[GRASS-dev] [GRASS GIS] #1308: wingrass - dbf.exe-crash
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Default | Version: svn-releasebranch64
Keywords: wingrass, dbf.exe, d.vect | Platform: MSWindows Vista
      Cpu: x86-32 |
tested with nightly-build WinGRASS-6.4.SVN-r45623-1-Setup.exe
(but IIRC sometimes also in earlier revisions) in nc-sample-dataset
(1) in the wxgui add vector layer
(2) d.vect-gui pops up
(3) choosing a layer (very interesting, it isn't always the same
     existing layer and not always; I can't really give repeatable
     circumstances)
(4) dbf.exe crashes
(5) after clicking away the crash-error-windows and closing the
     d.vect-gui, the layer is added in the tree and the map display
some additional informations (delivered by DEUBUG=5 and windows-crash-
informations:
D1/5: grass.script.core.start_command(): g.mlist -m type=vect
D1/5: grass.script.core.start_command(): v.db.connect -g
map=lakes@PERMANENT fs=;
D1/5: grass.script.core.start_command(): db.describe -c table=lakes
driver=dbf database=C:\gisdata\grassdata\nc_spm_08\PERMANENT\dbf\
GRASS 6.4>
GRASS 6.4> D1/5: grass.script.core.start_command(): d.vect --q
map=lakes@PERMANENT type=point,area,face,centroid,line,boundary
D1/5: grass.script.core.start_command(): g.pnmcomp opacity=1.0
mask=c:\users\syringia\appdata\local\temp\tmp5rhzes.pgm height=502
width=782 background=255:255:255:255
input=c:\users\syringia\appdata\local\temp\tmp5rhzes.ppm
output=c:\users\syringia\appdata\local\temp\tmpo5cnsd.ppm
D1/5: grass.script.core.start_command(): g.findfile -n file=MASK
element=cell
it seems the crash is nearby the v.db.connect- and db.describe-steps.
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="dbf.exe" FILTER="GRABMI_FILTER_PRIVACY">
     <MATCHING_FILE NAME="dbf.exe" SIZE="553931" CHECKSUM="0x378861C9"
MODULE_TYPE="WIN32" PE_CHECKSUM="0x93EF1" LINKER_VERSION="0x10000"
LINK_DATE="03/11/2011 02:08:34" UPTO_LINK_DATE="03/11/2011 02:08:34" />
     <MATCHING_FILE NAME="odbc.exe" SIZE="475447" CHECKSUM="0xEEE2279C"
MODULE_TYPE="WIN32" PE_CHECKSUM="0x77E51" LINKER_VERSION="0x10000"
LINK_DATE="03/11/2011 02:08:39" UPTO_LINK_DATE="03/11/2011 02:08:39" />
     <MATCHING_FILE NAME="ogr.exe" SIZE="80297" CHECKSUM="0xC557406A"
MODULE_TYPE="WIN32" PE_CHECKSUM="0x1FDFB" LINKER_VERSION="0x10000"
LINK_DATE="03/11/2011 02:08:45" UPTO_LINK_DATE="03/11/2011 02:08:45" />
     <MATCHING_FILE NAME="pg.exe" SIZE="101619" CHECKSUM="0x3C15C8C2"
MODULE_TYPE="WIN32" PE_CHECKSUM="0x209B9" LINKER_VERSION="0x10000"
LINK_DATE="03/11/2011 02:08:42" UPTO_LINK_DATE="03/11/2011 02:08:42" />
     <MATCHING_FILE NAME="sqlite.exe" SIZE="95388" CHECKSUM="0x132FBDAF"
MODULE_TYPE="WIN32" PE_CHECKSUM="0x1C709" LINKER_VERSION="0x10000"
LINK_DATE="03/11/2011 02:08:44" UPTO_LINK_DATE="03/11/2011 02:08:44" />
</EXE>
<EXE NAME="ntdll.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
     <MATCHING_FILE NAME="ntdll.dll" SIZE="1205080" CHECKSUM="0x1C4D583"
BIN_FILE_VERSION="6.0.6002.18327" BIN_PRODUCT_VERSION="6.0.6002.18327"
PRODUCT_VERSION="6.0.6001.18000" FILE_DESCRIPTION="DLL für NT-Layer"
COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Betriebssystem
Microsoft® Windows®" FILE_VERSION="6.0.6001.18000
(longhorn_rtm.080118-1840)" ORIGINAL_FILENAME="ntdll.dll.mui"
INTERNAL_NAME="ntdll.dll" LEGAL_COPYRIGHT="© Microsoft Corporation. Alle
Rechte vorbehalten." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004"
VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12F237"
LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="6.0.6002.18327"
UPTO_BIN_PRODUCT_VERSION="6.0.6002.18327" LINK_DATE="10/14/2010 16:47:50"
UPTO_LINK_DATE="10/14/2010 16:47:50" EXPORT_NAME="ntdll.dll"
VER_LANGUAGE="Deutsch (Deutschland) [0x407]" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
     <MATCHING_FILE NAME="kernel32.dll" SIZE="891392" CHECKSUM="0xF772C2F2"
BIN_FILE_VERSION="6.0.6002.18005" BIN_PRODUCT_VERSION="6.0.6002.18005"
PRODUCT_VERSION="6.0.6001.18000" FILE_DESCRIPTION="Client-DLL für Windows
NT-Basis-API" COMPANY_NAME="Microsoft Corporation"
PRODUCT_NAME="Betriebssystem Microsoft® Windows®"
FILE_VERSION="6.0.6001.18000 (longhorn_rtm.080118-1840)"
ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="©
Microsoft Corporation. Alle Rechte vorbehalten." VERDATEHI="0x0"
VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32"
PE_CHECKSUM="0xDBE01" LINKER_VERSION="0x60000"
UPTO_BIN_FILE_VERSION="6.0.6002.18005"
UPTO_BIN_PRODUCT_VERSION="6.0.6002.18005" LINK_DATE="04/11/2009 06:25:33"
UPTO_LINK_DATE="04/11/2009 06:25:33" EXPORT_NAME="KERNEL32.dll"
</EXE>
</DATABASE>
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [ticket:1308 hellik]:
after finishing wingrass, in the windows task manager it seems there are
still some db.describe.exe-instances running.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:1&gt;
Priority: blocker | Milestone: 6.4.1
      Cpu: x86-32 |
Changes (by martinl):
  * priority: major => blocker
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:2&gt;
      Cpu: x86-32 |
Comment(by hellik):
seems related to #1298 (http://trac.osgeo.org/grass/ticket/1298),
dbf.exe-crash with v.digit
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:3&gt;
      Cpu: x86-32 |
Comment(by martinl):
Replying to [comment:1 hellik]:
it's strange that it crashes only sometimes, it's probably unrelated but
with r45652 I was not able to reproduce this bug. Can you test it?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:4&gt;
      Cpu: x86-32 |
Replying to [comment:4 martinl]:
steps.
