#139: wxgrass: Allow disabling of remove layer promp in GIS Layer Manager
Reporter: epatton | Owner: grass-dev@lists.osgeo.org
Priority: trivial | Milestone: 6.4.0
Component: Python | Version: svn-trunk
Keywords: Layer Manager, prompt, remove layer |
Would it would be possible to disable the prompting from the Layer Manager
"Do you want to remove map layer <map> from layer tree" globally from the
preferences? It gets a little tedious doing this for each map every time.
Confirmed, works great! Thanks again. I don't see any problem with the
wording.
Closing ticket,
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/139#comment:2>
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies. GRASS is official project of the Open Source Geospatial Foundation.
Martin:
> 'Ask when removing map layer from layer tree' (maybe you can suggest
better
> wording here)
I think that sounds fine.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/139#comment:3>
