[GRASS-dev] [GRASS GIS] #1396: wxnviz command not compiling
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: wxnviz command | Platform: MacOSX
      Cpu: OSX/Intel |
All of wxnviz now compiles except for ../nviz2/cmd. It gives the following
error:
cmb-mbp-3:grass70_dev cmbarton$ cd
/Users/Shared/grass_dev/grass70_dev/visualization/nviz2/cmd
cmb-mbp-3:cmd cmbarton$ make GDAL_DYNAMIC=gcc -g -O2 -arch i386 -arch
x86_64 -I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/include -I/Users/Shared/grass_dev/grass70_dev/dist.i386
-apple-darwin10.8.0/include -D_FILE_OFFSET_BITS=64
-I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/include
-I/Library/Frameworks/UnixImageIO.framework/unix/include
-I/Library/Frameworks/GDAL.framework/Versions/1.8/Headers
-I/Library/Frameworks/GEOS.framework/Versions/3/unix/include
-DPACKAGE=\""grassmods"\"
-o OBJ.i386-apple-darwin10.8.0/vector.o -c vector.c
In file included from
/System/Library/Frameworks/CorShared/grass_dev/grass70_dev/dist.i386
-apple-darwin10.8.0/man/man1/v.net.spanningtree.1
darwin10.8.0/man/man1/v.net.steiner.1
darwin10.8.0/man/man1/v.net.timetable.1
darwin10.8.0/man/man1/v.net.visibility.1
darwin10.8.0/man/man1/v.normal.1
darwin10.8.0/man/man1/v.out.ascii.1
darwin10.8.0/man/man1/v.out.dxf.1
darwin10.8.0/man/man1/v.out.gps.1
darwin10.8.0/man/man1/v.out.ogr.1
darwin10.8.0/man/man1/v.out.pov.1
darwin10.8.0/man/man1/v.out.svg.1
darwin10.8.0/man/man1/v.out.vtk.1
darwin10.8.0/man/man1/v.outlier.1
darwin10.8.0/man/man1/v.overlay.1
darwin10.8.0/man/man1/v.parallel.1
darwin10.8.0/man/man1/v.patch.1
darwin10.8.0/man/man1/v.perturb.1
darwin10.8.0/man/man1/v.proj.1
darwin10.8.0/man/man1/v.qcount.1
darwin10.8.0/man/man1/v.random.1
darwin10.8.0/man/man1/v.rast.stats.1
darwin10.8.0/man/man1/v.reclass.1
darwin10.8.0/man/man1/v.report.1
darwin10.8.0/man/man1/v.sample.1
darwin10.8.0/man/man1/v.segment.1
darwin10.8.0/man/man1/v.select.1
darwin10.8.0/man/man1/v.split.1
darwin10.8.0/man/man1/v.support.1
darwin10.8.0/man/man1/v.surf.bspline.1
darwin10.8.0/man/man1/v.surf.idw.1
darwin10.8.0/man/man1/v.surf.rst.1
darwin10.8.0/man/man1/v.to.3d.1
darwin10.8.0/man/man1/v.to.db.1
darwin10.8.0/man/man1/v.to.points.1
darwin10.8.0/man/man1/v.to.rast.1
darwin10.8.0/man/man1/v.to.rast3.1
darwin10.8.0/man/man1/v.transform.1
darwin10.8.0/man/man1/v.type.1
darwin10.8.0/man/man1/v.univar.1
darwin10.8.0/man/man1/v.vol.rst.1
darwin10.8.0/man/man1/v.voronoi.1
darwin10.8.0/man/man1/v.what.1
darwin10.8.0/man/man1/v.what.rast.1
darwin10.8.0/man/man1/v.what.vect.1
darwin10.8.0/man/man1/variables.1
darwin10.8.0/man/man1/vector.1
darwin10.8.0/man/man1/vectorintro.1
darwin10.8.0/man/man1/wxGUI.Attribute_Table_Manager.1
darwin10.8.0/man/man1/wxGUI.GCP_Manager.1
darwin10.8.0/man/man1/wxGUI.Modeler.1
darwin10.8.0/man/man1/wxGUI.Nviz.1
darwin10.8.0/man/man1/wxGUI.PsMap.1
darwin10.8.0/man/man1/wxGUI.Vector_Digitizer.1
darwin10.8.0/man/man1/wxGUI.1
darwin10.8.0/man/man1/wximgview.1
darwin10.8.0/man/man1/wxpyimgview.1
darwin10.8.0/man/man1/xganim.1
make[4]: `/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/man/man1/cairodriver.1' is up to date.
darwin10.8.0/man/man1/d.barscale.1' is up to date.
darwin10.8.0/man/man1/d.colorlist.1' is up to date.
darwin10.8.0/man/man1/d.colortable.1' is up to date.
darwin10.8.0/man/man1/d.correlate.1' is up to date.
darwin10.8.0/man/man1/d.erase.1' is up to date.
darwin10.8.0/man/man1/d.font.1' is up to date.
darwin10.8.0/man/man1/d.fontlist.1' is up to date.
darwin10.8.0/man/man1/d.geodesic.1' is up to date.
darwin10.8.0/man/man1/d.graph.1' is up to date.
darwin10.8.0/man/man1/d.grid.1' is up to date.
darwin10.8.0/man/man1/d.his.1' is up to date.
darwin10.8.0/man/man1/d.histogram.1' is up to date.
