#1278: d.mon strings from grassmods po files not localised at runtime
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Translations | Version: svn-releasebranch64
Keywords: locale | Platform: All
Cpu: All |
d.mon strings from grassmods po files are not localised at runtime. See
e.g. for GRASS built --with-nls, run in pl_PL.UTF-8 locale:
The '''message is in English''', although Polish translation is there -
source:/grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po@head#L15822
Cpu: All |
Comment(by glynn):
Replying to [ticket:1278 msieczka]:
This is because PACKAGE doesn't get defined. Module.make and Multi.make
define it as "grassmods", while Lib.make defines it as "grasslibs".
display/d.mon/pgms/Makefile doesn't include any of these, so the mon.*
programs don't use any message catalogue.
It should suffice to add:
PACKAGE = "grassmods"
to the top of display/d.mon/pgms/Makefile.
