it's allocated by
[source:grass/branches/releasebranch_6_4/lib/db/dbmi_base/value.c#L374
G_calloc], anyway it should be harmless, currently `G_free()` and
`db_free()` are identical.
Replying to [comment:16 martinl]:
> Replying to [comment:15 hellik]:
> > Replying to [comment:13 martinl]:
> > > I found incorrect usage of `db_free_string` on variable `char *`,
fixed in r45671. I am still unable to reproduce any crash...
> > no chance at the moment for compiling myself r45671. I'll test it when
nightly build will be available.
> extra build available at http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.SVN-r45671-1-Setup.exe
I've tested it a little with above build in different modes (GRASS
6.4.SVN,GRASS 6.4.SVN with MSYS, GRASS Old TclTk GUI, GRASS Command Line
and g.gui wxpython) with a random set of nc-sample-vectors in about 30
sessions. I can't reproduce this anymore.
2011/3/16 Markus Neteler <neteler at osgeo.org>:
>> it's allocated by
> Ok, I was just remembering
> http://trac.osgeo.org/grass/ticket/468#comment:2
> (were they came from different DLLs, hence the problem)
right, I overlooked this issue. Anyway now it should OK.
Martin
I see there was some code review for this issue, therefore I'll close this
ticket.
please reopen if needed.
