[GRASS-dev] [GRASS GIS] #136: sqlite: confusing error message
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: sqlite |
I tried to import
cat tin.asc
cat,x,y,z
1,0,0,0
1,0,10,1
1,0,20,2
2,10,0,1
2,10,10,3
2,10,20,4
3,20,0,1
3,20,10,4
3,20,20,5
Import:
v.in.ascii -z tin.asc out=tinpoints z=3 fs=comma skip=1 cat=1 --o
Scanning input for column types...
Maximum input row length: 10
Maximum number of columns: 4
Minimum number of columns: 4
Importing points...
DBMI-SQLite driver error:
Error in sqlite3_step():
SQL logic error or missing database
ERROR: Unable to insert new record: insert into tinpoints values ( 1, 0,
       10, 1)
but this is the wrong (confusing) error:
Trying the same on console:
sqlite3 ddd.sb
SQLite version 3.4.2
Enter ".help" for instructions
sqlite> create table tinpoints ( int_1 integer, int_2 integer, int_3
integer, int_4 integer );
sqlite> create unique index tinpoints_int_1 on tinpoints ( int_1 );
sqlite> insert into tinpoints values ( 1, 0, 0, 0);
sqlite> insert into tinpoints values ( 1, 0, 10, 1);
SQL error: column int_1 is not unique
sqlite>
That's the right error.... would like to see that message in GRASS, too.
The code is in
db/drivers/sqlite/execute.c line 47
strange that it isn't identical...
Ticket URL: <http://trac.osgeo.org/grass/ticket/136&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Reporter: neteler | Owner: grass-dev@…
Component: Default | Version: svn-trunk
Keywords: sqlite | Platform: Unspecified
      Cpu: Unspecified |
Changes (by mmetz):
  * platform: => Unspecified
  * cpu: => Unspecified
Comment:
Fixed in trunk r48530.
Please test.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/136#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: sqlite
  Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
With wrong parameters the error message is better now:
GRASS 6.4.3svn (nc_spm_08):~ > v.in.ascii -z tin.asc out=tinpoints z=3
Column: 1 type: integer
Column: 2 type: integer
Column: 3 type: integer
Column: 4 type: integer
Importing points...
        10, 1)
With correct parameters it works:
GRASS 6.4.3svn (nc_spm_08):~ > v.in.ascii -z tin.asc out=tinpoints x=2 y=3
z=4 fs=comma skip=1 cat=1 --o
Importing points...
  100%
Building topology for vector map <tinpoints>...
Registering primitives...
9 primitives registered
9 vertices registered
Building areas...
  100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
  100%
Number of nodes: 9
Number of primitives: 9
Number of points: 9
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
v.in.ascii complete.
Hence, closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/136#comment:2&gt;
