#1359: No Startup
Reporter: ke6iyc | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Startup | Version: 6.4.0
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
GRASS (Latest download) will not start.
Full text of terminal session follows:
Last login: Mon May 9 22:56:18 on ttys000
'/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
You have new mail.
brian-gieryks-macbook-pro-3:~ ke6iyc$
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.6.1 found.
WELCOME TO GRASS Version 6.4.1 2011
1) Have at your side all available GRASS tutorials
2) When working on your location, the following materials
are extremely useful:
- A topo map of your area
- Current catalog of available computer maps
Starting GRASS ...
File
"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py", line
34, in <module>
from gui_modules import globalvar
File "/Users/Shared/src/GRASS/grass-6.4.1-snow/dist.i386-apple-
darwin10.7.0/etc/wxpython/gui_modules/globalvar.py", line 79, in <module>
File "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-
packages/wx-2.8-mac-unicode/wx/__init__.py", line 45, in <module>
packages/wx-2.8-mac-unicode/wx/_core.py", line 4, in <module>
ImportError:
dlopen(/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so,
2): Library not loaded:
/Library/Frameworks/UnixImageIO.framework/Versions/C/UnixImageIO
Referenced from:
/Applications/GRASS-6.4.app/Contents/MacOS/lib/libwx_macud-2.8.0.dylib
Reason: image not found
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
dyld: Library not loaded:
/Library/Frameworks/GDAL.framework/Versions/1.8/GDAL
Referenced from:
/Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.dylib
/Applications/GRASS-6.4.app/Contents/MacOS/etc/Init.sh: line 630: 12084
Trace/BPT trap "$ETC/set_data"
logout
I am seeing this as well, with some slight differences. It appears that
GRASS is referring to a specific version of UnixImageIO, which is
different than what the framework installer (GDAL Complete 1.9) installed.
ImportError:
/Library/Frameworks/UnixImageIO.framework/Versions/D/UnixImageIO
% ls -l /Library/Frameworks/UnixImageIO.framework/Versions/
total 8
lrwxr-xr-x 1 root admin 1 Sep 2 09:08 Current -> E
drwxrwxr-x 7 root admin 238 Jun 15 09:42 E
Yes, I noticed this recently. It is still not really a GRASS bug, but a
dependency packaging problem. When I rebuilt everything for the new
UnixImageIO, I forgot wxpython. Either wait for a new installer, or
install Barton's package.
Note: do not try to fix UnixImageIO with a symlink for the D version, D
and E versions are incompatible.
