[GRASS-dev] [GRASS GIS] #1310: Browse button in WxPython GUIs (for scripts) does not provide a correct file path for WinGRAS
Reporter: katrineggert1980 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.1
Component: wxGUI | Version: 6.4.1 RCs
Keywords: winGRASS | Platform: MSWindows XP
      Cpu: Unspecified |
Greetings
I'm running GRASS script function (e.g. r.out.xyz) and If I use Browse
button to search/define for output file it produces a path in Windows
style (e.g. C:\data\GRASS\) that is wrong since GRASS's pythons do not use
'\'. So user need to change '\' by hand to '/'.
THis happens to all GRASS Scripts that uses Browse and file paths.
This does not happen in text mode if we use " " around the file path.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310&gt;
      Cpu: Unspecified |
Comment(by hellik):
tested with WinGRASS-6.4.SVN-r45749-1-Setup.exe
folder and file destination of the output files always definded by the
Browse button of the wxgui
r.out.xyz input=elevation@PERMANENT output=C:\wd\exportgrass\routxyz.txt
c:/Program Files/GRASS 6.4.SVN/scripts/r.out.xyz: line 61:
C:wdexportgrassroutxyz.txt: Permission denied
but very interesting also tested with other raster and vector export
modules
r.out.ascii input=elevation@PERMANENT
output=C:\wd\exportgrass\routascii.asc
(Sat Mar 26 14:43:54 2011) Command finished (10 sec)
r.out.arc input=elevation@PERMANENT output=C:\wd\exportgrass\routarc.asc
(Sat Mar 26 14:46:38 2011) Command finished (12 sec)
r.out.mat input=elevation@PERMANENT output=C:\wd\exportgrass\routmat.mat
r.out.mat komplett.
(Sat Mar 26 14:48:06 2011) Command finished (1 sec)
r.out.png input=elevation@PERMANENT output=C:\wd\exportgrass\routpng.png
(Sat Mar 26 14:49:23 2011) Command finished (3 sec)
r.out.ppm input=elevation@PERMANENT output=C:\wd\exportgrass\routppm.ppm
Zeilen = 1350, Spalten = 1500
Konvertiere ...
r.out.ppm komplett. Datei <C:\wd\exportgrass\routppm.ppm> erstellt.
(Sat Mar 26 14:50:15 2011) Command finished (2 sec)
r.out.gdal input=elevation@PERMANENT
output=C:\wd\exportgrass\routgdal.gtif
Exportiere in den GDAL-Datentyp: Float32
Prüfe GDAL Datentyp und NoData-Wert.
ERROR 6: SetColorTable() only supported for Byte or UInt16
bands in TIFF format.
Exportiere nach GDAL-Raster.
r.out.gdal komplett.
(Sat Mar 26 14:52:23 2011) Command finished (1 sec)
v.out.ascii input=firestations@PERMANENT
output=C:\wd\exportgrass\voutascii.txt
(Sat Mar 26 14:53:32 2011) Command finished (0 sec)
v.out.dxf input=firestations@PERMANENT
output=C:\wd\exportgrass\voutdxf.dxf
v.out.dxf komplett. 71 Feature geschrieben nach
'C:\wd\exportgrass\voutdxf.dxf'.
(Sat Mar 26 14:54:27 2011) Command finished (0 sec)
are you able to test it on your side?
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:1&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:1310 katrineggert1980]:
maybe some hints from the ML
(http://lists.osgeo.org/pipermail/grass-dev/2011-March/053942.html)
Just a preliminary note: This error is reported here:
http://lists.osgeo.org/pipermail/grass-dev/2011-March/053774.html
I saw that Glynn sugeste this a couple of months ago:
http://lists.osgeo.org/pipermail/grass-dev/2010-October/052396.html
Can this be an option to solve this problem? Can anyone give a few tips on
this? (just to try and test it)
Thanks
Best Regards
Kat
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:2&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:1 hellik]:
Looking at the *script* r.out.xyz, we see that a redirection is used:
# if no output filename, output to stdout
if [ -z "$GIS_OPT_OUTPUT" ] || [ "$GIS_OPT_OUTPUT" = "-" ]; then
     r.stats -1gn "$GIS_OPT_INPUT" fs="$GIS_OPT_FS"
else
     r.stats -1gn "$GIS_OPT_INPUT" fs="$GIS_OPT_FS" > "$GIS_OPT_OUTPUT"
fi
I suspect that this is causing problems on Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:3&gt;
      Cpu: Unspecified |
Replying to [comment:3 neteler]:
> else
> fi
I wonder why not simply using the "output=" parameter of r.stats:
   output Name for output file (if omitted or "-" output to stdout)
Helmut, could you please test if adding output="$GIS_OPT_OUTPUT" helps?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:4&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:4 neteler]:
tried with following:
else
fi
now there isn't any error message
r.out.xyz input=elevation@PERMANENT output=C:\wd\test\routxyzp.xyz
(Sat Mar 26 18:30:37 2011) Command finished (46 sec)
'''but''' the file doesn't seem to be written, the destination folder is
empty.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:5&gt;
      Cpu: Unspecified |
Replying to [comment:5 hellik]:
> else
> fi
empty.
