part of it was still an open file.
ie I'd guess the map to be overwritten was still open, as the PID in the
.tmp file changed but the error persisted once it started.
H
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:8&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:7 hamish]:
That may be a separate issue. Vector commands often access a database for
attributes, which means spawning a DBMI driver. There have been problems
on Windows which might have been caused by the DBMI driver inheriting a
descriptor from the parent, keeping the file open.
That isn't applicable to r.null, which doesn't spawn any child processes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:9&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:6 glynn]:
file,
From the timestamps (and r.info showing the correct range) I can confirm
that cell_misc/$MAP/null and cell_misc/$MAP/range are updated when running
r.null on Windows XP, but cell/$MAP's timestamp is not updated.
before
> the output map.
> checking those.
done in r50404 in devbr6.
bug: close(fd) is called twice, (??)
https://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/lib/gis/closecell.c#L287
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:10&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:10 hamish]:
AFAICT, the only way for G_close_cell() to not delete that file and not
print a warning is if G__open_null_write() fails at line 207. But that
should result in the null file not being updated (contrary to my previous
comment, the null file isn't updated in-place; it's handled the same way
as the cell/fcell file).
Otherwise, it should attempt to rename the file, and any failure should
generate a warning. There aren't any return statements in close_new()
between renaming the null file and renaming the cell/fcell file, so I
don't know how this situation can arise.
The first one (line 288) should be removed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:11&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:9 glynn]:
examine
> > checking those.
hmmm, now r.to.vect (and r.circle, and probably many others) reports a
bunch of problems, even on linux:
WARNING: Unable to delete prior null-cells file
WARNING: Unable to delete the temporary null-cells file
WARNING: Unable to delete prior 'fcell' file
WARNING: Unable to delete the f_format file
WARNING: Unable to delete the prior 'cell' file
WARNING: Unable to delete the temporary 'cell' file
WARNING: Unable to delete the f_quant file
but no such warnings appear when running r.null on the latest nightly
build of 6.5svn on Windows XP. (& problem persists)
> and not print a warning is if `G__open_null_write()` fails at line
> 207.
aside:
             null_fd = G__open_null_write(fd);
             if (null_fd <= 0)
                 return -1;
             if (null_fd < 1)
                 return -1;
(`G__open_null_write()` returns -1 on failure otherwise a new fd for the
null file)
more needless duplication. I'm getting the idea that there may be more
sloppy code in this file..
fixed in devbr6.
> should generate a warning. There aren't any return statements in
> close_new() between renaming the null file and renaming the
> cell/fcell file, so I don't know how this situation can arise.
maybe this part of the code isn't being entered:
if (ok && (fcb->temp_name != NULL)) {
? I've added some more debug messages, we'll see what they have to say.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:12&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:12 hamish]:
These are likely a consequence of the original files not existing.
Any previous null, cell or fcell file is always removed prior to renaming
the temporary file into place (on Windows, rename() fails if the
destination exists). When writing a new map (rather than replacing an
existing map), these files won't exist.
When writing an integer map, any existing fcell, f_format or f_quant file
is removed. If it isn't replacing an existing map, or the existing map was
an integer map, these files won't exist.
These probably arise from trying to remove the temporary file after
renaming has succeeded. Those remove() calls should either be removed, or
moved to the other branch of the conditional (i.e. if rename() fails,
remove() the file instead).
However: the first one can also occur if the temporary null file is empty
(which indicates an error writing the raster data).
Not sure how that could happen. "ok" is true for G_close_cell() and false
for G_unopen_cell(). r.null only calls G_unopen_cell() if the loop is
terminated prematurely, in which case it prints a warning. fcb->tempname
is set to the result of G_tempfile(), which is never null. The assignment
is unconditional, and G!__open_raster_new() never returns prematurely
without generating a warning.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:13&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:13 glynn]:
> to renaming the temporary file into place (on Windows, rename()
> fails if the destination exists). When writing a new map (rather
> than replacing an existing map), these files won't exist.
> f_quant file is removed. If it isn't replacing an existing map,
> or the existing map was an integer map, these files won't exist.
> after renaming has succeeded. Those remove() calls should either
> be removed, or moved to the other branch of the conditional (i.e.
> if rename() fails, remove() the file instead).
> is empty (which indicates an error writing the raster data).
rather than just adding a only-remove if it exists (using e.g. stat())
which may hide an error, it will be better to use the branch conditionals.
