GDAL
April 6, 2011, 5:31pm
1
#1343: v.buffer2: difference between Linux 32bit and 64bit
Reporter: mmetz | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-develbranch6
Keywords: v.buffer, v.buffer2 | Platform: Linux
Cpu: x86-64 |
v.buffer2 (not original v.buffer) produces warning messages on Linux 64bit
that are not apparent on Linux 32bit. The initial results differ slightly,
the final result seems to be ok after lots of cleaning.
Reproducible with roadsmajor in nc_spm:
GRASS> v.buffer2 input=roadsmajor@PERMANENT output=roadsmajor_buf1_2000
distance=1000
WARNING: Next edge was visited but it is not the first one !!! breaking
loop
loop
loop
No such warnings, but topological errors with distance=500, warnings like
these but no topological errors with distance=1000 or larger.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1343> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
March 25, 2014, 4:17pm
2
Type: defect | Status: closed
Resolution: fixed | Keywords: v.buffer, v.buffer2
Platform: Linux | Cpu: x86-64
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
The current v.buffer is working well, closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1343#comment:1> ;
GDAL
April 9, 2014, 6:30am
3
Type: defect | Status: reopened
Resolution: | Keywords: v.buffer, v.buffer2
Changes (by mmetz):
* status: closed => reopened
* resolution: fixed =>
Comment:
Reopening because v.buffer works only in GRASS7 and only if it uses the
GEOS algorithm. A backport to GRASS6 is possible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1343#comment:2> ;
GDAL
April 21, 2014, 4:22pm
4
Priority: critical | Milestone: 7.0.0
* keywords: v.buffer, v.buffer2 => v.buffer
* priority: normal => critical
Comment:
(v.buffer2 is v.buffer for a while)
See also #2223
See also #1464
Ticket URL: <https://trac.osgeo.org/grass/ticket/1343#comment:3> ;
GDAL
April 29, 2014, 3:33pm
5
Comment(by neteler):
v.buffer has been rebased on GEOS in r59970 which you now need to compile
the module.
Please test the updated version of v.buffer in 6.4.svn.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1343#comment:4> ;
GDAL
July 21, 2014, 10:44pm
6
Priority: critical | Milestone: 6.4.5
* milestone: 7.0.0 => 6.4.5
Comment:
Done in G7, downgrading to G6 where GEOS support was added in r59970.
# G6:
v.buffer input=roadsmajor@PERMANENT output=roadsmajor_buf1_2000
distance=1000
Appears to work, closing (reopen if not).
Some fun performance comparison:
* G6.4.svn: 43.19 sec
* G7.0.svn: 7.59 sec
Ticket URL: <https://trac.osgeo.org/grass/ticket/1343#comment:5> ;
GDAL
July 21, 2014, 10:45pm
7
* status: reopened => closed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1343#comment:6> ;
