[GRASS-dev] [GRASS GIS] #1328: v.in.ogr: bogus table connection created when input Shapefile has spaces in it's name
it's name
Reporter: msieczka | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Vector | Version: svn-releasebranch64
Keywords: | Platform: All
      Cpu: All |
Debian, releasebranch_6_4 r45717.
Import the attached "a a.shp":
$ v.in.ogr dsn=a\ a.shp output=b
Try some operation on it - e.g:
$ v.info -c b
Displaying column types/names for database connection of layer 1:
DBMI-DBF driver error:
Cannot create dbf database: cat /home/grassdata/spearfish60/PERMANENT/dbf/
ERROR: Unable to open database <cat
        /home/grassdata/spearfish60/PERMANENT/dbf/> by driver <d
That's because the table link is bogus:
$ v.db.connect -p b
Vector map <b@PERMANENT> is connected by:
layer <1> table <a> in database <cat
/home/grassdata/spearfish60/PERMANENT/dbf/> through driver <dbf> with key
<b>
which should rather be:
layer <1> table <b> in database
</home/grassdata/spearfish60/PERMANENT/dbf/> through driver <dbf> with key
<cat>
The respective dbln file contains:
1/a a b cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
(Mind the "a a" above, derived from input Shapefile layer name.)
Does GRASS allow spaces in layer names? If so, maybe use a different
separator in dbln's?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1328&gt;
it's name
      Cpu: All |
Comment(by hamish):
see #809.
the dbln file field sep in grass7 has been changed to '|' from space.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1328#comment:1&gt;
it's name
Priority: major | Milestone: 6.4.4
      Cpu: All |
Changes (by neteler):
  * milestone: 6.4.1 => 6.4.4
Comment:
Replying to [comment:1 hamish]:
> see #809.
Since we cannot change the dbln format in GRASS 6, this looks like
"wontfix".
Ticket URL: <http://trac.osgeo.org/grass/ticket/1328#comment:2&gt;
it's name
      Cpu: All |
Comment(by mmetz):
Replying to [comment:2 neteler]:
> > see #809.
"wontfix".
Fixed in 6.5 r52755 by replacing whitespace with underscore in the GRASS
layer name. Works for me with shapefiles with whitespace in the name.
Backport to 6.4?
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1328#comment:3&gt;
it's name
      Cpu: All |
Comment(by mmetz):
Replying to [comment:3 mmetz]:
> > > see #809.
space.
"wontfix".
Backport to 6.4?
Whitespace support in OGR dsn and OGR layer names has been backported to
6.4 in r52765.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1328#comment:4&gt;
it's name
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: All | Cpu: All
Changes (by mmetz):
  * status: new => closed
  * resolution: => fixed
Comment:
Closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1328#comment:5&gt;