(more work, but worth it)
ok, the annoyance of seeing those warnings all the time will be motivating
for the task..
the new debug message inside that conditional confirms that it is getting
into there, so it's not that.
trying 'v.to.rast --overwrite' to replace the cell/ file still gives me
problems:
WARNING: Unable to delete prior 'cell' file ## (!! but it exists)
WARNING: closecell: can't move [C:/Documents and Settings/User/My
   Documents/.../.tmp/1612.0] to cell file [.../cell/streets_speed]
I wonder if the reason it can't remove the prior 'cell' file and r.null
failing are the same. (but why no error message from r.null in that case?)
... next step will be to add 'errno' reporting to the failed remove()
prior 'cell' file message while rerunning v.to.rast with --overwrite.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:14&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:14 hamish]:
> remove() prior 'cell' file message while rerunning v.to.rast
> with --overwrite.
ok, with `perror(path)` in place I see `.../cell/mapname: Permission
denied.` Checking in the Windows Task Manager I see that a leftover
dbf.exe and cmd.exe are still running after v.to.rast has finished.
If I kill the dbf.exe the cmd.exe goes away too, then r.null seems to
work. I'm not sure why dbf.exe would have the cell file open, I guess it
is actually the residual cmd.exe which is doing that. (?)
Interestingly with r.null I just get the perror() message but not the
G_warning() from the failed remove(). !?
we saw this same zombie dbf.exe problem before in #1184. In that case
Martin discovered `db_close_database_shutdown_driver()` wasn't called. It
looks like v.to.rast has the same problem: hopefully r50487 (devbr6) fixes
it.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:15&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:15 hamish]:
are we going to see this same zombie dbf.exe problem on Windows whenever
an exit via G_fatal_error() happens before closing the driver? e.g.
because of a typo in the column name or the column exists but its type is
wrong for the action? (or 1000 other ways things might fail)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:16&gt;
      Cpu: Unspecified |
Comment(by glynn):
Er, what?
motivating for the task..
The warnings shouldn't have been added in the first place. The remove() is
only necessary on Windows; on Unix, rename() will replace the destination
if it exists. On either platform, if the remove() fails, the subsequent
rename() should also fail, so there's no particular need to check the
result of remove() (other than for debugging this particular issue).
problems:
This ticket relates to r.null. As previously mentioned, vector modules
have their own issues, which belong on a separate ticket.
Replying to [comment:16 hamish]:
> ok, with perror(path) in place I see .../cell/mapname: Permission
denied. Checking in the Windows Task Manager I see that a leftover dbf.exe
and cmd.exe are still running after v.to.rast has finished. If I kill the
dbf.exe the cmd.exe goes away too, then r.null seems to work.
So this is specifically about running r.null on a map created by a vector
module? Does r.null work correctly on maps not created by vector modules?
If so, the title should be updated to reflect that.
In that case, the problem is one of the DBMI driver failing to terminate
along with its parent. I note that db__recv_procnum() only returns DB_EOF
if db__recv() returns 0 (indicating EOF). If it returns an error, it will
return DB_OK. Try r50496.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:17&gt;
#1276: r.null after v.to.rast in winGRASS does not work properly
Keywords: r.null, v.to.rast, wingrass | Platform: MSWindows 7
      Cpu: Unspecified |
  * keywords: r.null, wingrass => r.null, v.to.rast, wingrass
Comment:
Replying to [comment:17 glynn]:
> Er, what?
just that the warning messages need to be better targeted so that they
only print in cases when they are meaningful. (and don't try to remove() a
file which doesn't exist, etc)
vector module?
> Does r.null work correctly on maps not created by vector modules? If so,
the
The failing r.null is the symptom, I would guess that `g.remove rast` for
that map would also fail (untested) as the zombie v.to.rast process would
still have the cell file open.
along
> with its parent. I note that `db__recv_procnum()` only returns DB_EOF if
> `db__recv()` returns 0 (indicating EOF). If it returns an error, it will
return
> DB_OK. Try r50496.
is r50497 "SF_CLOSE_DESCRIPTOR should actually close the descriptor"
related? should it be backported?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:18&gt;
      Cpu: Unspecified |
Comment(by hamish):
along
> with its parent. I note that db__recv_procnum() only returns DB_EOF if
db__recv()
> returns 0 (indicating EOF). If it returns an error, it will return
DB_OK. Try r50496.
r50496 causes a `dbmi: Protocol error`, e.g. with `v.info -c mapname`.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:19&gt;