darwin10.8.0/man/man1/d.info.1' is up to date.
darwin10.8.0/man/man1/d.labels.1' is up to date.
darwin10.8.0/man/man1/d.legend.1' is up to date.
darwin10.8.0/man/man1/d.linegraph.1' is up to date.
darwin10.8.0/man/man1/d.nviz.1' is up to date.
darwin10.8.0/man/man1/d.path.1' is up to date.
darwin10.8.0/man/man1/d.polar.1' is up to date.
darwin10.8.0/man/man1/d.profile.1' is up to date.
darwin10.8.0/man/man1/d.rast.arrow.1' is up to date.
darwin10.8.0/man/man1/d.rast.edit.1' is up to date.
darwin10.8.0/man/man1/d.rast.1' is up to date.
darwin10.8.0/man/man1/d.rast.leg.1' is up to date.
darwin10.8.0/man/man1/d.rast.num.1' is up to date.
darwin10.8.0/man/man1/d.rgb.1' is up to date.
darwin10.8.0/man/man1/d.rhumbline.1' is up to date.
darwin10.8.0/man/man1/d.shadedmap.1' is up to date.
darwin10.8.0/man/man1/d.text.1' is up to date.
darwin10.8.0/man/man1/d.thematic.area.1' is up to date.
darwin10.8.0/man/man1/d.title.1' is up to date.
darwin10.8.0/man/man1/d.vect.chart.1' is up to date.
darwin10.8.0/man/man1/d.vect.1' is up to date.
darwin10.8.0/man/man1/d.vect.thematic.1' is up to date.
darwin10.8.0/man/man1/d.where.1' is up to date.
VERSION_NUMBER=7.0.svn /Users/Shared/grass_dev/grass70_dev/dist.i386
-apple-darwin10.8.0/tools/g.html2man.py
darwin10.8.0/docs/html/database.html
darwin10.8.0/man/man1/database.1
darwin10.8.0/man/man1/databaseintro.1' is up to date.
darwin10.8.0/man/man1/db.columns.1' is up to date.
darwin10.8.0/man/man1/db.connect.1' is up to date.
darwin10.8.0/man/man1/db.copy.1' is up to date.
darwin10.8.0/man/man1/db.createdb.1' is up to date.
darwin10.8.0/man/man1/db.databases.1' is up to date.
darwin10.8.0/man/man1/db.describe.1' is up to date.
darwin10.8.0/man/man1/db.drivers.1' is up to date.
darwin10.8.0/man/man1/db.dropcolumn.1' is up to date.
darwin10.8.0/man/man1/db.dropdb.1' is up to date.
darwin10.8.0/man/man1/db.droptable.1' is up to date.
darwin10.8.0/man/man1/db.execute.1' is up to date.
darwin10.8.0/man/man1/db.in.ogr.1' is up to date.
darwin10.8.0/man/man1/db.login.1' is up to date.
darwin10.8.0/man/man1/db.out.ogr.1' is up to date.
darwin10.8.0/man/man1/db.select.1' is up to date.
darwin10.8.0/man/man1/db.tables.1' is up to date.
darwin10.8.0/man/man1/db.test.1' is up to date.
darwin10.8.0/docs/html/display.html
darwin10.8.0/man/man1/display.1
darwin10.8.0/docs/html/displaydrivers.html
darwin10.8.0/man/man1/displaydrivers.1
darwin10.8.0/docs/html/full_index.html
darwin10.8.0/man/man1/full_index.1
darwin10.8.0/man/man1/g.access.1' is up to date.
darwin10.8.0/man/man1/g.copy.1' is up to date.
darwin10.8.0/man/man1/g.dirseps.1' is up to date.
darwin10.8.0/man/man1/g.extension.1' is up to date.
darwin10.8.0/man/man1/g.filename.1' is up to date.
darwin10.8.0/man/man1/g.findetc.1' is up to date.
darwin10.8.0/man/man1/g.findfile.1' is up to date.
darwin10.8.0/man/man1/g.gisenv.1' is up to date.
darwin10.8.0/man/man1/g.gui.1' is up to date.
darwin10.8.0/man/man1/g.list.1' is up to date.
darwin10.8.0/man/man1/g.manual.1' is up to date.
darwin10.8.0/man/man1/g.mapset.1' is up to date.
darwin10.8.0/man/man1/g.mapsets.1' is up to date.
darwin10.8.0/man/man1/g.message.1' is up to date.
darwin10.8.0/man/man1/g.mkfontcap.1' is up to date.
darwin10.8.0/man/man1/g.mlist.1' is up to date.
darwin10.8.0/man/man1/g.mremove.1' is up to date.
darwin10.8.0/man/man1/g.parser.1' is up to date.
darwin10.8.0/man/man1/g.pnmcomp.1' is up to date.
darwin10.8.0/man/man1/g.ppmtopng.1' is up to date.
darwin10.8.0/man/man1/g.proj.1' is up to date.
darwin10.8.0/man/man1/g.region.1' is up to date.
darwin10.8.0/man/man1/g.remove.1' is up to date.
darwin10.8.0/man/man1/g.rename.1' is up to date.
darwin10.8.0/man/man1/g.tempfile.1' is up to date.
darwin10.8.0/man/man1/g.transform.1' is up to date.
darwin10.8.0/man/man1/g.version.1' is up to date.
darwin10.8.0/docs/html/general.html
darwin10.8.0/man/man1/general.1
darwin10.8.0/man/man1/grass-dbf.1' is up to date.