are still some db.describe.exe-instances running.
build available at
http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.SVN-r45652-1-Setup.exe
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:5&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:5 martinl]:
steps.
but with r45652 I was not able to reproduce this bug. Can you test it?
> build available at
it's very strange. tested in following way with the nc-sample-dataset
adding
always geology, firestations, lakes and geonamesNC in the same order:
self compiled r45652 in the osgeo4w-stack:
(1) starting wingrass in the osgeo4w-windows-shell(command line):
first run adding
-geology dbf.exe-crash
- firestations dbf.exe-crash
- lakes ok
- geonames dbf.exe-crash
exit the grass-session and starting a new second one, all vector are
loading normally
(2) starting wingrass in the osgeo4w-msys-shell:
-geology ok
- firestations ok
- lakes dbf.exe-crash
- geonames ok
loading normally
(3) testing
all vectors added with the d.vect without any dbf.exe-crash.
Helmut
p.s. no dbf.exe-crash with create a new vector by v.digit in all 3
approaches
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:6&gt;
      Cpu: x86-32 |
Replying to [comment:6 hellik]:
> (3) testing
I made some tests, unfortunately it's still sometimes crashing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:7&gt;
      Cpu: x86-32 |
Replying to [comment:7 martinl]:
it's really hard to hunt this bug, currently trying to reproduce dbf
crash. Unfortunately not crashing here after some attempts. Can some post
here full debug output?
g.debug set=DEBUG=5
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:8&gt;
      Cpu: x86-32 |
informations:
> GRASS 6.4>
element=cell
it doesn't seem to be full debug output, I can see only debug messages
produced by python library...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:9&gt;
      Cpu: x86-32 |
Replying to [comment:9 martinl]:
informations:
here is missing completely debug info from `db.describe`, so it seems that
it crashes before first debug message (?)
D2/5: dbDbmscap(): opendir [c:\Program Files (x86)\GRASS
6.4.SVN\driver\db\]
> > GRASS 6.4>
element=cell
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:10&gt;
      Cpu: x86-32 |
Replying to [comment:3 hellik]:
these bugs have been reported recently, it's worth to review r45515
(`lib/db/dbmi_base` part). I can be that this bug has been accidentally
introduced by this commit - just an idea...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:11&gt;
      Cpu: x86-32 |
Replying to [comment:11 martinl]:
patch attached - dbmi-45515.diff
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:12&gt;
      Cpu: x86-32 |
Replying to [comment:12 martinl]:
I found incorrect usage of `db_free_string` on variable `char *`, fixed in
r45671. I am still unable to reproduce any crash...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:13&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:10 martinl]:
that it crashes before first debug message (?)
yes it seems so what I have also found in my testings
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:14&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:13 martinl]:
in r45671. I am still unable to reproduce any crash...
no chance at the moment for compiling myself r45671. I'll test it when
nightly build will be available.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:15&gt;
      Cpu: x86-32 |
Replying to [comment:15 hellik]:
fixed in r45671. I am still unable to reproduce any crash...
extra build available at
http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.SVN-r45671-1-Setup.exe
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:16&gt;
      Cpu: x86-32 |
Comment(by neteler):
I checked the patch r45671 and found another bug candidate:
  * in lib/db/dbmi_base/value.c
(http://trac.osgeo.org/grass/changeset/45515#file16)
   -> G_free? I guess db_free()?
Then in lib/db/dbmi_driver/d_close_cur.c, checking the db_free_cursor():
call (http://trac.osgeo.org/grass/changeset/45673#file2): looks ok to me
since db_free_cursor() does not free cursor itself. Not sure, though.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:17&gt;
      Cpu: x86-32 |
Replying to [comment:17 neteler]:
it's allocated by
[source:grass/branches/releasebranch_6_4/lib/db/dbmi_base/value.c#L374
G_calloc], anyway it should be harmless, currently `G_free()` and
`db_free()` are identical.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:18&gt;
Cpu: x86-32 |
it's allocated by
Ok, I was just remembering
http://trac.osgeo.org/grass/ticket/468#comment:2
(were they came from different DLLs, hence the problem)
