[GRASS-dev] [GRASS GIS] #1282: WinGrass using www.python.org-installation
Reporter: hellik | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.2
Component: Packaging | Version: svn-releasebranch64
Keywords: | Platform: MSWindows Vista
      Cpu: Unspecified |
taken from http://lists.osgeo.org/pipermail/grass-
windows/2011-February/002117.html
On 22/02/2011 01:45, Glynn Clements wrote:
> However, this particular issue isn't a programming issue, but a
> packaging issue. If you want to use Python for scripting GRASS on
> Windows, the best solution is to delete the bundled version of Python
> 2.5 from the GRASS installation, install Python and the required
> add-ons (wxPython, NumPy, PyWin32) from their official installers,
> then edit the GRASS start-up script to remove any references to the
> bundled version.
One year ago or so Colin sent me an adapted nsis-wingrass-installer-script
with a first
attempt to use a www.python.org-installation instead of a bundled osgeo4w-
python.
I hope that I can find this script, so I can make this available for
further development.
maybe this would be a good starting point for the GRASS-hackfest in Prague
in May 2011.
best regards
Helmut
p.s. BTW I have a lot of different python-version on my WinVista-laptop
bundled with Inkscape, ArcGIS10, OpenOffice, etc. ... so I'm often
surprised
that all this python-installations are working ...
I have the nsis-script, but unfortunately not anymore the related mail.
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1282&gt;
Keywords: wingrass | Platform: MSWindows Vista
      Cpu: Unspecified |
Changes (by hellik):
  * keywords: => wingrass
Ticket URL: <http://trac.osgeo.org/grass/ticket/1282#comment:1&gt;
      Cpu: Unspecified |
Comment(by hamish):
Hi, any new ideas on this? Change %GRASS_PYTHON% in GRASS's env.bat as
needed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1282#comment:2&gt;
Priority: normal | Milestone: 6.4.4
      Cpu: Unspecified |
Changes (by hamish):
  * milestone: 6.4.2 => 6.4.4
Comment:
> Change %GRASS_PYTHON% in GRASS's env.bat as needed?
change of GRASS_PYTHON from "python" to
"%GISBASE%/etc/extrabin/python.exe" now applied in relbr64 and devbr6 to
avoid the reported version mis-match startup problems with wxGUI and
Python 2.7.2.
The GRASS+Msys startup method for wingrass continues to have $GRASS_PYTHON
= "python" as per Init.sh, so dependent on the $PATH. We'll have to watch
what happens there.
It seems to work in devbr6 for .py scripts called from the GUI, hopefully
"GRASS_PYTHON" is always launched instead of "python" so it will avoid
another installed version somewhere in the %PATH%. There are a couple .py
scripts and addons-- I assume on Wingrass the shebang is always ignored?
How about when called from msys?
This recent change is in basic disagreement with the thesis of this
particular bug report, so... I guess we'll see how it goes.
Anyone running custom .py addon scripts on Windows + GRASS 6.x are asked
to check if they still work.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1282#comment:3&gt;
