[GRASS-dev] [GRASS GIS] #134: Add a flag for subgroup listing in i.group
Reporter: nikos | Owner: grass-dev@lists.osgeo.org
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: |
How do you list your subgroup's?
Ticket URL: <http://trac.osgeo.org/grass/ticket/134&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords:
Comment (by neteler):
Currently i.group seems to be broken for subgroups. Otherwise -l should
list
them AFAIK.
Ticket URL: <http://trac.osgeo.org/grass/ticket/134#comment:1&gt;
Comment (by glynn):
Replying to [comment:1 neteler]:
list
> them AFAIK.
No, -l doesn't list subgroups, only files. Essentially, it dumps the
contents of the REF file for either a group or subgroup (depending upon
whether subgroup= was given).
You can list groups with "g.list group", but there doesn't appear to be
any way to list the subgroups of a group.
Ticket URL: <http://trac.osgeo.org/grass/ticket/134#comment:2&gt;
With fixed i.group, it is possible but too complicated to list subgroups:
mapset: landsat
i.group mylsat7_2000 sub=mylsat7_2000
in=lsat7_2000_10,lsat7_2000_20,lsat7_2000_30,lsat7_2000_40,lsat7_2000_50,lsat7_2000_61,lsat7_2000_70,lsat7_2000_80
i.group -l mylsat7_2000
group [mylsat7_2000] references the following cellfiles
lsat7_2000_10 in landsat lsat7_2000_20 in landsat
lsat7_2000_30 in landsat lsat7_2000_40 in landsat
lsat7_2000_50 in landsat lsat7_2000_61 in landsat
lsat7_2000_70 in landsat lsat7_2000_80 in landsat
i.group complete.
-> subgroups missing, not even indicated that they are present in that
group.
"g.list subgroup" does not exist.
i.group -l mylsat7_2000 subgroup=mylsat7_2000
subgroup [mylsat7_2000] of group [mylsat7_2000] references the following
cellfiles
i.group complete.
Now '''only''' the subgroups are listed. But how to know its name to issue
this command?
I see some conceptual problems here. Proposal
- either list automatically also the subgroup(s) when only indicating
group=
- or add a new flag for subgroup(s) listing
- or enhance g.list to ist subgroup names (but looks moreover confusig to
me).
Ticket URL: <http://trac.osgeo.org/grass/ticket/134#comment:3&gt;
Comment (by glynn):
Replying to [comment:3 neteler]:
subgroups:
Let me clarify. You can list the files which make up a subgroup, but you
cannot list the subgroups of a group.
group.
The -l switch just dumps the REF file for a group or subgroup.
Well, each group has its own list of subgroups. g.list only lists "top-
level" entities (rasters, vectors, groups, etc).
Only the contents of a specific subgroup are listed. Adding subgroup=
causes -l to
dump that subgroup's REF file rather than the group's REF file.
> But how to know its name to issue this command?
Exactly.
group=
That could be confusing, particularly if you have scripts parsing the
output of "i.group -l".
That seems like the most viable solution. And there is actually a function
to do this, named I_list_subgroups(), although nothing uses it at present.
FWIW, there is also I_list_groups(), but the only thing which uses it is
I_ask_group_old() (if you type "list"), which in turn is only used by the
i.ortho.photo front-end.
Both of those functions are abominations which uses popen("ls ...") to
enumerate the directory. They also do all of the formatting, and send the
results to the pager. There isn't anything like I_get_[sub]group_ref()
which just returns the information to the caller in a usable form.
to me).
You would need to add a group= parameter to g.list, unless you want it to
enumerate all subgroups of all groups. But that's arguably outside of the
scope of g.list, which isn't supposed to know the details of the various
entity types (it violates that principle for vectors, although I'm not
sure if that's really necessary).
Ticket URL: <http://trac.osgeo.org/grass/ticket/134#comment:4&gt;
  Platform: Unspecified | Cpu: Unspecified
Changes (by hamish):
  * platform: => Unspecified
  * cpu: => Unspecified
Comment:
see also duplicate in #324
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/134#comment:5&gt;
Reporter: nikos | Owner: grass-dev@…
Priority: major | Milestone: 6.4.4
Component: Imagery | Version: unspecified
Keywords: i.group | Platform: All
      Cpu: All |
  * keywords: => i.group
  * platform: Unspecified => All
  * component: Default => Imagery
  * cpu: Unspecified => All
  * milestone: 6.4.0 => 6.4.4
Ticket URL: <https://trac.osgeo.org/grass/ticket/134#comment:6&gt;
      Cpu: All |
Comment(by turek):
I have added (r57704 and r57703) -s flag into G7 i.group module, which
lists subgroups in group.
Stepan
Ticket URL: <http://trac.osgeo.org/grass/ticket/134#comment:7&gt;
      Type: enhancement | Status: closed
  Priority: major | Milestone: 7.0.0
Resolution: fixed | Keywords: i.group
  Platform: All | Cpu: All
Changes (by nikos):
  * status: new => closed
  * resolution: => fixed
  * milestone: 6.4.4 => 7.0.0
Comment:
Thanks Stepan, works perfectly in both (G71 and G7).
Ticket URL: <https://trac.osgeo.org/grass/ticket/134#comment:8&gt;