darwin10.8.0/man/man1/grass-odbc.1' is up to date.
darwin10.8.0/man/man1/grass-ogr.1' is up to date.
darwin10.8.0/man/man1/grass-sqlite.1' is up to date.
darwin10.8.0/docs/html/grass7.html
darwin10.8.0/man/man1/grass7.1
darwin10.8.0/docs/html/helptext.html
darwin10.8.0/man/man1/helptext.1
darwin10.8.0/man/man1/htmldriver.1' is up to date.
darwin10.8.0/man/man1/i.albedo.1' is up to date.
darwin10.8.0/man/man1/i.aster.toar.1' is up to date.
darwin10.8.0/man/man1/i.atcorr.1' is up to date.
darwin10.8.0/man/man1/i.biomass.1' is up to date.
darwin10.8.0/man/man1/i.cca.1' is up to date.
darwin10.8.0/man/man1/i.cluster.1' is up to date.
darwin10.8.0/man/man1/i.eb.eta.1' is up to date.
darwin10.8.0/man/man1/i.eb.evapfr.1' is up to date.
darwin10.8.0/man/man1/i.eb.h_sebal01.1' is up to date.
darwin10.8.0/man/man1/i.eb.netrad.1' is up to date.
darwin10.8.0/man/man1/i.eb.soilheatflux.1' is up to date.
darwin10.8.0/man/man1/i.emissivity.1' is up to date.
darwin10.8.0/man/man1/i.evapo.mh.1' is up to date.
darwin10.8.0/man/man1/i.evapo.pm.1' is up to date.
darwin10.8.0/man/man1/i.evapo.pt.1' is up to date.
darwin10.8.0/man/man1/i.evapo.time.1' is up to date.
darwin10.8.0/man/man1/i.fft.1' is up to date.
darwin10.8.0/man/man1/i.fusion.brovey.1' is up to date.
darwin10.8.0/man/man1/i.gensig.1' is up to date.
darwin10.8.0/man/man1/i.gensigset.1' is up to date.
darwin10.8.0/man/man1/i.group.1' is up to date.
darwin10.8.0/man/man1/i.his.rgb.1' is up to date.
darwin10.8.0/man/man1/i.ifft.1' is up to date.
darwin10.8.0/man/man1/i.image.mosaic.1' is up to date.
darwin10.8.0/man/man1/i.in.spotvgt.1' is up to date.
darwin10.8.0/man/man1/i.landsat.acca.1' is up to date.
darwin10.8.0/man/man1/i.landsat.rgb.1' is up to date.
darwin10.8.0/man/man1/i.landsat.toar.1' is up to date.
darwin10.8.0/man/man1/i.latlong.1' is up to date.
darwin10.8.0/man/man1/i.maxlik.1' is up to date.
darwin10.8.0/man/man1/i.modis.qc.1' is up to date.
darwin10.8.0/man/man1/i.oif.1' is up to date.
darwin10.8.0/man/man1/i.pca.1' is up to date.
darwin10.8.0/man/man1/i.rectify.1' is up to date.
darwin10.8.0/man/man1/i.rgb.his.1' is up to date.
darwin10.8.0/man/man1/i.smap.1' is up to date.
darwin10.8.0/man/man1/i.spectral.1' is up to date.
darwin10.8.0/man/man1/i.sunhours.1' is up to date.
darwin10.8.0/man/man1/i.target.1' is up to date.
darwin10.8.0/man/man1/i.tasscap.1' is up to date.
darwin10.8.0/man/man1/i.vi.1' is up to date.
darwin10.8.0/man/man1/i.zc.1' is up to date.
darwin10.8.0/docs/html/imagery.html
darwin10.8.0/man/man1/imagery.1
darwin10.8.0/man/man1/imageryintro.1' is up to date.
darwin10.8.0/docs/html/index.html
darwin10.8.0/man/man1/index.1
darwin10.8.0/man/man1/lrs.1' is up to date.
darwin10.8.0/man/man1/m.cogo.1' is up to date.
darwin10.8.0/man/man1/m.measure.1' is up to date.
darwin10.8.0/man/man1/m.proj.1' is up to date.
darwin10.8.0/docs/html/misc.html
darwin10.8.0/man/man1/misc.1
darwin10.8.0/man/man1/nviz.1' is up to date.
darwin10.8.0/man/man1/pngdriver.1' is up to date.
darwin10.8.0/docs/html/postscript.html
darwin10.8.0/man/man1/postscript.1
darwin10.8.0/man/man1/projectionintro.1' is up to date.
darwin10.8.0/man/man1/ps.map.1' is up to date.
darwin10.8.0/man/man1/psdriver.1' is up to date.
darwin10.8.0/man/man1/r.basins.fill.1' is up to date.
darwin10.8.0/man/man1/r.bitpattern.1' is up to date.
darwin10.8.0/man/man1/r.blend.1' is up to date.
darwin10.8.0/man/man1/r.buffer.1' is up to date.
darwin10.8.0/man/man1/r.buffer2.1' is up to date.
darwin10.8.0/man/man1/r.carve.1' is up to date.
darwin10.8.0/man/man1/r.category.1' is up to date.
darwin10.8.0/man/man1/r.circle.1' is up to date.
darwin10.8.0/man/man1/r.clump.1' is up to date.
darwin10.8.0/man/man1/r.coin.1' is up to date.
