GDAL
1
#1321: DebCheck QA: Passing value -1 to sqrt() leads to undefined result
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Vector | Version: 6.4.0
Keywords: v.mapcalc | Platform: Linux
Cpu: Unspecified |
(see #1311)
* ./vector/v.mapcalc/vector.c:127 [error] - Passing value -1 to sqrt()
(v.mapcalc? anyone ever play with this code??)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1321>
GDAL
2
Cpu: Unspecified |
Comment(by neteler):
v.mapcalc should be svn moved out to GRASS Addons.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1321#comment:1>
GDAL
3
Cpu: Unspecified |
Comment(by hamish):
sqrt(-1) to set nan value replaced by 0.0/0.0 in devbr6 and trunk with
r50193-5.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1321#comment:2>
GDAL
4
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Resolution: fixed | Keywords: v.mapcalc
Platform: Linux | Cpu: Unspecified
Changes (by hamish):
* status: new => closed
* resolution: => fixed
* milestone: 6.4.2 => 6.4.4
Comment:
nan creation backported to relbr64 in r57770, closing ticket.
Some more fixes applied so now it builds in all branches (need to run
`make` twice in 6.x as it's missing some Makefile target prereq).
Unless someone wants to take it up, recommend to move trunk's v.mapcalc
code into addons svn since the module remains a work in progress.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1321#comment:3>
