#1366: When GRASS is launched it stops because the MSVCR71.DLL is not found
Reporter: GABRIEL | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone:
Component: Installation | Version: unspecified
Keywords: MSVCR71.dll, error when starting GRASS | Platform: MSWindows XP
Cpu: x86-64 |
When GRASS is launched using the screen icon whose properties are:
"C:\Archivos de programa\GRASS 6.4.1\grass64.bat" -wxpython
inmediately the message (translated from Spanish¨:
¨Error when starting the application because the MSCVR71.DLL was not
found. The reinstallation of the application could solve the problem¨
I´ve installed later the OSGEO4W and the problem continues.
Then I´ve reinstalled GRASS and the message appears again.
I was using GRASS, Linux Red Hat for a long time, but now I need it in my
notebook that has a Windows XP(32) operating system. Thanks.
Cpu: x86-64 |
Comment(by hellik):
Replying to [ticket:1366 GABRIEL]:
my notebook that has a Windows XP(32) operating system. Thanks.
Cpu: x86-64 |
Comment(by hamish):
probably you need to install vcredist_x86, or similar,
Type: defect | Status: closed
Priority: critical | Milestone: 6.4.3
Resolution: duplicate | Keywords: MSVCR71.dll, error when starting GRASS
Platform: MSWindows XP | Cpu: x86-64
Changes (by hamish):
