[GRASS-dev] [GRASS GIS] #1345: backport ctypes to relbr64
Reporter: hamish | Owner: grass-dev@…
     Type: task | Status: new
Priority: major | Milestone: 6.4.2
Component: Python ctypes | Version: svn-releasebranch64
Keywords: | Platform: All
      Cpu: All |
placeholder ticket for discussing backporting ctypes to the 6.4 branch.
IMHO solid python scripting is an important feature to get working for
end-users in the 6.4 branch after the next point release. lots of users
want it.
(Although in 6.x-stable I'd totally oppose replacing the existing shell
scripts/ with their many many years of testing & stabilization)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1345&gt;
      Cpu: All |
Comment(by martinl):
Replying to [ticket:1345 hamish]:
my opinion is different as I mentioned earlier, you are right that bash
scripts could be more stable than their python version. Anyway we are
discovering new and new bugs in bash scripts (which is normal), some of
them are hard to fix, see e.g. #1310. Unfortunately most of them are quite
critical. Some of them are remaining open, generally speaking maintaining
bash scripts for winGRASS is a big pain. Bearing in mind our man power in
GRASS developer team I think it would be better solution to replace bash
scripts by python in devbr6. Fix bugs which has been introduced during
conversion from Bash script (which is easy). Make them solid and working
on Windows. And later to backported them to relbr64. It's just my opinion.
I would be happy to hear also other devs from the community.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1345#comment:1&gt;
Reporter: hamish | Owner: martinl
     Type: task | Status: assigned
      Cpu: All |
Changes (by martinl):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Comment:
want it.
I agree that ctypes are needed to be backported to relbr64, at least there
are two wxGUI extensions which are depending on ctypes (digitizer and 3d
view). I took liberty to backport ctypes in r45937
Ticket URL: <http://trac.osgeo.org/grass/ticket/1345#comment:2&gt;
      Type: task | Status: closed
Resolution: fixed | Keywords:
  Platform: All | Cpu: All
Changes (by hamish):
  * status: assigned => closed
  * resolution: => fixed
Comment:
Replying to [comment:2 martinl]:
thanks. I really feel this will be a good thing.
  I believe the rest of this conversation belongs on the -dev list, so I'll
state my piece and get out; closing the bug.
Replying to [comment:1 martinl]:
scripts
uber-irrelevant nit-pick: technically bourne scripts, not bash scripts.
(-> component renamed)
> Anyway we are discovering new and new bugs in bash scripts (which is
normal),
No, really not many at all- most of the scripts have been in use for 5-15+
years now. Maybe a few more bugs than libgis or the older raster modules,
but still very few. Of the 15 or so edits to shell scripts in the last 6
months, most are either edits to relatively new additions (v.db.*,
r.in.w{m|f}s, simple quoting of variables for WinGrass), or long
known/forgotten bugs (yesterday I applied a 3 yr old patch from Brad to
v.in.mapgen and fixed a quite rare one which survived for 9 years without
notice until last week).
> some of them are hard to fix, see e.g. #1310. Unfortunately most of them
are
> quite critical. Some of them are remaining open,
** those are not bugs in the shell scripts. The shell scripts themselves
are mature, very well tested, and mostly bug free (AFAWK). 'Til now we
have not had to compromise the stability of the linux/mac stable branches
to please MS Windows. IMHO it would be a rotten bother to start that now.
The bugs you refer to are in the build system (.bat wrappers), wxGUI,
MSys, and general MS Windows weirdness. WinGrass users new to the command
line will need to learn to "quote" path names regardless of bourne/python
scripts, due to the ubiquitous space in path names. If the \slash trouble
went away instantly, the space problem would still confound argc,argv.
The solution to that 'bug' is educating users that path names always have
to be quoted.
> generally speaking maintaining bash scripts for winGRASS is a big pain.
I think that's because hardly anyone is working on the problem, not
because the problems are especially or fundamentally deep. It's not a
question of devpower, it's a question of focusing/encouraging volunteers
to spend some time on chores which don't immediately benefit them (but
certainly do in the long run). As for me, I've been neglecting it for
months, but for my part can jump back into this effort sometime in early
May (go qemu-kvm!). i.e. while problematic, I am not convinced the
WinGrass + .sh issues are fatal or even that deep. The solution to this
'bug' is to educate ourselves more about Windows's weirdness, which will
be useful knowledge anyway.
And even if it is a pain, we should bear it and deal with it -- one of the
tenets of a having a stable branch is that you can trust the code stays in
a known state, warts and all. You work around the ugliness and fix bugs
along the path of least change in an effort to minimize the chance of
unintended consequences, and maximizing experience of the behavior.
Swapping out all the scripts is just too huge a leap in the codebase.
> Bearing in mind our man power in GRASS developer team
as far as manpower goes, as long as grass 6 is maintained, and probably
after, I'll help maintain the shell scripts (luckily they don't need
much), and lend a hand as I can to help the small wingrass team deal with
msys troubles (but then next few weeks are insane for me).
> I think it would be better solution to replace bash scripts by python in
devbr6.
** This is a stable branch. devbr6 (IMNSHO) is for getting things ready
and testing before backporting to 6.4.x. If the decision has not been made
for something to eventually go into 6.4, then it does not belong in 6.5.
Moving something into 6.5 as a wedge to get it into 6.4 later is not
behavior I ever hope to find in GRASS, as it will be the end of the
project being fun for me.
> Fix bugs which has been introduced during conversion from Bash script
(which is
> easy).
It is hard. It doesn't matter how good you are or how much cleaner the new
language is -- you simply can't replace a decade of widespread testing on
a huge diversity of systems just like that. It takes time, lots of it.
When grass7 is ready, they'll be rock solid. I'd so much rather be having
this conversation about how best to implement a new/future improvement in
trunk, or doing detective work on specific bugs.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1345#comment:3&gt;
