[GRASS-dev] [GRASS GIS] #1325: DebCheck QA: Uninitialized variables
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Compiling | Version: 6.4.0
Keywords: i.ortho.photo, lib/cdhc, lib/gis/gdal.c, r.terraflow, v.delaunay2 | Platform: Linux
      Cpu: Unspecified |
Debian's run of the Cpp check tool automatically found a number of C-code
errors (or potential errors) which need to be reviewed by hand. See grass-
dev ML thread of 13 Jan 2011.
about:
''Cppcheck is a command-line tool that tries to detect bugs that your
C/C++ compiler doesn't see. It is versatile, and can check non-standard
code including various compiler extensions, inline assembly code, etc. Its
internal preprocessor can handle includes, macros, and several
preprocessor commands. While Cppcheck is highly configurable, you can
start using it just by giving it a path to the source code.''
  http://www.linuxjournal.com/content/daca-could-mean-less-bugs-debian
the list of probably-bugs in the 6.4.0 C/C++ code:
   http://qa.debian.org/daca/cppcheck/squeeze/grass_6.4.0~rc6+42329-3.html
CLI analysis program (not Debian specific):
   http://cppcheck.wiki.sourceforge.net
I have split those 154 hits into 16 classes, and will report each class in
an individual bug report.
Run against releasebranch6_4 r42329 (including all patches up to, but not
beyond, 6.4.0-final)
This bug report is for: '''Uninitialized variables'''
  * ./imagery/i.ortho.photo/photo.rectify/ps_cp.c:53 [error] -
Uninitialized variable: msg
  * ./imagery/i.ortho.photo/photo.rectify/ps_cp.c:58 [error] -
  * ./lib/cdhc/enormp.c:51 [error] - Uninitialized variable: x4
  * ./lib/gis/gdal.c:58 [error] - Uninitialized variable: sym
  * ./raster/r.terraflow/sweep.cc:158 [error] - Uninitialized variable:
flowpq
  * ./vector/v.delaunay2/geometry.c:254 [error] - Uninitialized variable:
v_n_o_b
  * ./vector/v.delaunay2/geometry.c:255 [error] - Uninitialized variable:
v_n_d_b
  * ./vector/v.delaunay2/geometry.c:257 [error] - Uninitialized variable:
v_n_o_b
v_n_d_b
  * ./vector/v.delaunay2/geometry.c:291 [error] - Uninitialized variable:
v_p_o_b
  * ./vector/v.delaunay2/geometry.c:292 [error] - Uninitialized variable:
v_p_d_b
  * ./vector/v.delaunay2/geometry.c:294 [error] - Uninitialized variable:
v_p_o_b
v_p_d_b
Modules: i.ortho.photo, lib/cdhc, lib/gis/gdal.c, r.terraflow, v.delaunay2
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1325&gt;
Priority: normal | Milestone: 6.4.4
      Cpu: Unspecified |
Changes (by hamish):
  * milestone: 6.4.2 => 6.4.4
Ticket URL: <https://trac.osgeo.org/grass/ticket/1325#comment:1&gt;
Priority: normal | Milestone: 6.4.5
      Cpu: Unspecified |
  * milestone: 6.4.4 => 6.4.5
Ticket URL: <https://trac.osgeo.org/grass/ticket/1325#comment:2&gt;
