[GRASS-dev] [GRASS GIS] #1331: winGrass: hangs when displaying vector attribute labels
Reporter: morrisxs09 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Display | Version: 6.4.1 RCs
Keywords: wingrass | Platform: MSWindows XP
      Cpu: x86-32 |
Using the spearfish dataset, add the vector map archsites.
In the Layer Manager, click on archsites to open the properties window.
In the Required Tab tick 'Display selected attribute based on attrcol'
In the Labels Tab choose 'str1' in the Name of field to be displayed.
Apply changes - winGrass windows hang; no labels are displayed; only
option is to close all winGrass windows and re-start winGrass.
Using d.vect to display attribute labels via the wxgui command line option
also results in winGrass hanging.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1331&gt;
Priority: critical | Milestone: 6.4.2
Keywords: wingrass, d.vect | Platform: MSWindows XP
      Cpu: x86-32 |
Changes (by hamish):
  * keywords: wingrass => wingrass, d.vect
  * priority: normal => critical
  * milestone: 6.4.1 => 6.4.2
Comment:
perhaps related to #1184
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1331#comment:1&gt;
      Cpu: x86-32 |
Comment(by martinl):
I can confirm this bug, strangely the same command (`d.vect map
display=shape,attr attrcol=col`) works from the command line...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1331#comment:2&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords: wingrass, d.vect
  Platform: MSWindows XP | Cpu: x86-32
Changes (by martinl):
  * status: new => closed
  * resolution: => duplicate
Comment:
Replying to [comment:1 hamish]:
seems to be. Closing as 'duplicate'.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1331#comment:3&gt;
