[GRASS-dev] [GRASS GIS] #1288: g.dirseps breaks non-latin file/folder names on Windows
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.1
Component: Default | Version: 6.4.1 RCs
Keywords: | Platform: MSWindows Vista
      Cpu: Unspecified |
For some strange reason g.dirseps corrupts file/folder names during slash
conversion on Windows Vista running with CP1257 locale. This prevents
TCL/Tk GUI from starting as it fails to locate GISRC file.
WinGRASS-6.4.1RC1-1
"Executing: g.dirseps -g 'C:\Users\Māris\.grassrc6'"
C:/Users/MŌris/.grassrc6
"g.dirsteps complete."
Ticket URL: <http://trac.osgeo.org/grass/ticket/1288&gt;
Keywords: wingrass | Platform: MSWindows Vista
      Cpu: Unspecified |
Changes (by hellik):
  * keywords: => wingrass
Ticket URL: <http://trac.osgeo.org/grass/ticket/1288#comment:1&gt;
Priority: critical | Milestone: 7.0.0
      Cpu: Unspecified |
Changes (by marisn):
  * milestone: 6.4.1 => 7.0.0
Comment:
Related to issue #995
Most likely impossible to fix due to OEM/CP/Unicode coding issues in MS-
Windows.
Pushing up to 7.0 to remember about codepage issues in MS-Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1288#comment:2&gt;
Keywords: wingrass, i18n, encoding | Platform: MSWindows Vista
      Cpu: Unspecified |
Changes (by wenzeslaus):
  * keywords: wingrass => wingrass, i18n, encoding
Comment:
I'm not sure if it makes sense to keep this issue open. It is hard to say
where all/some encoding issues may appear and then go and fix them. And
new code is being added, so if this issue is kept open ''to remember'', it
should be open forever (which does not make sense).
Of course we should keep in mind internationalization issues which are
especially occurring on MS Windows. However, I would rather keep tract of
individual issues rather then having some general ticket just as a
reminder.
Most of the related tickets hopefully captured by these queries:
[query:?status=assigned&status=new&status=reopened&summary=~localization&summary=~internationalization&summary=~i18n&summary=~L10n&summary=~locale&summary=~locales&summary=~translations&summary=~encoding&order=priority&col=id&col=summary&col=keywords&col=type&col=priority
summary]
[query:?status=assigned&status=new&status=reopened&description=~localization&description=~internationalization&description=~i18n&description=~L10n&description=~locale&description=~locales&description=~translations&description=~encoding&order=priority&col=id&col=summary&col=keywords&col=type&col=priority
description]
[query:?status=assigned&status=new&status=reopened&keywords=~localization&keywords=~internationalization&keywords=~i18n&keywords=~L10n&keywords=~locale&keywords=~locales&keywords=~translations&keywords=~encoding&order=priority&col=id&col=summary&col=keywords&col=type&col=priority
keywords]
Done using wiki:TracQuery:
summary]
description]
keywords]
Originally reported issue seems to be resolved as ''wontfix'' according to
comment:2, so I suggest to close this issue accordingly. But to test this
(and perhaps #995) with GRASS 6.4.svn would not harm, probably, since it
was reported 3 years ago for GRASS 6.4.1 RC.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1288#comment:3&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
Please, somebody, test this on some non-English MS Windows with as many
version of GRASS as possible. Please close this ticket if it is not an
issue for 7.0 (currently: beta1, beta2, nightly).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1288#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, i18n, encoding
  Platform: MSWindows Vista | Cpu: Unspecified
  * status: new => closed
  * resolution: => fixed
Comment:
Closing, as GRASS 7 has moved away from the TCL/Tk UI, startup script now
is using Python and doesn't call dirseps via shell.
The encoding issues when passing text via CMD remain, but are (and should
be) tracked in separate tickets. It is still an issue for the 6.x
releases, but wontfix there due to too invasive changes required.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1288#comment:5&gt;