darwin10.8.0/man/man1/r.colors.1' is up to date.
darwin10.8.0/man/man1/r.colors.out.1' is up to date.
darwin10.8.0/man/man1/r.colors.stddev.1' is up to date.
darwin10.8.0/man/man1/r.composite.1' is up to date.
darwin10.8.0/man/man1/r.compress.1' is up to date.
darwin10.8.0/man/man1/r.contour.1' is up to date.
darwin10.8.0/man/man1/r.cost.1' is up to date.
darwin10.8.0/man/man1/r.covar.1' is up to date.
darwin10.8.0/man/man1/r.cross.1' is up to date.
darwin10.8.0/man/man1/r.describe.1' is up to date.
darwin10.8.0/man/man1/r.distance.1' is up to date.
darwin10.8.0/man/man1/r.drain.1' is up to date.
darwin10.8.0/man/man1/r.external.1' is up to date.
darwin10.8.0/man/man1/r.external.out.1' is up to date.
darwin10.8.0/man/man1/r.fill.dir.1' is up to date.
darwin10.8.0/man/man1/r.fillnulls.1' is up to date.
darwin10.8.0/man/man1/r.flow.1' is up to date.
darwin10.8.0/man/man1/r.grow.distance.1' is up to date.
darwin10.8.0/man/man1/r.grow.1' is up to date.
darwin10.8.0/man/man1/r.gwflow.1' is up to date.
darwin10.8.0/man/man1/r.his.1' is up to date.
darwin10.8.0/man/man1/r.horizon.1' is up to date.
darwin10.8.0/man/man1/r.in.arc.1' is up to date.
darwin10.8.0/man/man1/r.in.ascii.1' is up to date.
darwin10.8.0/man/man1/r.in.aster.1' is up to date.
darwin10.8.0/man/man1/r.in.bin.1' is up to date.
darwin10.8.0/man/man1/r.in.gdal.1' is up to date.
darwin10.8.0/man/man1/r.in.gridatb.1' is up to date.
darwin10.8.0/man/man1/r.in.mat.1' is up to date.
darwin10.8.0/man/man1/r.in.png.1' is up to date.
darwin10.8.0/man/man1/r.in.poly.1' is up to date.
darwin10.8.0/man/man1/r.in.srtm.1' is up to date.
darwin10.8.0/man/man1/r.in.wms.1' is up to date.
darwin10.8.0/man/man1/r.in.xyz.1' is up to date.
darwin10.8.0/man/man1/r.info.1' is up to date.
darwin10.8.0/man/man1/r.kappa.1' is up to date.
darwin10.8.0/man/man1/r.lake.1' is up to date.
darwin10.8.0/man/man1/r.li.cwed.1' is up to date.
darwin10.8.0/man/man1/r.li.daemon.1' is up to date.
darwin10.8.0/man/man1/r.li.dominance.1' is up to date.
darwin10.8.0/man/man1/r.li.edgedensity.1' is up to date.
darwin10.8.0/man/man1/r.li.1' is up to date.
darwin10.8.0/man/man1/r.li.mpa.1' is up to date.
darwin10.8.0/man/man1/r.li.mps.1' is up to date.
darwin10.8.0/man/man1/r.li.padcv.1' is up to date.
darwin10.8.0/man/man1/r.li.padrange.1' is up to date.
darwin10.8.0/man/man1/r.li.padsd.1' is up to date.
darwin10.8.0/man/man1/r.li.patchdensity.1' is up to date.
darwin10.8.0/man/man1/r.li.patchnum.1' is up to date.
darwin10.8.0/man/man1/r.li.pielou.1' is up to date.
darwin10.8.0/man/man1/r.li.renyi.1' is up to date.
darwin10.8.0/man/man1/r.li.richness.1' is up to date.
darwin10.8.0/man/man1/r.li.shannon.1' is up to date.
darwin10.8.0/man/man1/r.li.shape.1' is up to date.
darwin10.8.0/man/man1/r.li.simpson.1' is up to date.
darwin10.8.0/man/man1/r.los.1' is up to date.
darwin10.8.0/man/man1/r.mapcalc.1' is up to date.
darwin10.8.0/man/man1/r.mask.1' is up to date.
darwin10.8.0/man/man1/r.mfilter.1' is up to date.
darwin10.8.0/man/man1/r.mode.1' is up to date.
darwin10.8.0/man/man1/r.neighbors.1' is up to date.
darwin10.8.0/man/man1/r.null.1' is up to date.
darwin10.8.0/man/man1/r.out.arc.1' is up to date.
darwin10.8.0/man/man1/r.out.ascii.1' is up to date.
darwin10.8.0/man/man1/r.out.bin.1' is up to date.
darwin10.8.0/man/man1/r.out.gdal.1' is up to date.
darwin10.8.0/man/man1/r.out.gridatb.1' is up to date.
darwin10.8.0/man/man1/r.out.mat.1' is up to date.
darwin10.8.0/man/man1/r.out.mpeg.1' is up to date.
darwin10.8.0/man/man1/r.out.png.1' is up to date.
darwin10.8.0/man/man1/r.out.pov.1' is up to date.
darwin10.8.0/man/man1/r.out.ppm.1' is up to date.
darwin10.8.0/man/man1/r.out.ppm3.1' is up to date.
darwin10.8.0/man/man1/r.out.tiff.1' is up to date.
