#1409: wxGUI command console does not parse correctly "help" and first parameter
Reporter: philippbs | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
The wxGUI command line console does not parse commands correctly,
critically the 'help' option does not work. e.g.
d.vect help
results in
ERROR: Rendering failed
and erases the map display and it leads to the undesired creation
of a layer 'help' in the Map Layers tab.
Similarly, implicit parameter declarations are not parsed, e.g. (using the
North Carolina dataset)
d.vect streams
results in the same error message as above and the creation of a layer
'streams' in Map Layers.
Keywords: | Platform: All
Cpu: x86-64 |
Changes (by neteler):
* platform: MSWindows 7 => All
Comment:
Confirmed on Linux.
In GRASS 7, on Linux the usage of "d.vect help" in the cmd console leads
instead to:
File "/home/neteler/grass70/dist.x86_64-unknown-linux-
gnu/etc/gui/wxpython/gui_modules/prompt.py", line 1097, in
OnKeyPressed
self.parent.RunCmd(cmd)
gnu/etc/gui/wxpython/gui_modules/goutput.py", line 506, in
RunCmd
layerType = layertype)
gnu/etc/gui/wxpython/gui_modules/utils.py", line 144, in
GetLayerNameFromCmd
dcmd[i] = p + '=' + v
TypeError
unsupported operand type(s) for +: 'NoneType' and 'str'
Cpu: x86-64 |
Comment(by cmbarton):
The command console is not designed to support the in-terminal help.
Instead, pressing the <tab> key will show the command syntax, much like
typing help. There needs to be a better error trap when "help" is typed to
inform the user of that.
There is also a full help manual as a tab in every command module.
Cpu: x86-64 |
I stand corrected. If you type the command, followed by "help", the
standard terminal help will print to the console output window.
This works for all commands EXCEPT d.* commands. When I type a d.*
command, followed by "help", I get an error "Error: rendering failed" and
all subsequent attempts to display a map in the window fail (with the same
error). It acts like I've switched to the Cairo driver, but the display
says it is still on the PNG driver.
Cpu: x86-64 |
Figure it out. Overly simple. Needs a better error trap
Typing "d.rast help" in the command console adds a blank map layer named
"help" to the list of layers, obscuring all layers below. It also
generates the "rendering failed" error because it cannot render the non-
existant map "help".
Reporter: philippbs | Owner: martinl
Type: defect | Status: assigned
Keywords: cmd, d. | Platform: All
Cpu: x86-64 |
Changes (by martinl):
* cc: grass-dev@… (added)
* keywords: => cmd, d.
* status: new => assigned
* owner: grass-dev@… => martinl
Comment:
Replying to [ticket:1409 philippbs]:
> d.vect help
try out r47251 (backported in r47252 to devbr6 for testing).
d.vect help
should print out usage of the module.
d.vect stream
should add `stream` map (from search path) to layer tree. After some
testing it could be backported to `relbr64`.
