#1306: WGUI doesn't strip quotes from map name when adding to layer manager after
module run
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: wxGUI | Version: 6.4.1 RCs
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Use raster calculator to create a new map that needs quotes around it's
name i.e. "a-b" (r.mapcalc "a-b" = 5). a-b map is added to layer manager
as "a-b" (including quotes), still correct map name is a-b and not "a-b".
Some modules (all?) would fail to process this map until it's name in
layer manager is changed to correct one.
(Fri Mar 11 11:34:03 2011)
r.mapcalc "a-b" = 5
(Fri Mar 11 11:34:04 2011) Command finished (1 sec)
(Fri Mar 11 11:34:16 2011)
r.info map="a-b"@SRTM
Illegal filename. Character <"> not allowed.
ERROR: Raster map <"a-b"@SRTM> not found
(Fri Mar 11 11:34:17 2011) Command finished (0 sec)