darwin10.8.0/man/man1/r.out.vrml.1' is up to date.
darwin10.8.0/man/man1/r.out.vtk.1' is up to date.
darwin10.8.0/man/man1/r.out.xyz.1' is up to date.
darwin10.8.0/man/man1/r.pack.1' is up to date.
darwin10.8.0/man/man1/r.param.scale.1' is up to date.
darwin10.8.0/man/man1/r.patch.1' is up to date.
darwin10.8.0/man/man1/r.plane.1' is up to date.
darwin10.8.0/man/man1/r.profile.1' is up to date.
darwin10.8.0/man/man1/r.proj.1' is up to date.
darwin10.8.0/man/man1/r.quant.1' is up to date.
darwin10.8.0/man/man1/r.quantile.1' is up to date.
darwin10.8.0/man/man1/r.random.cells.1' is up to date.
darwin10.8.0/man/man1/r.random.1' is up to date.
darwin10.8.0/man/man1/r.random.surface.1' is up to date.
darwin10.8.0/man/man1/r.reclass.area.1' is up to date.
darwin10.8.0/man/man1/r.reclass.1' is up to date.
darwin10.8.0/man/man1/r.recode.1' is up to date.
darwin10.8.0/man/man1/r.region.1' is up to date.
darwin10.8.0/man/man1/r.regression.line.1' is up to date.
darwin10.8.0/man/man1/r.report.1' is up to date.
darwin10.8.0/man/man1/r.resamp.bspline.1' is up to date.
darwin10.8.0/man/man1/r.resamp.filter.1' is up to date.
darwin10.8.0/man/man1/r.resamp.interp.1' is up to date.
darwin10.8.0/man/man1/r.resamp.rst.1' is up to date.
darwin10.8.0/man/man1/r.resamp.stats.1' is up to date.
darwin10.8.0/man/man1/r.resample.1' is up to date.
darwin10.8.0/man/man1/r.rescale.eq.1' is up to date.
darwin10.8.0/man/man1/r.rescale.1' is up to date.
darwin10.8.0/man/man1/r.ros.1' is up to date.
darwin10.8.0/man/man1/r.series.1' is up to date.
darwin10.8.0/man/man1/r.shaded.relief.1' is up to date.
darwin10.8.0/man/man1/r.sim.sediment.1' is up to date.
darwin10.8.0/man/man1/r.sim.water.1' is up to date.
darwin10.8.0/man/man1/r.slope.aspect.1' is up to date.
darwin10.8.0/man/man1/r.solute.transport.1' is up to date.
darwin10.8.0/man/man1/r.spread.1' is up to date.
darwin10.8.0/man/man1/r.spreadpath.1' is up to date.
darwin10.8.0/man/man1/r.statistics.1' is up to date.
darwin10.8.0/man/man1/r.statistics2.1' is up to date.
darwin10.8.0/man/man1/r.statistics3.1' is up to date.
darwin10.8.0/man/man1/r.stats.1' is up to date.
darwin10.8.0/man/man1/r.sun.1' is up to date.
darwin10.8.0/man/man1/r.sunmask.1' is up to date.
darwin10.8.0/man/man1/r.support.1' is up to date.
darwin10.8.0/man/man1/r.support.stats.1' is up to date.
darwin10.8.0/man/man1/r.surf.area.1' is up to date.
darwin10.8.0/man/man1/r.surf.contour.1' is up to date.
darwin10.8.0/man/man1/r.surf.fractal.1' is up to date.
darwin10.8.0/man/man1/r.surf.gauss.1' is up to date.
darwin10.8.0/man/man1/r.surf.idw.1' is up to date.
darwin10.8.0/man/man1/r.surf.idw2.1' is up to date.
darwin10.8.0/man/man1/r.surf.random.1' is up to date.
darwin10.8.0/man/man1/r.terraflow.1' is up to date.
darwin10.8.0/man/man1/r.texture.1' is up to date.
darwin10.8.0/man/man1/r.thin.1' is up to date.
darwin10.8.0/man/man1/r.tileset.1' is up to date.
darwin10.8.0/man/man1/r.timestamp.1' is up to date.
darwin10.8.0/man/man1/r.to.rast3.1' is up to date.
darwin10.8.0/man/man1/r.to.rast3elev.1' is up to date.
darwin10.8.0/man/man1/r.to.vect.1' is up to date.
darwin10.8.0/man/man1/r.topidx.1' is up to date.
darwin10.8.0/man/man1/r.topmodel.1' is up to date.
darwin10.8.0/man/man1/r.transect.1' is up to date.
darwin10.8.0/man/man1/r.univar.1' is up to date.
darwin10.8.0/man/man1/r.unpack.1' is up to date.
darwin10.8.0/man/man1/r.uslek.1' is up to date.
darwin10.8.0/man/man1/r.usler.1' is up to date.
darwin10.8.0/man/man1/r.volume.1' is up to date.
darwin10.8.0/man/man1/r.walk.1' is up to date.
darwin10.8.0/man/man1/r.water.outlet.1' is up to date.
darwin10.8.0/man/man1/r.watershed.1' is up to date.
darwin10.8.0/man/man1/r.what.color.1' is up to date.
darwin10.8.0/man/man1/r.what.1' is up to date.
darwin10.8.0/man/man1/r3.colors.1' is up to date.
darwin10.8.0/man/man1/r3.colors.out.1' is up to date.
darwin10.8.0/man/man1/r3.cross.rast.1' is up to date.
