[GRASS-dev] [GRASS GIS] #1407: confusing error message after grass7 crash
Reporter: MilenaN | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.2
Component: Startup | Version: svn-trunk
Keywords: | Platform: All
      Cpu: Unspecified |
After crashed grass7 session grass complains about .gislock file. The
message is unhelpful if the user doesn't know what to do. Please add an
explanation for the needed step to fix the blocked grass installation.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407&gt;
      Cpu: Unspecified |
Comment(by MilenaN):
Checking with the file expolorer, the indicated file does not exist.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:1&gt;
Keywords: wingrass | Platform: Unspecified
      Cpu: Unspecified |
Changes (by martinl):
  * keywords: => wingrass
  * platform: All => Unspecified
Comment:
I think it's related only to Windows...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:2&gt;
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
Changes (by neteler):
  * keywords: wingrass =>
Comment:
The problem is similar on Linux, see attachment.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:3&gt;
      Cpu: Unspecified |
Comment(by martinl):
I have modified the dialog to allow remove gislock and continue (r47226) -
see the attached screenshot. Would it help?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:4&gt;
      Cpu: Unspecified |
Replying to [comment:1 MilenaN]:
this should only refer to wingrass...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:5&gt;
Reporter: MilenaN | Owner: martinl
     Type: enhancement | Status: assigned
      Cpu: Unspecified |
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:6&gt;
Keywords: wxgui | Platform: Unspecified
      Cpu: Unspecified |
  * keywords: => wxgui
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:7&gt;
      Cpu: Unspecified |
Replying to [comment:4 martinl]:
- see the attached screenshot. Would it help?
Backported to devbr6 in r47246. Testing welcomed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:8&gt;
      Cpu: Unspecified |
Replying to [comment:8 martinl]:
(r47226) - see the attached screenshot. Would it help?
Before closing the ticket, should it be also backported to {{{relbr64}}}?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:9&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: wxgui
  Platform: Unspecified | Cpu: Unspecified
  * status: assigned => closed
  * resolution: => fixed
Comment:
Replying to [comment:9 martinl]:
{{{relbr64}}}?
Backported as r48257
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:10&gt;
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: startup
  * keywords: wxgui => startup
  * component: Startup => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:11&gt;
      Type: enhancement | Status: reopened
Resolution: | Keywords: startup
Changes (by hamish):
  * status: closed => reopened
  * resolution: fixed =>
Comment:
> continue (r47226) -
I would argue to make the warning a lot more dire and the functionality
much harder to access.
the user is blocked from starting twice for a good reason, and it's for
their own safety whether they realize it or not. Too many people are used
to broken software and just click past "an error occurred -> ignore"
without thinking about it.
since grass can crash too, or the power go out, etc, sure it's nice to
allow recovery without filesystem hacks, but perhaps have it launch a
second dialog saying "Are you sure? If you really are running another
GRASS session doing this could corrupt your data. Have another look in the
processor manager just to be sure.."
or something like that.
Hamsih
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:12&gt;
  Priority: blocker | Milestone: 6.4.2
  * priority: normal => blocker
Comment:
Replying to [comment:12 hamish]:
Try r48565, backported to devbr in r48566 for testing. Is it better?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:13&gt;
  * status: reopened => closed
Comment:
Replying to [comment:13 martinl]:
Backported to relbr64 in r49016
Ticket URL: <http://trac.osgeo.org/grass/ticket/1407#comment:14&gt;
