[GRASS-dev] [GRASS GIS] #1284: 'v.vol.rst --help' fails
Reporter: torben | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: 6.4.0
Keywords: v.vol.rst | Platform: Linux
      Cpu: x86-64 |
'v.vol.rst --help' fails with a 'buffer overflow' (cf. vvolrst_error.txt)
when 'g.region res3' is set to larger than 200 (in most cases). The error
depends on the value set to 'g.region res' (cf. vvolrstRes.csv).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1284&gt;
      Cpu: x86-64 |
Comment(by neteler):
I tried and no problem appears. The --help should be unrelated to
anything:
GRASS 6.4.1svn (nc_spm_08):~ > g.region n=4928500 s=4913500 w=589500
e=609000 b=0 t=2100 res=500 res3=500 tbres=2100
GRASS 6.4.1svn (nc_spm_08):~ > g.region -p3
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 4928500
south: 4913500
west: 589500
east: 609000
top: 2100.00000000
bottom: 0.00000000
nsres: 500
nsres3: 500
ewres: 500
ewres3: 500
tbres: 2100
rows: 30
rows3: 30
cols: 39
cols3: 39
depths: 1
cells: 1170
cells3: 1170
GRASS 6.4.1svn (nc_spm_08):~ > v.vol.rst --help
Description:
  Interpolates point data to a G3D grid volume using regularized spline
with tension (RST) algorithm.
Please create a backtrace in a debugger, like
gdb v.vol.rst
r --help
bt full
Ticket URL: <http://trac.osgeo.org/grass/ticket/1284#comment:1&gt;
      Cpu: x86-64 |
Comment(by torben):
The '-- help' shouldn't be related to anything, but it seems to me that
the defaul-value for 'dmin' is computed, when calling 'v.vol.rst'.
I tried to run it also on another machine with GRASS 6.4.1RC1, where it
started without any problems.
Here the debugger outputs.
GRASS 6.4.0 (spearfish60):~ > gdb v.vol.rst
GNU gdb (GDB) 7.1-ubuntu
Copyright (C) 2010 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html&gt;
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/&gt;\.\.\.
Reading symbols from /usr/lib/grass64/bin/v.vol.rst...(no debugging
symbols found)...done.
(gdb) r --help
Starting program: /usr/lib/grass64/bin/v.vol.rst --help
[Thread debugging using libthread_db enabled]
*** buffer overflow detected ***: /usr/lib/grass64/bin/v.vol.rst
terminated
======= Backtrace: =========
/lib/libc.so.6(__fortify_fail+0x37)[0x7ffff5380217]
/lib/libc.so.6(+0xfe0d0)[0x7ffff537f0d0]
/lib/libc.so.6(+0xfd539)[0x7ffff537e539]
/lib/libc.so.6(__printf_fp+0x1541)[0x7ffff52cd421]
/lib/libc.so.6(_IO_vfprintf+0x25fe)[0x7ffff52c899e]
/lib/libc.so.6(__vsprintf_chk+0x99)[0x7ffff537e5d9]
/lib/libc.so.6(__sprintf_chk+0x7f)[0x7ffff537e51f]
/usr/lib/grass64/bin/v.vol.rst(main+0x177)[0x405837]
/lib/libc.so.6(__libc_start_main+0xfd)[0x7ffff529fc4d]
/usr/lib/grass64/bin/v.vol.rst[0x404d89]
======= Memory map: ========
00400000-00410000 r-xp 00000000 08:01 102864
0060f000-00610000 r--p 0000f000 08:01 102864
00610000-00611000 rw-p 00010000 08:01 102864
00611000-00633000 rw-p 00000000 00:00 0
[heap]
7fffec829000-7fffec82c000 r-xp 00000000 08:01 570165
/lib/libgpg-error.so.0.4.0
7fffec82c000-7fffeca2b000 ---p 00003000 08:01 570165
7fffeca2b000-7fffeca2c000 r--p 00002000 08:01 570165
7fffeca2c000-7fffeca2d000 rw-p 00003000 08:01 570165
7fffeca2d000-7fffeca3d000 r-xp 00000000 08:01 540007
/usr/lib/libtasn1.so.3.1.7
7fffeca3d000-7fffecc3c000 ---p 00010000 08:01 540007
7fffecc3c000-7fffecc3d000 r--p 0000f000 08:01 540007
7fffecc3d000-7fffecc3e000 rw-p 00010000 08:01 540007
7fffecc3e000-7fffecc57000 r-xp 00000000 08:01 539953
/usr/lib/libsasl2.so.2.0.23
7fffecc57000-7fffece56000 ---p 00019000 08:01 539953
7fffece56000-7fffece57000 r--p 00018000 08:01 539953
7fffece57000-7fffece58000 rw-p 00019000 08:01 539953
7fffece58000-7fffece6e000 r-xp 00000000 08:01 69293
/lib/libresolv-2.11.1.so
7fffece6e000-7fffed06d000 ---p 00016000 08:01 69293
7fffed06d000-7fffed06e000 r--p 00015000 08:01 69293
7fffed06e000-7fffed06f000 rw-p 00016000 08:01 69293
7fffed06f000-7fffed071000 rw-p 00000000 00:00 0
7fffed071000-7fffed073000 r-xp 00000000 08:01 570172
/lib/libkeyutils-1.2.so
7fffed073000-7fffed272000 ---p 00002000 08:01 570172
7fffed272000-7fffed273000 r--p 00001000 08:01 570172
7fffed273000-7fffed274000 rw-p 00002000 08:01 570172
7fffed274000-7fffed27b000 r-xp 00000000 08:01 538290
/usr/lib/libkrb5support.so.0.1
7fffed27b000-7fffed47a000 ---p 00007000 08:01 538290
7fffed47a000-7fffed47b000 r--p 00006000 08:01 538290