darwin10.8.0/man/man1/r3.gwflow.1' is up to date.
darwin10.8.0/man/man1/r3.in.ascii.1' is up to date.
darwin10.8.0/man/man1/r3.in.v5d.1' is up to date.
darwin10.8.0/man/man1/r3.info.1' is up to date.
darwin10.8.0/man/man1/r3.mapcalc.1' is up to date.
darwin10.8.0/man/man1/r3.mask.1' is up to date.
darwin10.8.0/man/man1/r3.mkdspf.1' is up to date.
darwin10.8.0/man/man1/r3.null.1' is up to date.
darwin10.8.0/man/man1/r3.out.ascii.1' is up to date.
darwin10.8.0/man/man1/r3.out.v5d.1' is up to date.
darwin10.8.0/man/man1/r3.out.vtk.1' is up to date.
darwin10.8.0/man/man1/r3.retile.1' is up to date.
darwin10.8.0/man/man1/r3.stats.1' is up to date.
darwin10.8.0/man/man1/r3.timestamp.1' is up to date.
darwin10.8.0/man/man1/r3.to.rast.1' is up to date.
darwin10.8.0/man/man1/r3.univar.1' is up to date.
darwin10.8.0/docs/html/raster.html
darwin10.8.0/man/man1/raster.1
darwin10.8.0/docs/html/raster3D.html
darwin10.8.0/man/man1/raster3D.1
darwin10.8.0/man/man1/raster3dintro.1' is up to date.
darwin10.8.0/man/man1/rasterintro.1' is up to date.
darwin10.8.0/man/man1/sql.1' is up to date.
darwin10.8.0/man/man1/v.buffer.1' is up to date.
darwin10.8.0/man/man1/v.build.all.1' is up to date.
darwin10.8.0/man/man1/v.build.1' is up to date.
darwin10.8.0/man/man1/v.build.polylines.1' is up to date.
darwin10.8.0/man/man1/v.category.1' is up to date.
darwin10.8.0/man/man1/v.centroids.1' is up to date.
darwin10.8.0/man/man1/v.class.1' is up to date.
darwin10.8.0/man/man1/v.clean.1' is up to date.
darwin10.8.0/man/man1/v.colors.1' is up to date.
darwin10.8.0/man/man1/v.convert.all.1' is up to date.
darwin10.8.0/man/man1/v.convert.1' is up to date.
darwin10.8.0/man/man1/v.db.addcolumn.1' is up to date.
darwin10.8.0/man/man1/v.db.addtable.1' is up to date.
darwin10.8.0/man/man1/v.db.connect.1' is up to date.
darwin10.8.0/man/man1/v.db.dropcolumn.1' is up to date.
darwin10.8.0/man/man1/v.db.droprow.1' is up to date.
darwin10.8.0/man/man1/v.db.droptable.1' is up to date.
darwin10.8.0/man/man1/v.db.join.1' is up to date.
darwin10.8.0/man/man1/v.db.reconnect.all.1' is up to date.
darwin10.8.0/man/man1/v.db.renamecolumn.1' is up to date.
darwin10.8.0/man/man1/v.db.select.1' is up to date.
darwin10.8.0/man/man1/v.db.univar.1' is up to date.
darwin10.8.0/man/man1/v.db.update.1' is up to date.
darwin10.8.0/man/man1/v.delaunay.1' is up to date.
darwin10.8.0/man/man1/v.dissolve.1' is up to date.
darwin10.8.0/man/man1/v.distance.1' is up to date.
darwin10.8.0/man/man1/v.drape.1' is up to date.
darwin10.8.0/man/man1/v.edit.1' is up to date.
darwin10.8.0/man/man1/v.external.1' is up to date.
darwin10.8.0/man/man1/v.external.out.1' is up to date.
darwin10.8.0/man/man1/v.extract.1' is up to date.
darwin10.8.0/man/man1/v.extrude.1' is up to date.
darwin10.8.0/man/man1/v.generalize.1' is up to date.
darwin10.8.0/man/man1/v.hull.1' is up to date.
darwin10.8.0/man/man1/v.in.ascii.1' is up to date.
darwin10.8.0/man/man1/v.in.db.1' is up to date.
darwin10.8.0/man/man1/v.in.dxf.1' is up to date.
darwin10.8.0/man/man1/v.in.e00.1' is up to date.
darwin10.8.0/man/man1/v.in.geonames.1' is up to date.
darwin10.8.0/man/man1/v.in.gns.1' is up to date.
darwin10.8.0/man/man1/v.in.lines.1' is up to date.
darwin10.8.0/man/man1/v.in.mapgen.1' is up to date.
darwin10.8.0/man/man1/v.in.ogr.1' is up to date.
darwin10.8.0/man/man1/v.in.region.1' is up to date.
darwin10.8.0/man/man1/v.in.sites.all.1' is up to date.
darwin10.8.0/man/man1/v.in.sites.1' is up to date.
darwin10.8.0/man/man1/v.in.wfs.1' is up to date.
darwin10.8.0/man/man1/v.info.1' is up to date.
darwin10.8.0/man/man1/v.kcv.1' is up to date.
darwin10.8.0/man/man1/v.kernel.1' is up to date.
darwin10.8.0/man/man1/v.krige.1' is up to date.
darwin10.8.0/man/man1/v.label.1' is up to date.
darwin10.8.0/man/man1/v.lidar.correction.1' is up to date.
