[GRASS-dev] [GRASS GIS] #1381: wxgui: add monitor calibrate option to prefs
Reporter: hamish | Owner: grass-dev@…
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-releasebranch64
Keywords: map scale | Platform: All
      Cpu: All |
currently the wxGUI offers a 1:xxxxx map scale option in the status bar of
the Map Display window. By definition this is the ratio of the distance
(in map units) on the ground to the distance (in map units) on the
rendered display.
Without knowing the monitor size + resolution the currently displayed
value seems to just be like region_distance/number_of_pixels. So it's
missing being multiplied by a `pixels_per_meter` factor (if map units were
in meters..).
source:grass/trunk/gui/wxpython/gui_modules/mapdisp.py@46524#L742
X11 and I suspect OSX & MS Windows provide some info about the monitor,
but in the past those reported values have been quite unreliable. Maybe it
is a little better now and could be used for setting a seed value?
I propose to do as GIMP and Inkscape do, and offer a calibration tool in
the Preferences menu's "Display" setting tab. Then we know the DPI to map-
units conversion factor specific to the user's screen resolution and
monitor size, and after calibration they can trust the scale shown in the
info bar. Either that or remove the currently erroneous option altogether.
I've just looked at the version in Inkscape 0.48.1 and it seems quite nice
and easy to use. Inkscape is written using wx(C++) but maybe there is
still some pre-fab code in there we could quickly adapt?
The `gv` program uses another way, in its State->Setup options it lets you
define "Screen size (mm): ___ x ___"
note that this isn't an issue for ps.map, because we already know the
exact dimensions of the paper sizes.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1381&gt;
      Cpu: All |
Comment(by hamish):
tooltip explaining that 'map scale' as currently given is only really
accurate to within the order of magnitude committed in trunk and devbr6 in
r48228,9.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1381#comment:1&gt;
Priority: major | Milestone: 6.4.3
      Cpu: All |
Changes (by vincent):
  * milestone: 6.5.0 => 6.4.3
Comment:
OK for the tooltip
The notion of display scale is very useful when performing on-the-fly
snapshots of the display. Would be great if one could precisely trim his
display settings.
I understand retrieving monitor size is not straight, and obviously much
platform-dependant...
GIMP's method relies on monitor information delivered by xdpyinfo (am I
wrong ?), but sometimes this info is not reliable.
Could the first-aid solution be an option in the Display preferences menu
(2 input datafields) that allows user to set manually his vertical- &
horizontal resolutions ? after all, we can believe the user who cares for
this parameter is aware of how to calculate his proper values, no ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1381#comment:2&gt;
      Cpu: All |
Changes (by hamish):
  * milestone: 6.4.3 => 6.5.0
Comment:
(as a matter of short time to the next release this probably won't be in
6.4.3, but look out for it in future versions)
fwiw, for ideas on how to do it:
In my version of GIMP it is in Edit -> Preferences -> Display.
Then in ''Monitor Resolution'' there is:
  * Detect automatically (currently XX x YY ppi) <- probably from xdpyinfo
  * Enter manually
    * Horiz Vert units
or
  [Calibrate]
In the calibrate window you get a horizontal and vertical ruler in a
window, you put a ruler up to the screen and type in the true length of
the bars. (and then don't change your monitor or resolution :slight_smile:
I've no idea how to get that on MS Windows or a Mac, I suppose it is
possible somehow and the GIMP code is open to borrow from, but I think a
universal solution would be better. In practice I've found those reported
sizes not always very accurate. Probably it is better these days post-CRT.
menu
for this
Entering the measured width and height of the monitor screen, and the
current resolution sounds easy enough first step, but to avoid errors/be
easy I would have the program do all the calculations, just have the user
enter the distances.
For ease of use, I still like Inkscape's calibration method the best: you
drag the slider until the on-screen ruler matches your real one. (File ->
Inkscape Prefs -> Interface -> Zoom correction factor) Then it does the
math. Although theirs is just horizontal; I've noticed on one of my
systems the correct scale factor is not the same for horiz/vert.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1381#comment:3&gt;