7fffed47b000-7fffed47c000 rw-p 00007000 08:01 538290
7fffed47c000-7fffed4a0000 r-xp 00000000 08:01 537563
/usr/lib/libk5crypto.so.3.1
7fffed4a0000-7fffed6a0000 ---p 00024000 08:01 537563
7fffed6a0000-7fffed6a1000 r--p 00024000 08:01 537563
7fffed6a1000-7fffed6a2000 rw-p 00025000 08:01 537563
7fffed6a2000-7fffed6b9000 r-xp 00000000 08:01 69284
/lib/libnsl-2.11.1.so
7fffed6b9000-7fffed8b8000 ---p 00017000 08:01 69284
7fffed8b8000-7fffed8b9000 r--p 00016000 08:01 69284
7fffed8b9000-7fffed8ba000 rw-p 00017000 08:01 69284
7fffed8ba000-7fffed8bc000 rw-p 00000000 00:00 0
7fffed8bc000-7fffed931000 r-xp 00000000 08:01 570161
/lib/libgcrypt.so.11.5.2
7fffed931000-7fffedb30000 ---p 00075000 08:01 570161
7fffedb30000-7fffedb31000 r--p 00074000 08:01 570161
7fffedb31000-7fffedb34000 rw-p 00075000 08:01 570161
7fffedb34000-7fffedbd0000 r-xp 00000000 08:01 539501
/usr/lib/libgnutls.so.26.14.12
7fffedbd0000-7fffeddcf000 ---p 0009c000 08:01 539501
7fffeddcf000-7fffeddd5000 r--p 0009b000 08:01 539501
7fffeddd5000-7fffeddd6000 rw-p 000a1000 08:01 539501
7fffeddd6000-7fffedde3000 r-xp 00000000 08:01 539719
/usr/lib/liblber-2.4.so.2.5.4
7fffedde3000-7fffedfe2000 ---p 0000d000 08:01 539719
7fffedfe2000-7fffedfe3000 r--p 0000c000 08:01 539719
7fffedfe3000-7fffedfe4000 rw-p 0000d000 08:01 539719
7fffedfe4000-7fffee015000 r-xp 00000000 08:01 539675
/usr/lib/libidn.so.11.5.44
7fffee015000-7fffee215000 ---p 00031000 08:01 539675
7fffee215000-7fffee216000 r--p 00031000 08:01 539675
7fffee216000-7fffee217000 rw-p 00032000 08:01 539675
7fffee217000-7fffee2a1000 r-xp 00000000 08:01 539994
/usr/lib/libsqlite3.so.0.8.6
7fffee2a1000-7fffee4a0000 ---p 0008a000 08:01 539994
7fffee4a0000-7fffee4a2000 r--p 00089000 08:01 539994
7fffee4a2000-7fffee4a4000 rw-p 0008b000 08:01 539994
Program received signal SIGABRT, Aborted.
0x00007ffff52b4a75 in raise () from /lib/libc.so.6
(gdb) bt full
#0 0x00007ffff52b4a75 in raise () from /lib/libc.so.6
No symbol table info available.
#1 0x00007ffff52b85c0 in abort () from /lib/libc.so.6
#2 0x00007ffff52ee4fb in ?? () from /lib/libc.so.6
#3 0x00007ffff5380217 in __fortify_fail () from /lib/libc.so.6
#4 0x00007ffff537f0d0 in __chk_fail () from /lib/libc.so.6
#5 0x00007ffff537e539 in ?? () from /lib/libc.so.6
#6 0x00007ffff52cd421 in __printf_fp () from /lib/libc.so.6
#7 0x00007ffff52c899e in vfprintf () from /lib/libc.so.6
#8 0x00007ffff537e5d9 in __vsprintf_chk () from /lib/libc.so.6
#9 0x00007ffff537e51f in __sprintf_chk () from /lib/libc.so.6
#10 0x0000000000405837 in main ()
Ticket URL: <http://trac.osgeo.org/grass/ticket/1284#comment:2&gt;
Priority: major | Milestone: 6.4.1
      Cpu: x86-64 |
Changes (by marisn):
  * priority: normal => major
Comment:
Crashes on my ~AMD64 machine too. Memory corruption? Can't check, as my
glibc (for some strange reason) lacks debug symbols and thus valgrind
doesn't work.
Will try to get some extra debugging info within today.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1284#comment:3&gt;
      Cpu: x86-64 |
Maris, on my system there is glibc-debug as package.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1284#comment:4&gt;
      Cpu: x86-64 |
Comment(by marisn):
Markus, on my system there is a "SPLITDEBUG" feature + recompilation. I
migh be rm'ing debug data to free some disk space :wink:
Problem is here:
source:grass/branches/releasebranch_6_4/vector/v.vol.rst/main.c#L225
"dminchar" is defined to have length of 10, still on my system somtimes
"dmin" is longer than 10. Easy workaround - bump up dminchar to anything
large enough (1000). Correct solution - analyze code and see if it's
required at all.
sprintf(dminchar, "%lf", dmin);
Ticket URL: <http://trac.osgeo.org/grass/ticket/1284#comment:5&gt;
      Cpu: x86-64 |
Comment(by torben):
Is it important to have a high precision for 'dminchar'?
That could also fix it:
sprintf(dminchar, "%.2f", dmin);
Ticket URL: <http://trac.osgeo.org/grass/ticket/1284#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.vol.rst
  Platform: Linux | Cpu: x86-64
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:5 marisn]:
> Problem is here:
"dmin" is
> longer than 10. Easy workaround - bump up dminchar to anything large
enough (1000).
buffer size increased in all branches with r45906-8.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1284#comment:7&gt;