darwin10.8.0/man/man1/v.lidar.edgedetection.1' is up to date.
darwin10.8.0/man/man1/v.lidar.growing.1' is up to date.
darwin10.8.0/man/man1/v.lrs.create.1' is up to date.
darwin10.8.0/man/man1/v.lrs.label.1' is up to date.
darwin10.8.0/man/man1/v.lrs.segment.1' is up to date.
darwin10.8.0/man/man1/v.lrs.where.1' is up to date.
darwin10.8.0/man/man1/v.mkgrid.1' is up to date.
darwin10.8.0/man/man1/v.neighbors.1' is up to date.
darwin10.8.0/man/man1/v.net.alloc.1' is up to date.
darwin10.8.0/man/man1/v.net.allpairs.1' is up to date.
darwin10.8.0/man/man1/v.net.bridge.1' is up to date.
darwin10.8.0/man/man1/v.net.centrality.1' is up to date.
darwin10.8.0/man/man1/v.net.components.1' is up to date.
darwin10.8.0/man/man1/v.net.connectivity.1' is up to date.
darwin10.8.0/man/man1/v.net.distance.1' is up to date.
darwin10.8.0/man/man1/v.net.flow.1' is up to date.
darwin10.8.0/man/man1/v.net.1' is up to date.
darwin10.8.0/man/man1/v.net.iso.1' is up to date.
darwin10.8.0/man/man1/v.net.path.1' is up to date.
darwin10.8.0/man/man1/v.net.salesman.1' is up to date.
darwin10.8.0/man/man1/v.net.spanningtree.1' is up to date.
darwin10.8.0/man/man1/v.net.steiner.1' is up to date.
darwin10.8.0/man/man1/v.net.timetable.1' is up to date.
darwin10.8.0/man/man1/v.net.visibility.1' is up to date.
darwin10.8.0/man/man1/v.normal.1' is up to date.
darwin10.8.0/man/man1/v.out.ascii.1' is up to date.
darwin10.8.0/man/man1/v.out.dxf.1' is up to date.
darwin10.8.0/man/man1/v.out.gps.1' is up to date.
darwin10.8.0/man/man1/v.out.ogr.1' is up to date.
darwin10.8.0/man/man1/v.out.pov.1' is up to date.
darwin10.8.0/man/man1/v.out.svg.1' is up to date.
darwin10.8.0/man/man1/v.out.vtk.1' is up to date.
darwin10.8.0/man/man1/v.outlier.1' is up to date.
darwin10.8.0/man/man1/v.overlay.1' is up to date.
darwin10.8.0/man/man1/v.parallel.1' is up to date.
darwin10.8.0/man/man1/v.patch.1' is up to date.
darwin10.8.0/man/man1/v.perturb.1' is up to date.
darwin10.8.0/man/man1/v.proj.1' is up to date.
darwin10.8.0/man/man1/v.qcount.1' is up to date.
darwin10.8.0/man/man1/v.random.1' is up to date.
darwin10.8.0/man/man1/v.rast.stats.1' is up to date.
darwin10.8.0/man/man1/v.reclass.1' is up to date.
darwin10.8.0/man/man1/v.report.1' is up to date.
darwin10.8.0/man/man1/v.sample.1' is up to date.
darwin10.8.0/man/man1/v.segment.1' is up to date.
darwin10.8.0/man/man1/v.select.1' is up to date.
darwin10.8.0/man/man1/v.split.1' is up to date.
darwin10.8.0/man/man1/v.support.1' is up to date.
darwin10.8.0/man/man1/v.surf.bspline.1' is up to date.
darwin10.8.0/man/man1/v.surf.idw.1' is up to date.
darwin10.8.0/man/man1/v.surf.rst.1' is up to date.
darwin10.8.0/man/man1/v.to.3d.1' is up to date.
darwin10.8.0/man/man1/v.to.db.1' is up to date.
darwin10.8.0/man/man1/v.to.points.1' is up to date.
darwin10.8.0/man/man1/v.to.rast.1' is up to date.
darwin10.8.0/man/man1/v.to.rast3.1' is up to date.
darwin10.8.0/man/man1/v.transform.1' is up to date.
darwin10.8.0/man/man1/v.type.1' is up to date.
darwin10.8.0/man/man1/v.univar.1' is up to date.
darwin10.8.0/man/man1/v.vol.rst.1' is up to date.
darwin10.8.0/man/man1/v.voronoi.1' is up to date.
darwin10.8.0/man/man1/v.what.1' is up to date.
darwin10.8.0/man/man1/v.what.rast.1' is up to date.
darwin10.8.0/man/man1/v.what.vect.1' is up to date.
darwin10.8.0/docs/html/variables.html
darwin10.8.0/docs/html/vector.html
darwin10.8.0/man/man1/vectorintro.1' is up to date.
darwin10.8.0/docs/html/wxGUI.Attribute_Table_Manager.html
darwin10.8.0/docs/html/wxGUI.GCP_Manager.html
can't handle line breaks in <dt>...</dt>
darwin10.8.0/docs/html/wxGUI.Modeler.html
darwin10.8.0/docs/html/wxGUI.Nviz.html
darwin10.8.0/docs/html/wxGUI.PsMap.html
darwin10.8.0/docs/html/wxGUI.Vector_Digitizer.html
darwin10.8.0/docs/html/wxGUI.html
darwin10.8.0/man/man1/wximgview.1' is up to date.
