#1393: v.db.join and "duplicate column name"
Reporter: lucadelu | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: Vector | Version: unspecified
Keywords: vector db join | Platform: All
Cpu: Unspecified |
Today I found a problem when I try to join tables with v.db.join. The
problem was that the key columns have the same name and the join returned
an error.
v.db.join map=confini_provinciali column=PROV otable=tabprovince ocol=PROV
DBMI-SQLite driver error:
Error in sqlite3_prepare():
duplicate column name: PROV
ERROR: Error while executing: 'ALTER TABLE confini_provinciali ADD COLUMN
PROV CHARACTER
ERROR: Cannot continue (problem adding column).
ERROR: Cannot continue.
To solve this problem I adding two flag that they permit to pass it.
One permit to not copy the join column, the data of join column are
already present on the map table; the other flag permit to copy all the
column from other_table adding "_o" to the columns name. This is the idea
used by v.overlay that add "_a" at the columns of ainput and "_b" for the
columns of binput. In attachment you can found the patch, test it and if
you think that it's a good solution please add it to the svn
Ticket URL: <http://trac.osgeo.org/grass/ticket/1393>
