GDAL
1
#1305: WXGUI raster map calculator should quote map names
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.1
Component: wxGUI | Version: 6.4.1 RCs
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Create a map with - in it's name (it's legal map name). Use it in
r.mapcalc from WXGUI mapcalculator (use dropdown list to select it).
Wrapping map names in "" fixes issue:
(Fri Mar 11 11:18:08 2011)
r.mapcalc srtm-rst = srtm@SRTM-reljefs_rst@SRTM
syntax error, unexpected '-', expecting '='
Parse error
(Fri Mar 11 11:18:10 2011) Command finished (1 sec)
(Fri Mar 11 11:20:34 2011)
r.mapcalc negacija = reljefs_rst@SRTM-srtm-reljefs@SRTM
Invalid map <reljefs@SRTM>
Parse error
(Fri Mar 11 11:20:35 2011) Command finished (1 sec)
(Fri Mar 11 11:22:29 2011)
r.mapcalc negacija = "reljefs_rst@SRTM"-"srtm-reljefs@SRTM"
(Fri Mar 11 11:22:31 2011) Command finished (2 sec)
(Fri Mar 11 11:27:28 2011)
r.mapcalc "negacija-smegacija" = "reljefs_rst@SRTM"-"srtm-reljefs@SRTM"
(Fri Mar 11 11:27:30 2011) Command finished (2 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1305>
GDAL
2
Keywords: raster calculator | Platform: Unspecified
Cpu: Unspecified |
Changes (by martinl):
* keywords: => raster calculator
Ticket URL: <http://trac.osgeo.org/grass/ticket/1305#comment:1>
GDAL
3
Priority: minor | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2 RCs
Keywords: raster calculator, r.mapcalc | Platform: All
Cpu: All |
Changes (by hamish):
* keywords: raster calculator => raster calculator, r.mapcalc
* platform: Unspecified => All
* version: 6.4.1 RCs => 6.4.2 RCs
* cpu: Unspecified => All
* milestone: 6.4.1 => 6.4.3
Comment:
still fails. tested on both wingrass and linux, 6.5svn.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1305#comment:2>
GDAL
4
Type: defect | Status: closed
Resolution: fixed | Keywords: raster calculator, r.mapcalc
Platform: All | Cpu: All
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Should be fixed in r52807, r52808, r52809.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1305#comment:3>
