#1395: osgf generates error compiling on Mac OS X
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Component: Compiling | Version: svn-trunk
Keywords: osgf nviz | Platform: MacOSX
Cpu: OSX/Intel |
I just updated from the SVN and also installed the newest frameworks. osgf
fails to compile with the following error. This (I think) also causes nviz
to fail to compile too.
cmb-mbp-3:grass70_dev cmbarton$ cd
/Users/Shared/grass_dev/grass70_dev/lib/ogsf
cmb-mbp-3:ogsf cmbarton$ make
cc -dynamiclib -compatibility_version 7.0 -current_version 7.0
-install_name
/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib/libgrass_ogsf.7.0.svn.dylib
-o /Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/lib/libgrass_ogsf.7.0.svn.dylib
-L/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/lib
-arch i386 -arch x86_64 OBJ.i386-apple-darwin10.8.0/GK2.o OBJ.i386
-apple-darwin10.8.0/GP2.o OBJ.i386-apple-darwin10.8.0/GS2.o OBJ.i386
-apple-darwin10.8.0/GSX.o OBJ.i386-apple-darwin10.8.0/GS_util.o OBJ.i386
-apple-darwin10.8.0/GV2.o OBJ.i386-apple-darwin10.8.0/GVL2.o OBJ.i386
-apple-darwin10.8.0/Gp3.o OBJ.i386-apple-darwin10.8.0/Gs3.o OBJ.i386
-apple-darwin10.8.0/Gv3.o OBJ.i386-apple-darwin10.8.0/Gvl3.o OBJ.i386
-apple-darwin10.8.0/gk.o OBJ.i386-apple-darwin10.8.0/gp.o OBJ.i386-apple-
darwin10.8.0/gpd.o OBJ.i386-apple-darwin10.8.0/gs.o OBJ.i386-apple-
darwin10.8.0/gs_bm.o OBJ.i386-apple-darwin10.8.0/gs_norms.o OBJ.i386
-apple-darwin10.8.0/gs_query.o OBJ.i386-apple-darwin10.8.0/gsd_cplane.o
OBJ.i386-apple-darwin10.8.0/gsd_fonts.o OBJ.i386-apple-
darwin10.8.0/gsd_fringe.o OBJ.i386-apple-darwin10.8.0/gsd_img_mpeg.o
OBJ.i386-apple-darwin10.8.0/gsd_img_ppm.o OBJ.i386-apple-
darwin10.8.0/gsd_img_tif.o OBJ.i386-apple-darwin10.8.0/gsd_label.o
OBJ.i386-apple-darwin10.8.0/gsd_legend.o OBJ.i386-apple-
darwin10.8.0/gsd_objs.o OBJ.i386-apple-darwin10.8.0/gsd_prim.o OBJ.i386
-apple-darwin10.8.0/gsd_surf.o OBJ.i386-apple-darwin10.8.0/gsd_views.o
OBJ.i386-apple-darwin10.8.0/gsd_wire.o OBJ.i386-apple-
darwin10.8.0/gsdiff.o OBJ.i386-apple-darwin10.8.0/gsdrape.o OBJ.i386
-apple-darwin10.8.0/gsds.o OBJ.i386-apple-darwin10.8.0/gsget.o OBJ.i386
-apple-darwin10.8.0/gv.o OBJ.i386-apple-darwin10.8.0/gv_quick.o OBJ.i386
-apple-darwin10.8.0/gvd.o OBJ.i386-apple-darwin10.8.0/gvl.o OBJ.i386
-apple-darwin10.8.0/gvl_calc.o OBJ.i386-apple-darwin10.8.0/gvl_calc2.o
OBJ.i386-apple-darwin10.8.0/gvl_file.o OBJ.i386-apple-darwin10.8.0/gvld.o
OBJ.i386-apple-darwin10.8.0/trans.o -lgrass_bitmap.7.0.svn
-lgrass_g3d.7.0.svn -lgrass_vector.7.0.svn -lgrass_raster.7.0.svn
-lgrass_gis.7.0.svn -L/Library/Frameworks/UnixImageIO.framework/unix/lib
-ltiff -framework OpenGL -framework AGL -framework ApplicationServices
Undefined symbols:
"_db_get_value_int", referenced from:
_Gp_load_sites_thematic in Gp3.o
"_db_select_value", referenced from:
"_db_start_driver_open_database", referenced from:
"_db_get_value_string", referenced from:
ld: symbol(s) not found
collect2: ld returned 1 exit status
Undefined symbols:
lipo: can't open input file:
/var/folders/AK/AKpYwDw1EoWI+fFF02nvRk+++TI/-Tmp-//ccAxZpeP.out (No such
file or directory)
make: *** [/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/lib/libgrass_ogsf.7.0.svn.dylib] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1395>
