#1352: Mismatch between overwrite parameter in GCPManager and v.transform
Reporter: rangoy | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone:
Component: Default | Version: svn-releasebranch64
Keywords: | Platform: Unspecified
Cpu: Unspecified |
It appears that commit [45931] introduces a mismatch in the overwrite
parameter in
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcpmanager.py
(arround line 1395-1396)
v.transform still wants the overwrite flag to be written as "--o", but
this changeset removes one of the "-"s.
I don't know which of the modules are wrong, but I fixed it temporarily by
applying this patch;
Reporter: rangoy | Owner: martinl
Type: defect | Status: assigned
Priority: minor | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: georectify | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:1352 rangoy]:
by applying this patch;
The patch is incorrect; the flags= parameter should never contain a dash.
The patch only works as a side-effect of the naive way in which the flags=
parameter is currently handled.
The correct way to enable overwrite is to pass "overwrite = True".