darwin10.8.0/man/man1/wxpyimgview.1' is up to date.
darwin10.8.0/man/man1/xganim.1' is up to date.
mkdir -p -m 755 OBJ.i386-apple-darwin10.8.0
gcc -g -O2 -arch i386 -arch x86_64 -o OBJ.i386-apple-
darwin10.8.0/main.o -c main.m
gcc -L/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/lib
-arch i386 -arch x86_64 -o OBJ.i386-apple-darwin10.8.0/GRASS OBJ.i386
-apple-darwin10.8.0/main.o -framework Cocoa -framework AppleScriptKit
sed -e "s,@GRASS_VERSION_MAJOR@,7,g" \
                 -e "s,@GRASS_VERSION_MINOR@,0,g" \
                 -e "s,@GRASS_VERSION_RELEASE@,svn,g" \
                 -e "s,@GRASS_VERSION_BUILD@,`/bin/date "+%y%m%d"`,g" \
                 Info.plist.in > OBJ.i386-apple-darwin10.8.0/Info.plist
osacompile -d -x -i /System/Library/Frameworks/AppleScriptKit.framework -o
OBJ.i386-apple-darwin10.8.0/GRASS.scpt GRASS.applescript
sed -e "s,@GDAL_BIN_PATH@,`echo "-framework GDAL" | sed -e "s,-L," -e
"s,/lib.*$,/bin:,"`," \
                 -e "s,@PROJ_BIN_PATH@,`echo
"/Library/Frameworks/PROJ.framework/Programs/nad2bin" | sed -e "s,.=," -e
"s,/nad2bin,:,"`," \
                 -e "s,@X11@,g" \
                 -e "s,@PYVER@,`python -V 2>&1 | cut -d \ -f 2 | cut -d .
-f 1,2`,g" \
                 -e "s,@WX64BIT@,0,g" \
                 -e "s,@GRASS_NAME@,grass70,g" \
                 grass.sh.in > OBJ.i386-apple-darwin10.8.0/grass.sh
make /Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/AUTHORS /Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/COPYING /Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/CHANGES /Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/REQUIREMENTS.html
/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/GPL.TXT
darwin10.8.0/contributors.csv
darwin10.8.0/contributors_extra.csv
darwin10.8.0/translators.csv
/usr/bin/install -c -m 644 AUTHORS
/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/AUTHORS
/usr/bin/install -c -m 644 COPYING
/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/COPYING
/usr/bin/install -c -m 644 CHANGES
/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/CHANGES
/usr/bin/install -c -m 644 REQUIREMENTS.html
/usr/bin/install -c -m 644 GPL.TXT
/usr/bin/install -c -m 644 contributors.csv
/usr/bin/install -c -m 644 contributors_extra.csv
/usr/bin/install -c -m 644 translators.csv
make manifests
make[1]: Nothing to be done for `manifests'.
GRASS GIS compilation log
Started compilation: Wed Jun 29 09:48:08 MST 2011
Errors in:
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed Jun 29 09:57:37 MST 2011
make: *** [default] Error 1
In file included from /System/Library/Frameworks/CorIn file included from
/System/Library/Frameworks/CoreFo from
/System/Library/Frameworks/CoreFoundation.framework/Headers/CoreFoundation.h:38,
                  from
/System/Library/Frameworks/CoreServices.framework/Frameworks/CarbonCore.framework/Headers/CarbonCore.h:20,
                  from
/System/Library/Frameworks/CoreServices.framework/Frameworks/AE.framework/Headers/AE.h:20,
                  from
/System/Library/Frameworks/CoreServices.framework/Headers/CoreServices.h:21,
                  from
/System/Library/Frameworks/Carbon.framework/Headers/Carbon.h:20,
                  from
/System/Library/Frameworks/AGL.framework/Headers/agl.h:22,
                  from /Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/include/grass/nviz.h:28,
                  from local_proto.h:4,
                  from vector.c:22:
/System/Library/Frameworks/CoreServices.framework/Headers/../Frameworks/CarbonCore.framework/Headers/MacTypes.h:503:
error: redefinition of ‘struct Rect’
/System/Library/Frameworks/CoreFoundation.framework/Headers/CFBase.h:48,
                  from
                  from
                  from
                  from
                  from
                  from
                  from vector.c:22:
lipo: can't figure out the architecture type of:
/var/folders/AK/AKpYwDw1EoWI+fFF02nvRk+++TI/-Tmp-//ccJsLCb0.out
make: *** [OBJ.i386-apple-darwin10.8.0/vector.o] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1396&gt;
      Cpu: OSX/Intel |
Comment(by mmetz):
struct Rect is defined by the R-Tree: lib/vector/rtree/index.h. This is
nothing new and has been there at least since GRASS 6.0.
A solution would be to change the name of struct Rect in
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1396#comment:1&gt;
      Cpu: OSX/Intel |
Comment(by mmetz):
Please try r46942.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1396#comment:2&gt;
      Cpu: OSX/Intel |
Comment(by helena):
it compiles on Mac for me now, Michael please test and if it works for you
too, I think you can close this one,
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/1396#comment:3&gt;
      Cpu: OSX/Intel |
Comment(by cmbarton):
Compiles for me too. Thanks much Markus.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/1396#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxnviz command
  Platform: MacOSX | Cpu: OSX/Intel
Changes (by martinl):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/1396#comment:5&gt;
