GDAL
March 18, 2011, 7:27am
1
#1327: [python] DebCheck QA: undefined name 'main'
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Python | Version: 6.4.0
Keywords: d.rast3d | Platform: Linux
Cpu: Unspecified |
(see #1311 ,
http://qa.debian.org/daca/pyflakes/sid/grass_6.4.0-2_i386.html )
* ./usr/lib/grass64/etc/gui/scripts/d.rast3d:36: undefined name 'main'
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1327> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
March 18, 2011, 8:12am
2
Cpu: Unspecified |
Comment(by neteler):
The script is here: etc/wxpython/scripts/d.rast3d (no idea why Debian has
it in etc/gui/...).
Differences:
d.rast3d (DebCheck QA complains):
from grass.script import core as grass
if __name__ == "__main__":
options, flags = grass.parser()
main()
p.rast (same directory, DebCheck QA does not complain):
import sys
import os
import grass.script as grass
def construct_command(cmd):
main()
Ticket URL: <https://trac.osgeo.org/grass/ticket/1327#comment:1> ;
GDAL
October 11, 2011, 9:07am
3
Cpu: Unspecified |
A more recent test is at
http://qa.debian.org/daca/pyflakes/sid/grass_6.4.1-1_i386.html (note some
of those modules are no longer in 6.4.2)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1327#comment:2> ;
GDAL
September 5, 2014, 5:14am
4
Priority: minor | Milestone: 6.4.5
Keywords: d.rast3d, code analysis, pyflakes, static code analysis | Platform: Linux
Cpu: Unspecified |
Changes (by wenzeslaus):
* keywords: d.rast3d => d.rast3d, code analysis, pyflakes, static code
analysis
* priority: normal => minor
* milestone: 6.4.2 => 6.4.5
Comment:
Note that you can use `pep8`, `pyflakes`, `pylint` or `pychecker` by
yourself to check the code in order to avoid downstream reporting trivial
errors. See GRASS-specific configuration files in `tools` directory.
See also
[http://grass.osgeo.org/grass71/manuals/libpython/gunittest_testing.html
#analyzing-quality-of-source-code suggestions to test code quality] and
[https://svn.osgeo.org/grass/sandbox/wenzeslaus/grass_py_static_check.py a
script in sandbox] dedicated to this purpose. [https://qa.debian.org/daca/
DACA web page] is also interesting.
However, I'm not sure if we will ever fix this for 6.x. Some of the Python
developers are working on 7.x to minimize number of these "code smells"
for example using `pep8` or `pylint`. So, this might be wontfix for 6.x
but it is a big goal for 7.x which might be described and discussed in
several mega tickets if desired.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1327#comment:3> ;