Yes, you forgot to take out ">". Try this code:
     r.stats -1gn "$GIS_OPT_INPUT" fs="$GIS_OPT_FS" output="-"
else
fi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:6&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:6 neteler]:
r.out.xyz input=elevation@PERMANENT output=C:\wd\test\test.xyz
ERROR: Kann Datei <C:wdtesttest.xyz> nicht zum Schreiben öffnen.
(Sat Mar 26 19:14:10 2011) Command finished (0 sec)
so no change regarding the path issue.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:7&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:7 hellik]:
for the record with the original code:
if I copy the command from the wxgui to the wingrass-msys-shell
GRASS 6.4> r.out.xyz input=elevation@PERMANENT
output=C:\wd\test\testroutxyz.txt
C:wdtesttestroutxyz.txt: Permission denied
and with a quoted path in the wingrass-msys-shell
output="C:\wd\test\testroutxyz.txt"
  100%
GRASS 6.4>
the original code is working in windows with a quoted path
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:8&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:2 hellik]:
from the dev-ML
(http://lists.osgeo.org/pipermail/grass-dev/2011-March/053954.html)
on
Right. Currently, 6.5 has utils.split(), which handles Windows
filenames, but much of the wx GUI is still using shlex.split()
directly.
Feel free to replace all occurrences of shlex.split() with
utils.split() in your local copy. Also, open a bug report (if there
isn't already one for this issue).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:9&gt;
      Cpu: Unspecified |
To change the code in automated way:
cd gui/wxpython/gui_modules/
for i in menuform.py gmodeler.py menu.py prompt.py goutput.py ; do mv
$i tmp.py ; cat tmp.py | sed 's+shlex.split+utils.split+g' > $i ; rm
-f tmp.py ; done
$i tmp.py ; cat tmp.py | sed 's+import shlex+import utils+g' > $i ; rm
-f tmp.py ; done
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:10&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:9 hellik]:
tips on
> directly.
done in r45770 (devbr6) and r45771 (trunk). Testing welcomed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:11&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:11 martinl]:
tested in a self compiled wingrass65 r45770
r.out.xyz --verbose input=elevation@PERMANENT
output=C:\wd\test\wingrass65rout.xyz
c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
mingw32/scripts/r.out.xyz: line 61:
C:wdtestwingrass65rout.xyz: Permission denied
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:12&gt;
      Cpu: Unspecified |
Comment(by katrineggert1980):
I have tested with the following:
- GRASS Inport/Export modules- Works on Windows
- GRASS Inport/Export bash scripts- Does not work
- GRASS Inport/Export Python scripts- Does not work
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:13&gt;
      Cpu: Unspecified |
Replying to [comment:13 katrineggert1980]:
Ups Sorry. This meant before these updates :slight_smile:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:14&gt;
      Cpu: Unspecified |
I have installed WinGRASS6.4 night built from today (28th March 2011) and
I tried:
(Mon Mar 28 10:16:51 2011)
r.out.xyz input=lsat5_1987_10@landsat output=C:\delete\tried\output01 fs=
(Mon Mar 28 10:16:53 2011) Command finished (1 sec)
It didn't created the file in C:\delete\tried\output01. Again, it has
ignored the bars... So it's still not working
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:15&gt;
      Cpu: Unspecified |
Hi
I have just tried Nightly built for GRASS6.5 and:
(Mon Mar 28 10:31:48 2011)
r.out.xyz input=lsat5_1987_10@landsat output=C:\delete\tried\output02 fs=
path: C:deletetriedoutput02
Output written to C:deletetriedoutput02
(Mon Mar 28 10:31:50 2011) Command finished (1 sec)
And now it«s not even creating the file c:\deletetriedoutput02
I added, in the beggining of the code a print of $GIS_OPT_OUTPUT and it's
printed as:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:16&gt;
      Cpu: Unspecified |
Replying to [comment:16 katrineggert1980]:
it's printed as:
source of the problem are bat scripts, in this case
`$ARCH_DISTDIR\bin\r.out.xyz.bat`
@"%GRASS_SH%" -c '"%GISBASE%/scripts/r.out.xyz" %*'
where '\` are escaped. To make Bash script working on Windows is generally
speaking pain. The future are Python scripts in GRASS 7. I still think
that Pythonized script could replace most of Bash scripts in GRASS 6.
Benefits:
  * maintaining scripts only in one language
  * Python scripts can run on Windows without any problems
Drawback:
  * some new bugs can be introduced, anyway some Bash-related can be fixed
by this conversion
  * Python as requirement
I proposed that some time ago, but it was refused.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:17&gt;
      Cpu: Unspecified |
Ok it makes some sense. If I try to run anything on Msys the \ are
ignored. So this can be a possible solution.
But my question is, why C Modules accepts "\" and Scripts don't.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:18&gt;
      Cpu: Unspecified |
Replying to [comment:18 katrineggert1980]:
Because C modules don't use Bash for parsing the arguments. I would say
rather *Bash* scripts, Python scripts haven't such problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:19&gt;
