#1302: r.out.ascii with "-m" (MODFLOW) option produce larger fields for negative
values
Reporter: vargay | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Raster | Version: 6.4.0
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
The r.out.ascii with "-m" (MODFLOW) option produce larger fields for
negative values.
The error is probabely due to the format specification in the fprintf
statements in the file formspecific.c:
/* write MODFLOW ASCII ARRAY */
int write_MODFLOW(int fd,
FILE * fp,
int nrows, int ncols, int out_type, int dp, int width)
else if (out_type == FCELL_TYPE) {
if (G_is_null_value(ptr, out_type))
*((FCELL *) ptr) = 0;
fprintf(fp, "%*.*e", dp + 6, dp - 1, *((FCELL *) ptr));
else if (out_type == DCELL_TYPE) {
*((DCELL *) ptr) = 0;
fprintf(fp, "%*.*e", dp + 6, dp - 1, *((DCELL *) ptr));
For demonstrating the problem, see the next simple test program
(I use MINGW gcc 4.5.2 for compiling):
#include <stdio.h>
void main(void) {
int dp, i;
double DCELL;
dp = 5;
DCELL = 125.55;
printf("\n[");
for(i=0;i<5;i++) printf("%*.*e", dp + 6, dp - 1, DCELL);
printf("]");
DCELL = -125.55;
printf("\n[");
printf("]\n");
Running the above test program, the result is:
[1.2555e+0021.2555e+0021.2555e+0021.2555e+0021.2555e+002]
[-1.2555e+002-1.2555e+002-1.2555e+002-1.2555e+002-1.2555e+002]
Changing the format specification as follow:
printf("%*.*e", dp + 7, dp - 1, DCELL);
the result became suitable:
[ 1.2555e+002 1.2555e+002 1.2555e+002 1.2555e+002 1.2555e+002]
Sincerely Zoltan
Ticket URL: <http://trac.osgeo.org/grass/ticket/1302>
