[GRASS-dev] [GRASS GIS] #1289: wingrass65 - Vector digitizer not available: Reason: xdr not found
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: wingrass, vector, digitizer | Platform: MSWindows Vista
      Cpu: x86-32 |
tested with a self compiled wingrass65 at r45511
message in the wxgui at startup:
3D view mode not available
Reason: xdr not found.
Note that the wxGUI's 3D view mode is currently disabled on
MS Windows (hopefully this will be fixed soon). Please keep
an eye out for updated versions of GRASS. In the meantime
you can use "NVIZ" from the File menu.
Note that the wxGUI's vector digitizer is currently disabled
(hopefully this will be fixed soon). Please keep an eye out
for updated versions of GRASS. In the meantime you can use
"v.digit" from the Develop Vector menu.
from package.log
checking for library containing cuserid... no
checking for xdrmem_create... no
checking for xdrmem_create in -lsun... no
checking for xdrmem_create in -lnsl... no
checking for xdrmem_create in -lrpclib... no
checking for xdrmem_create in -lxdr... yes
checking for asprintf... no
checking for atan... yes
if I add a vector in the mapdisplay and then open the table attribute
manager, dbf.exe is crashing.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1289&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, vector, digitizer
  Platform: MSWindows Vista | Cpu: x86-32
Changes (by hellik):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [ticket:1289 hellik]:
> from package.log
> Helmut
closing ticket after a nearly a year of successfull testing.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1289#comment:1&gt;
