[GRASS-dev] [GRASS GIS] #1364: configure fails to detect X11 on OS X
Reporter: snorfalorpagus | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Compiling | Version: unspecified
Keywords: | Platform: MacOSX
      Cpu: OSX/Intel |
Configure was refusing to detect X11, despite specification of --with-x,
--x-libraries and --x-includes. This is due to OS X using a different
shared library suffix (*.dylib) to other OSs, which was missed out of the
search path. Applies to 6.4, 6.5 and 7. Patch attached (for 6.5).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1364&gt;
      Cpu: OSX/Intel |
Comment(by glynn):
Replying to [ticket:1364 snorfalorpagus]:
There's no point patching the configure script; it's generated by autoconf
from configure.in and aclocal.m4, so any changes will be lost the next
time that the source files are updated (unless we remember to keep
patching it, which is unlikely to happen).
The X stuff is handled by autoconf's AC_PATH_XTRA macro, which uses
AC_PATH_X_XMKMF, which doesn't recognise the .dylib suffix. At least, the
version from 2.13 doesn't. Updating to a later version of autoconf is
probably worthwhile, but it's potentially a lot of work.
In the meantime, it might be possible to override AC_PATH_X_XMKMF with a
fixed local version.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1364#comment:1&gt;
      Cpu: OSX/Intel |
Comment(by kyngchaos):
I don't have a problem detecting X11. I've always specified --with-x,
--x-includes and --x-libraries. If you use --x-includes and
--x-libraries, configure never gets to the parts to check for the
existence of library files (where your patches apply), it just assumes
you're right.
if test "x$with_x" = xno; then
   # The user explicitly disabled X.
   have_x=disabled
else
   if test "x$x_includes" != xNONE && test "x$x_libraries" != xNONE; then
     # Both variables are already set.
     have_x=yes
   else
# check for libs and includes...
   fi
fi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1364#comment:2&gt;
Component: Compiling | Version: svn-develbranch6
Keywords: configure.in, X11 | Platform: MacOSX
      Cpu: OSX/Intel |
Changes (by hamish):
  * keywords: => configure.in, X11
  * version: unspecified => svn-develbranch6
Comment:
any update?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1364#comment:3&gt;
Priority: normal | Milestone: 6.4.4
      Cpu: OSX/Intel |
Changes (by neteler):
  * milestone: => 6.4.4
Ticket URL: <https://trac.osgeo.org/grass/ticket/1364#comment:4&gt;
