[GRASS-dev] [GRASS GIS] #1373: Wrong stereographic grid tracing and labeling in stereographic projection
Reporter: alf | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Display | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: Unspecified |
When using stereographic projection set, for example, at the south pole,
d.grid's geographical output is messy: grids are not completely traced and
the labels accumulates at the corners at various angles.
Find attached a screenshot of the output for a 1000x1000 km area centered
at the south pole, and a sample location (to reproduce the screenshot,
use: d.grid -g size=10).
Alessandro Frigeri
Ticket URL: <http://trac.osgeo.org/grass/ticket/1373&gt;
Priority: normal | Milestone: 6.5.0
Keywords: d.grid | Platform: All
      Cpu: Unspecified |
Changes (by hamish):
  * keywords: => d.grid
  * milestone: => 6.5.0
Comment:
known bug.
for the stereographic images on the raster screenshots page (1,2) the
work-around I used was to use v.mkgrid in a lat/lon location which I then
pulled into the stereographic projection with v.proj.
(1) http://grass.osgeo.org/screenshots/images/day_on_earth_N.png
(2) http://grass.osgeo.org/screenshots/images/day_on_earth_S.png
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1373#comment:1&gt;
      Cpu: Unspecified |
Comment(by hamish):
hopefully the label text is a little better now. grid lines around
anomalies still need work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1373#comment:2&gt;
